Wood stringer storage?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> Wood stringer storage? Page: [1]
Login
Wood stringer storage? - 12/13/2012 2:15 AM
Thunderbolt47
Score: 111
Last Login: 5/26/2013
Status: offline
Hey Guys, Anybody came up with a good way of storing dowls, square stock, and stringers?
Kelly
_____________________________
Greg Norman said, "Happiness is a long walk with a putter." Obviously he never flew a P-51 Mustang. :)
Hide Signatures
       Post #: 1
RE: Wood stringer storage? - 12/13/2012 2:29 AM
acerc
Score: 221
Status: offline
I don't manage to keep enough to worry about storage.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to Thunderbolt47)
       Post #: 2
RE: Wood stringer storage? - 12/13/2012 3:35 AM  1 votes
invertmast
Score: 193
Status: offline
I bought a balsa storage rack what is like in the LHS'
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
(in reply to acerc)
       Post #: 3
RE: Wood stringer storage? - 12/13/2012 10:34 AM
Toysareforkids
Score: 100
Last Login: 5/8/2013
Status: offline
 I use old covering tubes & Christmas paper wraping tubes, among others. You can stand them up (tape one shut) or lay them flat, or lay them on your wing rack, etc. I use a different one for each kind of wood, control rods,  tubes, and wire I have.
   Pat
Hide Signatures
(in reply to invertmast)
       Post #: 4
RE: Wood stringer storage? - 12/13/2012 11:29 AM
AA5BY
Score: 153
Status: offline
Ditto on the storage tubes from various sources such as rolled plans, etc. And, I like to band together the stock before storing in the tubes in hope of preventing warping.
Hide Signatures
(in reply to Toysareforkids)
       Post #: 5
RE: Wood stringer storage? - 12/14/2012 4:22 AM
badger5964
Score: 110
Status: offline
I do much the same with PVC pipe and the matching solvent weld caps. I'll glue a cap on one end but leave it unglued on the other. It does cost a few dollars but one gets the protection of the hard PVC tube to protect the stuff from getting busted up. One can stand them up, lay flat they take some abuse.
I do the same for control rods, keeps them from getting bent.
Hide Signatures
(in reply to AA5BY)
       Post #: 6
RE: Wood stringer storage? - 12/14/2012 9:07 AM
Thunderbolt47
Score: 111
Status: offline
Thanks for the suggestions.
Hide Signatures
(in reply to badger5964)
       Post #: 7
RE: Wood stringer storage? - 12/14/2012 11:58 PM
Thunderbolt47
Score: 111
Status: offline
I remembered my cousin works at a local hydrolic cylinder plant. The inner piston rams come in 20 foot lenths protected by cardboard tubes. They have a big dumpster full of these tubes. A quick phone call got me five tubes of 1-3/4.
Thanks for the tips. I will post pix of what I come up with.
Hide Signatures
       Post #: 8
RE: Wood stringer storage? - 12/15/2012 2:27 AM
Edwin
Score: 156
Status: offline
I have racks under my big work bench with long boxes of wood stored in them. Sheet, stringers, all kinds with no problems.
Edwin
Hide Signatures
       Post #: 9
RE: Wood stringer storage? - 12/15/2012 12:35 PM
MILDBILL-RCU
Score: 100
Last Login: 5/25/2013
Status: offline
I work at an auto parts store & I use the hard cardboard tubes that steel brake lines arrive at the stores in. They come in all kinds of lenths, are easy to cut to any lenth needed, glue together quick with c/a glue, have heavy duty, stapled caps at the end to hold anything you could put in them. I used 7 tubes wide X 5 tubes deep. Holds hardwood stock, balsa stock, triangle stock, Round stock, etc....... I made this rack 21 years ago & it is still going strong. Hope the pictures help explain more than my words have.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
ULTRA-SPORT BROTHERHOOD #7. If enough power is good, & more is better, than "WAY TOO MUCH" is just about right!
Hide Signatures
(in reply to Edwin)
       Post #: 10
RE: Wood stringer storage? - 12/15/2012 3:57 PM
KW_Counter
Score: 141
Last Login: 5/19/2013
Status: offline
I take Badger's idea one step further.
I put a threaded end and a screw cap over it.
Make sure the cap goes over, not inside the end.
Got one for wood, one for steel rods and a short one for steel rods.
2 1/2 inch seem to be the most economical.
3 inch fittings seem to jump in price.
Good Luck,
KW_Counter
Hide Signatures
       Post #: 11
RE: Wood stringer storage? - 12/17/2012 2:29 AM
Thunderbolt47
Score: 111
Status: offline
Ok guys here is what I came up with. There are 15 tubes. Back row is 24", mid 16" and front is 11". It will get a coat of gray paint (wood only) then it will be done.
They are 2"(ID) tubes.
Thanks for the ideas.
Kelly
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to KW_Counter)
       Post #: 12
RE: Wood stringer storage? - 1/11/2013 11:20 PM
Mikie 1
Score: 105
Status: offline
Hi Guys, I stumbled on your question about storing things like control rods and other long fragile stuff and thought I would show what I came up with a couple of years ago. From the photos you'll see I found another use for those clear plastic covers for florescent lights. I like this idea because I can see into the holder and know right away if I'm leaving something behind - or - if I really do have "that" in stock.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 13
RE: Wood stringer storage? - 1/12/2013 4:59 PM
dadragon
Score: 112
Last Login: 3/14/2013
Status: offline
Thunderbolt; DiDDO
Hide Signatures
(in reply to Mikie 1)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.859RCU1
