chasis compatibility??    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> chasis compatibility??
Page: [1] 2   next >   >>
Login
chasis compatibility?? - 12/13/2012 3:16 PM
NateDogg80
Score: 100
Last Login: 2/26/2013
Status: offline
I am looking to replace my volcano epx pro chasis with an aluminum one.  I can't seem to find anything that is for the volcano other than the stock plastic one.  Is the Volocano chasis compatible with any other trucks, other than redcat epx models??
Hide Signatures
       Post #: 1
RE: chasis compatibility?? - 12/14/2012 1:49 AM
nitrosportsandrunner
Score: 296
Last Login: 5/19/2013
Status: offline
well, the diffs and suspension parts will bolt onto a nitro s30 chassis.
Everything else you would have to make mounting holes on the nitro chassis.
the nitro has a different steering servo location, no mount holes for the motor/upper chassis plate/battery posts ect.
I think it could be done, but custom holes would have to be drilled for sure. And who knows what other issues you may run into.
did you manage to break the plastic chassis?
_____________________________
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to NateDogg80)
       Post #: 2
RE: chasis compatibility?? - 12/14/2012 6:18 PM
NateDogg80
Score: 100
Status: offline
unfortunately yes.  I hit a pole doin about 20mph and it ripped the suspension arm right out of the chasis and broke where it screws in.  Also bent the crap out of hinge pins that hold the arms on.  but whats cool is... I can rebuild it.
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 3
RE: chasis compatibility?? - 12/26/2012 4:43 PM
Johnathond22
Score: 100
Last Login: 5/16/2013
Status: offline
 We all have the epx pro models and have been building many Aluminum upgrades. If you can't force the chassis to accept nitro version it is possible to upgrade to aluminum with a little home engineering. See below. This bumper took a direct pole hit at an easy 40 mph lipo epx. Still in tact.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4
RE: chasis compatibility?? - 12/26/2012 4:58 PM
Score: 296
Status: offline
quote:
ORIGINAL: Johnathond22
jeez, nice work man!
You just traced out the chassis, to cut the alloy one. Now you have heavy duty bumper as well as skid plates.
I also like where you bolted it to the chassis. You picked points that dont get any stress. If you had bolted it with the screws that hold the stock chassis to the diff cases that could have caused an issue.
Only thing I would have done different, is I would have used a much larger drill bit to make a countersink hole. Then used flat head screws to get them flush mounted with the alloy chassis.
You know, multiple people lately have been asking about alloy chassis for the volcano. Perhaps you should consider making/selling what you have there!
Hide Signatures
(in reply to Johnathond22)
       Post #: 5
RE: chasis compatibility?? - 12/26/2012 5:15 PM
Johnathond22
Score: 100
Status: offline
 Yeah, this was actually the first which is a prototype and we have actually perfected it. I will post a few photos again later of the other full guard. I did re-sink these screws. This was a quick run we built and tested heavy bashing. It helped with flipping too. It bounces on the front and rear bumpers instead of breaking off the hubs. We just got into RC and will try to keep posting new ideas. The volcano is an excellent starter truck but does indeed need a bit of protection to make it last a whole day of bashing. I'm currently building "pebble guards" cause it seems the smallest little pebble gets in the drive train and snaps the dog bones. Especially if you run lipo power. I will consider building to sell these items. We will see the responses to the other pics I post.
Hide Signatures
       Post #: 6
RE: chasis compatibility?? - 12/26/2012 6:56 PM
Score: 296
Status: offline
 Yeah, this was actually the first which is a prototype and we have actually perfected it. I will post a few photos again later of the other full guard. I did re-sink these screws. This was a quick run we built and tested heavy bashing. It helped with flipping too. It bounces on the front and rear bumpers instead of breaking off the hubs. We just got into RC and will try to keep posting new ideas. The volcano is an excellent starter truck but does indeed need a bit of protection to make it last a whole day of bashing. I'm currently building ''pebble guards'' cause it seems the smallest little pebble gets in the drive train and snaps the dog bones. Especially if you run lipo power. I will consider building to sell these items. We will see the responses to the other pics I post.
what ive seen people do, who sell custom/handmade parts on ebay is this: list the item and in the description state that the item is made after the sale. Thus, the item may take 7 days before shipping.
Thise makes it easy as you dont have to make the chassis before hand. Wait to you have the sale, then make it. If you sell enough of them quickly, then it would make sence to produce them in small batches beforehand.
What type of metal are you using, and what do you cut it with?
Other tricks I use with the volcano is putting nitro fuel tubing bits inside the diff's drive cups. This puts the dogbone further into the wheel's drive cup. There is often too much play on the dogbones, and they can come to far out of the wheel's drive cups...especially when the wheels are fully turned. Thats often the situation which causes the dogbones to bind/bend or snap.
On top of that, moving the camber and steering links to the holes closest to the hub helps alot. I find that it helps nearly as much as upgrading to the alloy ones. And there isnt much need for camber adjsutments and such on a basher monster truck like the volcano.
Just for an idea, the only other good chassis protection you can buy is the Tboneracing bumpers and skid plates. They make them for the tornado and volcano. These are high grade, larger plastic bumpers. The bumpers run you $15 each (front and rear) So, $30 for both.
Your chassis has front/rear bumper...as well as tougher chassis and serves as a skid plate (protecting all those screws)
I dont think it would be unreasonable to ask $50-$60 shipped for that chassis. If you can build it for less than $15-$20 then there is some money to be made there.
Hide Signatures
       Post #: 7
RE: chasis compatibility?? - 12/27/2012 3:14 PM
NateDogg80
Score: 100
Status: offline
Very nice job!
Let me know if you every start selling them!
Hide Signatures
       Post #: 8
RE: chasis compatibility?? - 12/29/2012 6:41 AM
Johnathond22
Score: 100
Status: offline
 Ok guys, I am now finished the final run of the Full Gaurd. Have a look. Let me know any thoughts or ideas.
Details are that the chassis skid and core is made of 1/8 aluminum and the rear bumper is aluminum 5/16 thick plate for realism. The front Gaurd  is 3/16 stainless rod. That was most likely the bulk of the work to shape a full realistic look. All is now Rhino lined and mounted ready for the bash!
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 9
RE: chasis compatibility?? - 12/29/2012 6:44 AM
Johnathond22
Score: 100
Status: offline
 Here are the rest of pics, only allowed to upload so many at a time in detail.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 10
RE: chasis compatibility?? - 12/29/2012 2:22 PM
NateDogg80
Score: 100
Status: offline
Thats bad as*!
Hide Signatures
       Post #: 11
RE: chasis compatibility?? - 12/29/2012 5:49 PM
Johnathond22
Score: 100
Status: offline
 Nate, I decided to build a few, if you want one I really just need something you would consider signature, like an ICon. These will be handmade so each can differ a little. Just provide some details as to what you would like to see in your own bumper. Ex: color, style of push, width of push. Keep in mind the aluminum used is thin to keep weight down so if it takes a heavy crash you may need to straighten it out.
Hide Signatures
       Post #: 12
RE: chasis compatibility?? - 12/29/2012 6:55 PM
Score: 296
Status: offline
Is that a axial or emaxx bumper on the back?
Hide Signatures
       Post #: 13
RE: chasis compatibility?? - 12/29/2012 7:02 PM
Johnathond22
Score: 100
Status: offline
It is a "Shear Hobbyz" rear bumper as I made this too and we are calling my "Hobby Shop" Shear Hobbyz" we we refer to the RC fun. It's not really public as I am not sure if I am ready to help the public. It's al l still just for fun right now. I am considering becoming a red cat dealer though.
Hide Signatures
       Post #: 14
RE: chasis compatibility?? - 12/29/2012 7:31 PM
NateDogg80
Score: 100
Status: offline
I would definitely want it black.  The back bumper is fine how it is.  I would maybe shorten the base of the front one a litlle, as well as the bars.  Maybe to half of the front tires.  It be nice to protect the new body i got, cuz those stock bumpers are useless for that.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 15
RE: chasis compatibility?? - 12/29/2012 7:39 PM
Johnathond22
Score: 100
Status: offline
Ok, I need a measurement from the wood to about 1/2 inch under the lights, we don't want to block the lights. I'll make an eighteen wheeler style push bumper.
Hide Signatures
       Post #: 16
RE: chasis compatibility?? - 1/1/2013 6:30 PM
Johnathond22
Score: 100
Status: offline
 Nate, see photo attached. I redesigned the bumper. It's all large plate with shorter front push. How's this look?
Click for fullsize
Hide Signatures
       Post #: 17
RE: chasis compatibility?? - 1/1/2013 7:59 PM
Score: 296
Status: offline
I like the width, but Id rather have the bumper be where the bumper on the body is. so maybe 1'' lower.
Certainly looks like it will protect the truck tho!
Hide Signatures
       Post #: 18
RE: chasis compatibility?? - 1/1/2013 8:20 PM
Johnathond22
Score: 100
Status: offline
 Nitro, I can make one for you too. What truck do you have? I do not have the chassis to outline of anything but Epx pro and Traxxas Tmax. Which Redcat do you have?
Hide Signatures
       Post #: 19
RE: chasis compatibility?? - 1/3/2013 4:45 PM
NateDogg80
Score: 100
Status: offline
Yeah I like that one better.  wish I had that the other day.  I was showing it off to some of my nephews, and ran it right into the back tire of a mini van head on at about 40mph.  demolished the front shock tower, drive shaft and bent almost every shock on it.  So needless to say, I'll have to get back to you on measurements once a buy the new parts and rebuild it.
Hide Signatures
       Post #: 20
RE: chasis compatibility?? - 1/19/2013 3:23 PM
NateDogg80
Score: 100
Status: offline
Hey John,
Finally put back together my epx pro. measurments are 3.5' from ground to front lights and they are 3.75' apart.  the backs are 5' high and 3.75' apart.  Let me know what else you need and what it will cost me. Thanks.
Hide Signatures
       Post #: 21
RE: chasis compatibility?? - 1/19/2013 4:56 PM
Score: 296
Status: offline
right now i only have the tornado epx pro.
Hide Signatures
       Post #: 22
RE: chasis compatibility?? - 1/20/2013 6:30 PM
Jswingle13
Score: 100
Last Login: 1/25/2013
Status: offline
I think I will be trying something similar on my nitro volcano..... During my final tank of break in I hit a pole just right and broke my front bumper. It took out a small piece of my body because the stock bumper provides no protection.
Hide Signatures
       Post #: 23
RE: chasis compatibility?? - 1/31/2013 1:17 PM
Johnathond22
Score: 100
Status: offline
 Nate,
     I am done with your bumper. I will post a picture when I get back in the shop this morning. We will discuss shipping g and price then. Do you prefer pm or email?
Nitro,
     Yours is done as well. Sorry for delays guys, work was hectic for a few weeks. Same question, pm or email?
Hide Signatures
       Post #: 24
RE: chasis compatibility?? - 1/31/2013 2:12 PM
NateDogg80
Score: 100
Status: offline
pm?? Posted Marked?  Since i dont know what it means, email will work.  nate_dok@yahoo.com.  thanks.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.626RCU1
