5 yr old LiPo battery charging issue    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> 5 yr old LiPo battery charging issue
Page: [1]
Login
5 yr old LiPo battery charging issue - 12/13/2012 3:52 PM
MMatheny
Score: 100
Last Login: 4/22/2013
Status: offline
I bought an Air Thunder 3s 2200mAh battery around 5 years ago, didn't get much use but I did pull it out every once in a while to discharge and charge it. Well, year or so ago I got a plane that I could use this battery for. Worked great and then lately last several times I tried to charge it using my BC-6 (real, not clone) charger, the first cell detected voltage jumps all over the place, and it eventually errors out. Testing with a cell voltage tester the voltage is solid! Even my amp/voltage meter shows solid full voltage charge! Another Turnigy 2200mAh charges fine, so I don't think it's the charger or cable.
Any ideas? I haven't had a chance to test run it to see if it loses power quickly. Might do that and also hook the ammeter in line to see what it shows.
_____________________________
Mike
"Never use your shins as a blade tracking device" - Mike
Hide Signatures
       Post #: 1
RE: 5 yr old LiPo battery charging issue - 12/13/2012 4:18 PM
t9dragon
Score: 328
Last Login: 6/16/2013
Status: offline
The battery probably has gone bad.
Hide Signatures
(in reply to MMatheny)
       Post #: 2
RE: 5 yr old LiPo battery charging issue - 12/13/2012 4:57 PM
allelectric
Score: 100
Last Login: 6/19/2013
Status: offline
Sounds like the battery. I wouldn't fly it in any of my planes. Any physical changes puffing,
loose connection at the balance.plug?
Hide Signatures
       Post #: 3
RE: 5 yr old LiPo battery charging issue - 12/13/2012 6:26 PM
opjose
Score: 284
Last Login: 6/20/2013
Status: offline
The voltage checker is probably not putting a load on the pack, so you are not getting anything meaningful back.
The better charges check the state of the packs and what happens under load, so I would put more trust in your charger.
It sounds like a cell went bad.
Don''t worry, be happy and fly something!
Hide Signatures
(in reply to allelectric)
       Post #: 4
RE: 5 yr old LiPo battery charging issue - 12/14/2012 1:10 AM
guver
Score: 174
Status: offline
It could be either of those things, my best guess is that your cell#1's balance wire has a bad connection where it's soldered to the cell tab. I think it HAS to pin 4 and not pin 3. Isn't pin 3 shared by two cells?
and airplanes were in
Hide Signatures
(in reply to opjose)
       Post #: 5
RE: 5 yr old LiPo battery charging issue - 12/14/2012 3:07 PM
MMatheny
Score: 100
Status: offline
No puffing - but that was Air Thunder's claim to fame for charging what they do! Guess a new battery is in order. Thanx for the inputs guys.
Mike
Hide Signatures
(in reply to guver)
       Post #: 6
RE: 5 yr old LiPo battery charging issue - 12/14/2012 3:08 PM
MMatheny
Score: 100
Status: offline
quote:
ORIGINAL: guver
I guess I could try wiggling the balance cable around just for grins.
Mike
Hide Signatures
(in reply to guver)
       Post #: 7
RE: 5 yr old LiPo battery charging issue - 12/14/2012 10:26 PM
guver
Score: 174
Status: offline
Yea, do it during the charge or discharge.
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
