"Hot Rod" Homelite 30cc    Gallery
Logged in as Guest
    Search This Thread
Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  4/28/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> "Hot Rod" Homelite 30cc
Page: [1]
Login
"Hot Rod" Homelite 30cc - 12/13/2012 7:14 PM
av8tor1977
Score: 665
Last Login: 6/19/2013
Status: offline
There is a really good Homelite 30cc in the marketplace with all the mods done to it.
AV8TOR
Click to see fullsize image.
Click for fullsize
_____________________________
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
       Post #: 1
RE: - 12/14/2012 11:37 PM
1QwkSport2.5r
Score: 155
Last Login: 6/20/2013
Status: online
I've tried searching for the mods to "hotrod" the homelite 30cc, but have come up a little short. What exactly are the "hotrod" mods? I want to run mine on gas/glow.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to av8tor1977)
       Post #: 2
RE: - 12/15/2012 1:18 AM  1 votes
av8tor1977
Score: 665
Status: offline
Hi,
Do a search here in the forum and you'll find lots of info. The things I do to hop them up are things I have learned from experience, and also from a lot of study on the web. The boat guys use the Homelites, and you can find a lot of info about them and modifications on the boating sites. There is just too much to do and explain for me to cover it here in the forum with a post. I cut the squish band out of the cylinder head, lower the cylinder, change all the port timings, stuff the crankcase, etc., etc. etc.... It's a lot of work and I normally never do them for sale because I could never charge for all the hours of work I get into them. But they do run great when all hopped up...
AV8TOR
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 3
RE: RE: - 12/15/2012 4:06 PM
1QwkSport2.5r
Score: 155
Status: online
quote:
ORIGINAL: av8tor1977
Hi,
AV8TOR
I will do some more searching. Thanks. I doubt I would use it on a plane as I really dont want to get into anything that large, but I'm not opposed to putting it in a boat. The engine has very little time on it, both rings aren't seated completely even.
Are all homelite 30cc engines equipped with a double ringed pistons? Mine is, and the rings are very narrow. About as narrow as a glow engine's piston ring. I think mine's from 1997 or thereabouts.
Hide Signatures
       Post #: 4
RE: - 12/21/2012 10:50 PM
av8tor1977
Score: 665
Status: offline
The narrow rings are good. Less friction and less ring flutter at high rpms.
You would be hard pressed to find a better deal than the one for sale in the market place. Even if you count your time at a buck an hour you would come out ahead. Just the custom two needle Walbro carb, the ignition sensor, the Twister Manifold, and the prop hub cost close to 100 bucks..... The whole engine with all the mods is only 150 as advertised....
AV8TOR
Hide Signatures
       Post #: 5
RE: RE: - 12/23/2012 5:29 PM
1QwkSport2.5r
Score: 155
Status: online
AV8TOR
Don't want all the extra stuff. No spark ignition for me. Besides, $150 is a lot more than I want to spend on an experiment.
The boat guys chewed my tail for even asking about modifying a homelite. Waste of time they say. I disagree as he knowledge gained is worth the time to mess with it. Though I am taking on a build for another forum member that will put the homelite on the shelf for awhile anyway.
Hide Signatures
       Post #: 6
RE: RE: - 12/23/2012 5:40 PM
av8tor1977
Score: 665
Status: offline
Well, for me it is hardly an "experiment". I've been flying these engines for years with zero failures. Swinging an APC 16 x 8 at 9400 rpms is some really decent power as well. Both of the planes shown have Homelite 30's in them, and both would go vertical out of sight. I lost the Christen Eagle due to a dumb thumb mistake, but I've had the Giles for 4 years and it flies super with it's Homelite 30cc.
AV8TOR
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 7
RE: RE: - 12/23/2012 9:34 PM
1QwkSport2.5r
Score: 155
Status: online
Well, for me it is hardly an ''experiment''. I've been flying these engines for years with zero failures. Swinging an APC 16 x 8 at 9400 rpms is some really decent power as well. Both of the planes shown have Homelite 30's in them, and both would go vertical out of sight. I lost the Christen Eagle due to a dumb thumb mistake, but I've had the Giles for 4 years and it flies super with it's Homelite 30cc.
AV8TOR
I am calling my engine conversion an experiment because I do not want to fly giant scale. If I get the engine performing well, I'll most likely put it on my big 18"x32" airboat. It runs real nice with an ST .90, I can only imagine what it would do with 30cc at 9,000+ rpm.
There is a possibility I may just put the engine on the shelf too. I'm not sure yet.
Hide Signatures
       Post #: 8
RE: RE: - 12/26/2012 12:12 AM
Altered1
Score: 106
Status: offline
quote:
ORIGINAL: 1QwkSport2.5r
AV8TOR
I think you will be surprised with the output.  My bodyboard hull (40x22), 25cc homie, swinging a 18x8 will barely stay put on the grass at idle.  Its a step up for sure!   The wife appreciates the quieter muffler
Hide Signatures
       Post #: 9
RE: RE: - 12/26/2012 4:48 PM
1QwkSport2.5r
Score: 155
Status: online
I won't run a prop that big, i was going to do a high pitch pattern prop. Maybe a 13x12 or 14x14. I'd want to prop it for 11,500rpm peak.
Before the pilots get cranky with my rpm figure, the engine would never unload since it wouldn't be airborne. That and I don't care a whole lot about the engine; I did pull it from a dumpster after all.
I figure it would be pretty light running without a flywheel and ignition system.
On a side note; my wife isn't fond of the noise much, I usually break engines in away from the house or wait until she isn't home.
Hide Signatures
(in reply to Altered1)
       Post #: 10
RE: RE: - 3/6/2013 6:29 PM
Twin Star
Score: 100
Last Login: 3/7/2013
Status: offline
I got a NOS Homelite 30 cyl and piston assembly awhile back. It has the small cooling fins an a small combustion chamber with good port timing. It does however have what appears to be a de-compressor port above the Ex. port.
What is a good and easy technique to plug that port.
No engine parts were deliberately harmed in this process.
Hide Signatures
       Post #: 11
RE: RE: - 3/6/2013 6:52 PM
av8tor1977
Score: 665
Status: offline
Tap it and put a small allen set screw/plug in it. (Use Loctite) That's the way I do all mine. I don't think I would trust just stuffing JB Weld in it because of the heat, fuel, pressure etc.
If I remember right, the hole is already the right size for the tap so you don't even have to drill it, but I can't remember the size. 8-32?
I don't believe it is a compression release however. None of us are sure, but I think it is kind of an Exhaust Gas Recirculation port for smog purposes.
AV8TOR
Hide Signatures
(in reply to Twin Star)
       Post #: 12
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> "Hot Rod" Homelite 30cc
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
