to sub c or AA batterys    Gallery
Logged in as Guest
    Search This Thread
Printable Version
S&W 2-6S LCD Battery Capacity & Checker ***FREE SHIPPING US ONLY*****
Seller:  swgiantscalemodels
Details:   $19.89   |  4/2/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> to sub c or AA batterys
Page: [1]
Login
to sub c or AA batterys - 12/13/2012 11:14 PM
handyman
Score: 111
Last Login: 3/28/2013
Status: offline
thinking about useing sub c batterys for rec (6v) and 4 cell for eng..is there a advanage to using the sub Cs over AA..........i have the room and the weight is no problem
Hide Signatures
       Post #: 1
RE: to sub c or AA batterys - 12/13/2012 11:25 PM
flyinwalenda
Score: 157
Last Login: 5/25/2013
Status: offline
If I could find sub C NiCads at a decent price I would use those. They are out there but rather expensive anymore.  I am done buying NiMh's and am converting dying or dead packs to lipos until my regulator supply runs out and then to Life' packs.  I always liked sub C packs and they pack a good punch but as you said at the sake of some extra weight.
_____________________________
Brian Ray
Hide Signatures
(in reply to handyman)
       Post #: 2
RE: to sub c or AA batterys - 12/14/2012 12:54 AM
heinzulrich
Score: 105
Last Login: 5/15/2013
Status: offline
Heck, I use sub "C" for my receivers ans "D" for my servos, both are 6v in same aircraft. Mind you I fly Hugh aircraft . I personally don't like using lipo batteriesI don't feel comfortable using them, seen to many burn.
Hide Signatures
(in reply to flyinwalenda)
       Post #: 3
RE: to sub c or AA batterys - 12/14/2012 10:57 AM
Tony Hallo
Score: 141
Status: offline
quote:
ORIGINAL: flyinwalenda
Batteries America has 1800 ma Sub C packs 4.8 Volt at $18.  What do you consider expensive?  I have always found the NiCads the least expensive.
Tony Hallo
Hide Signatures
       Post #: 4
RE: to sub c or AA batterys - 12/14/2012 4:02 PM
scale only 4 me
Score: 319
Status: offline
quote:
ORIGINAL: handyman
Well, If weight isn't an issue you can get them in up to 4200mah cells I think, AA size nimh top out at 2500mah
Both work great in most cases.
Hide Signatures
       Post #: 5
RE: to sub c or AA batterys - 1/14/2013 4:00 PM
DaveFri
Score: 100
Status: offline
AA's won't have the capacity that a sub-c will have.If you are using many servo's or big servo's or servos with high current drain...the AA will run out quicker than sub-c. I used to use only ni-cd but i have changed over to ni-mh and 6v for receiver packs. Depending on size of plane and servo's used i'll use either A size or sub- c size cells. No more AA size packs for receivers for me.
        Dave
Hide Signatures
(in reply to scale only 4 me)
       Post #: 6
RE: to sub c or AA batterys - 1/14/2013 4:42 PM
83scamp
Score: 100
Last Login: 3/4/2013
Status: offline
On a large scale plane, I would go sub-C or even C.  The AA have much higher internal resistance to ge the capacity up.  If your flying a plane with high drain servos, the pack can fade quickly.  Horizon has Venom 6V packs really reasonable, and they include both a standard RX connector, and a Tamiya connector for quick charging.  The 3000 mah pack is only $20.99.  http://www.horizonhobby.com/products/6v-3000mah-nimh-large-scale-receiver-battery-VNR1502  of course, they are on back order right now.  I just received one, and am eagerly awaiting the second one.  Seems to be a well constructed pack.  Should handle anything I throw at it.  Of course, I'm not doing any giant scale 3D, at least not yet....
Hide Signatures
(in reply to DaveFri)
       Post #: 7
RE: to sub c or AA batterys - 1/14/2013 4:49 PM
DaveFri
Score: 100
Status: offline
woiw,thats a great price....need to try one myself!!
Hide Signatures
(in reply to 83scamp)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
