Kavan MKI to gas    Gallery
Logged in as Guest
    Search This Thread
Printable Version
O.S. Engines O.S. FT-300 Twin
Seller:  thunderbolt-RCU
Details:   $600.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> Kavan MKI to gas
Page: [1]
Login
Kavan MKI to gas - 12/14/2012 7:07 PM
Maximiliano Galvez
Score: 105
Last Login: 5/8/2013
Status: offline
I have aKavan MKI to convert This engine is of my Friend Abdul . Is an interesting engine because it has oiling system inside
Hope works nice I began conversion tooday Will upload pics
Max
_____________________________
Special Tuned Engines (STengines)
Hide Signatures
       Post #: 1
RE: Kavan MKI to gas - 12/14/2012 8:38 PM
captinjohn
Score: 247
Last Login: 5/25/2013
Status: offline
I would convert it to ignition and still use a very small amout of oil in the fuel.  If you use a glow type carb you can use a mix with alky.  If you install a walbro carb, you can use gas...but they recomend a small amout of oil in the fuel even though it has its own oil supply.   Capt,n
I never met a engine I did not like !
Hide Signatures
(in reply to Maximiliano Galvez)
       Post #: 2
RE: Kavan MKI to gas - 12/15/2012 12:34 AM  1 votes
tkg
Score: 657
Status: offline
Oil in the sump, 2% oil in fuel for the valves.
2 or 3 types of carbs, ranging from poor to junk.
TKG
Too much power is just about right.
Hide Signatures
(in reply to captinjohn)
       Post #: 3
RE: Kavan MKI to gas - 12/15/2012 12:48 AM
Maximiliano Galvez
Score: 105
Status: offline
dear Capt John
yes Ill use a walbro this is a beaitfull 50cc twuin 4 strokes engine
My best regards
max
Hide Signatures
       Post #: 4
RE: Kavan MKI to gas - 12/15/2012 12:50 AM
Maximiliano Galvez
Score: 105
Status: offline
quote:
ORIGINAL: tkg
What kind of oil?? Ill use 5w30 4 strokes car syntetic oil
Hide Signatures
(in reply to tkg)
       Post #: 5
RE: Kavan MKI to gas - 12/15/2012 1:18 AM
captinjohn
Score: 247
Status: offline
I would & do use the same oil I place in the oil sump. If I use Klotz in the sump...then its Klotz in fuel.  If I use Mobile 1 in the sump...then I add Mobile 1in fuel.  I change the oil about every 4th run.   This engine will run with  only 1 degree difference in temp from one cyl too the other.  Made In Germany.  Go to   http://www.mecoa.com/kavan/index.htm for more data.
Capt,n
Click to see fullsize image.
Click for fullsize
< Message edited by captinjohn -- 12/15/2012 7:21 PM >
Hide Signatures
       Post #: 6
RE: Kavan MKI to gas - 12/15/2012 3:55 PM  1 votes
tkg
Score: 657
Status: offline
Parts and some info
http://www.mecoa.com/index.htm
TKG
TKG
Hide Signatures
       Post #: 7
RE: Kavan MKI to gas - 12/19/2012 3:30 AM
Maximiliano Galvez
Score: 105
Status: offline
I see thath will need to change engine mount suport in other way because I need some space for the walbro.
I see carb suport was not well tightened, i decided to unassamble some part to fit itcorrectly
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to tkg)
       Post #: 8
RE: Kavan MKI to gas - 12/19/2012 3:34 AM
Maximiliano Galvez
Score: 105
Status: offline
Finally carb support is ready i will use a Tillotson that for me is too much fine tah walbro.
IS our four strokes design ste modification with special STE valvle
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 9
RE: Kavan MKI to gas - 12/19/2012 3:04 PM
captinjohn
Score: 247
Status: offline
Looking good so far. Keep up the good work.  Just looked at my Kavan. It seems like the 2 upper mounts could be spaced out a little each way with a fill in adapter...then there would be room for a regular pumper carb.  I just may do that to my Kavan.   Capt,n
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 10
RE: Kavan MKI to gas - 12/22/2012 5:25 AM
Maximiliano Galvez
Score: 105
Status: offline
quote:
ORIGINAL: captinjohn
I solved with 2 separators and a high resitant allen 8-32
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 11
RE: Kavan MKI to gas - 12/22/2012 6:02 PM
captinjohn
Score: 247
Status: offline
Max, looks like a good job in the photos. Is there a rubber spacer in there yet?   I may want to get the Dimentions of the parts you made.  Thanks   Capt,n
Hide Signatures
       Post #: 12
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> Kavan MKI to gas
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.313RCU1
