Prop from transom distance    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - Electric >> Prop from transom distance
Page: [1]
Login
Prop from transom distance - 12/15/2012 1:44 AM
Johnwhite84
Last Login: 12/18/2012
Status: offline
Ok guys got a fairly simple one. I'm scratch building a very small 16in hull length mono hull. I do not have a strut mounted just the stuffing tube exiting the transom. My plans are to go as fast as the hull will allow. As a very rough starting point I currently have it mounted to the tip of the stuffing tube to the transum just shy of 2 inches or 12% of the length of the hull. Curious how short or long I should go.
Thank guys
Hide Signatures
       Post #: 1
RE: Prop from transom distance - 12/15/2012 1:58 AM
Mikeup
Last Login: 5/13/2013
Status: offline
I deleted as i didn't want to give bad advise but i really didn't give you bad advise. My lenght works perfect for my boats, but i use shorter turn fins and no trim tabs and longer  struts . I also have motors placed where i need them and al l works out. I'm retired and i've become very addicted to perfection on performance of such. Paul 785 is a GURU and i respect him for it. Sorry!  _____Forgot, i run full strakes on all my boats and that works in conjunction with 3" struts  with 2 degree down or neg. angle.
< Message edited by Mikeup -- 12/17/2012 3:16 PM >
Hide Signatures
(in reply to Johnwhite84)
       Post #: 2
RE: Prop from transom distance - 12/15/2012 2:19 AM
Johnwhite84
Status: offline
This started out as my rescue boat for my nitros but of course speed got the best of me. Has 2900kv brushless turnigy 28-45. Tested it with 3s lipo and only pulled 270W 26A with x434. leopard water jacket. turnigy marine 60A esc. .98 drive. Have 5 props to test. 430,431,434,437 and a 632.
2 1/2 inches just seems rather long to stick out from the transom on such a short hull. Is that 2 1/2 from transom to tip of drive shaft or from transom to drive dog ?
Hide Signatures
(in reply to Mikeup)
       Post #: 3
RE: Prop from transom distance - 12/15/2012 9:01 AM
martno1fan
Last Login: 5/18/2013
Status: online
You should be fine at 2".
Mart
_____________________________
waveridermouldings
Hide Signatures
       Post #: 4
RE: Prop from transom distance - 12/16/2012 9:56 AM
785boats
Status: offline
John.
The general rule of thumb is 10% of the hull length from transom to face of the prop. 1.5" - 1.75" should be ideal for a 16" hull.
If the prop is too far away from the transom the hull tends to skip a bit in the corners at full noise & become unsettled.
I've not built a hull as small as 16" but I have two identical Delta Force 25" racing hulls. One of them is set at 2" (strut) & the other is at 2.5" (stinger).
The shorter strut actually handles better than the one with the longer stinger. Even though 2.5" is 10% of the 25" hull.
I'm going to replace the stinger with a shorter strut for next years racing.
Even with some of my larger 33" & 36" hulls the ones with the strut/stinger length slightly shorter than 10% seem to be a bit more stable in the corners.
Hope this helps a bit.
Paul.
Hide Signatures
(in reply to martno1fan)
       Post #: 5
RE: Prop from transom distance - 12/16/2012 2:43 PM
Johnwhite84
Status: offline
That helps a lot! This is not a race boat so getting it 100% dialed in are not my intentions. I will shorten it up to around 10% and if she performs then that's where I'll stay. If she dosnt feel quite right ill shorten her up just a bit more. My previous measurement was tip of the stuffing tube to transom. Now I know where to measure from. Tanks for the help!
Hide Signatures
(in reply to 785boats)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.484RCU1
