Balance plug question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> Balance plug question
Page: [1]
Login
Balance plug question - 12/15/2012 3:26 AM
NIpilot
Score: 100
Last Login: 5/7/2013
Status: offline
Tota newbie to electric. Purchases a Hyperion EOS6061i charger at the swap. Came with three balance boards but nothing my Life 2100mah 6.6V batteries will plug into. The battery balance plug has only 3 pins and non of the boards have only thee pins. Four or more. What to do?
Hide Signatures
       Post #: 1
RE: Balance plug question - 12/15/2012 3:57 AM
rem0.061
Score: 102
Last Login: 5/15/2013
Status: offline
Does the charger itself have a 3 pin balance plug on it? You might have to just go without balance charging it until you can find a board with 3 pins.
Hide Signatures
(in reply to NIpilot)
       Post #: 2
RE: Balance plug question - 12/15/2012 1:07 PM
guver
Score: 174
Last Login: 5/16/2013
Status: offline
Your Hyp charger probably came with HYP balance board and 2-4s use the same white plastic housing. You will need to get the right board OR change your battery over to Hyp tap. It's hard to tell without seeing it or knowing the brand of battery , but my guess is that you need XH.
http://www.rcuniverse.com/forum/m_9108084/anchors_9108084/mpage_1/key_/anchor/tm.htm#9108084
_____________________________
and airplanes were in
Hide Signatures
(in reply to rem0.061)
       Post #: 3
RE: Balance plug question - 12/15/2012 4:43 PM
NIpilot
Score: 100
Status: offline
Yeah, I bought this Hyperion charger and it came with these boards. One is marked hyperion and has inputs for 2,3,4,5 and 5 cell
The fewest pins are 4 even on the two cell location.
Same with other board that says thunderpower, flight power on it. Still no 3 pin inputs.
My batteries I just purchased are the LiFe brand from Hobbico. They have a 3 pin balance plug thats slightly different than any of the options I have on these boards.
Guess I will try calling Hyperion service? Thanks
Hide Signatures
       Post #: 4
RE: Balance plug question - 12/15/2012 6:56 PM
guver
Score: 174
Status: offline
The TP should have 3 and 4 pin plugs , but they are different pin spacing anyways and a different latch. Your Hobbico Batts use XH style taps. They are the most popular.
Hide Signatures
       Post #: 5
RE: Balance plug question - 12/17/2012 2:24 PM
NIpilot
Score: 100
Status: offline
Your right and I have an XH board coming. Thanks all.
Hide Signatures
(in reply to guver)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
