1 ESC for multipul motors    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> E-Flight Power Sources >> 1 ESC for multipul motors
Page: [1]
Login
1 ESC for multipul motors - 12/15/2012 3:45 AM
rem0.061
Score: 102
Last Login: 5/21/2013
Status: offline
Why do people always use two ESCs on their twin engine airplanes, when it could be simpler and easier to setup just one? Is it because most people are not sure that this is possible, or is there a different reason such as efficiency or flight time?
Hide Signatures
       Post #: 1
RE: 1 ESC for multipul motors - 12/15/2012 3:23 PM
rem0.061
Score: 102
Status: offline
I test ran two motors on one ESC at the same time with no load and it worked, but would it be safe with a load?
Hide Signatures
(in reply to rem0.061)
       Post #: 2
RE: 1 ESC for multipul motors - 12/15/2012 4:56 PM
Gohmer
Score: 112
Status: offline
It works fine with brushed motors. I've made it work with brushless, but it's not worth it. ESC for each brushless motor works better for me. Seperate battery, esc and receiver for each motor is my favorite.
Hide Signatures
       Post #: 3
RE: 1 ESC for multipul motors - 12/15/2012 4:57 PM
JohnShe
Score: 107
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: rem0.061
What about the load factor?  If one motor draws 50A at full throttle, then you would need, at least, a 100A ESC for two motors.
Hide Signatures
       Post #: 4
RE: 1 ESC for multipul motors - 12/15/2012 7:15 PM
rem0.061
Score: 102
Status: offline
Does the ESC adjust it's timing according to what the motor is doing, because if it does two motors could confuse the ESC. I think, depending on where you get it, one big ESC is cheaper than two smaller ones.
Hide Signatures
(in reply to JohnShe)
       Post #: 5
RE: 1 ESC for multipul motors - 12/16/2012 8:01 AM
jdetray
Score: 115
Last Login: 5/20/2013
Status: offline
This question has been discussed many, many times in this and other forums. Some searching might discover those earlier threads.
The bottom line is that using one ESC for two brushless motors sometimes works. More often than not it doesn't. Sometimes only one motor will start reliably, or at all. The stalled motor may draw a large amount of current and damage itself or other components.
So unless you get real lucky, two ESCs will be required.
There was once a twin motor brushless package from Kontronik called the Kontronik Twin Drive, which matched two motors with one ESC. It was expensive = $300+ for the set. I never knew anybody who owned one, but apparently it worked. It is no longer listed on the Kontronik web site.
- Jeff
_____________________________
My other hobby: www.AstronomyBoy.com
Hide Signatures
       Post #: 6
RE: 1 ESC for multipul motors - 1/26/2013 11:12 PM
Dr Kiwi
Score: 120
Status: offline
As Jeff has noted.. the start-up can be dodgy. Some years ago, I tested several pairs of small motors using Castle, Scorpion, FMA, and Motrolfly ESCs... some were better than others, but none gave consistent starting for both motors, and even if they did run, not equal RPM.
Dr Phil Millener, Chattanooga, TN
Hide Signatures
(in reply to jdetray)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.234RCU1
