Quarterscale ProMod Rear-End    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> Quarterscale ProMod Rear-End
Page: [1]
Login
Quarterscale ProMod Rear-End - 12/15/2012 8:15 PM
QSPSB2
Score: 104
Last Login: 6/19/2013
Status: offline
Starting the machining process on the promod type rearend for the beretta & other! http://www.youtube.com/watch?list=PL9809C018150B54A6&v=NC8Ba7ZVDUQ&feature=player_detailpage
_____________________________
http://quarterscaleprostreetberetta.freeforums.org/index.php
Hide Signatures
       Post #: 1
RE: Quarterscale ProMod Rear-End - 12/25/2012 9:01 PM
QSPSB2
Score: 104
Status: offline
I now have 2 of 3 profiling operations completed.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to QSPSB2)
       Post #: 2
RE: Quarterscale ProMod Rear-End - 12/30/2012 2:51 PM
QSPSB2
Score: 104
Status: offline
I now have the profiling operations completed
And I'm now machining the axle path!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3
RE: Quarterscale ProMod Rear-End - 1/2/2013 11:12 PM
QSPSB2
Score: 104
Status: offline
Axle path is now done and I'm currently machining the gear path @ 2.325 x 1.485 @ 65 IPM
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4
RE: Quarterscale ProMod Rear-End - 1/3/2013 12:14 AM
mooman007uk
Score: 105
Status: offline
starting to take shape nicely. you running a diff or spool?
Bringing hurrax to N.America & beyond.
hurraxracing.com
Hide Signatures
       Post #: 5
RE: Quarterscale ProMod Rear-End - 1/3/2013 12:21 PM
Mudgy
Score: 100
Last Login: 6/20/2013
Status: online
Looking good mate... didn't you have a sheet metal diff case before?
Hide Signatures
(in reply to mooman007uk)
       Post #: 6
RE: Quarterscale ProMod Rear-End - 1/3/2013 10:27 PM
QSPSB2
Score: 104
Status: offline
Thanks guys. I'm going with a spool for this one. I may eventually machine an actuall diff..
Yeah mudgy I did make a sheet metal one a few years ago.. It was made from 1/8" steel and weighed a ton and wasn't precise at all.. This one is very precise I have about 0.0003 tolerance and that's just because I got about 0.0001 backlash on X&Y I got backlash compensate dialed in in mach3 but I'm still out 0.0001 no biggie..
Hide Signatures
(in reply to Mudgy)
       Post #: 7
RE: Quarterscale ProMod Rear-End - 1/5/2013 9:15 PM
QSPSB2
Score: 104
Status: offline
The gear cut path is now complete, the spotting/drilling operation to secure the faceplate to follow!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: Quarterscale ProMod Rear-End - 1/5/2013 9:28 PM
stiggwelder
Score: 100
Last Login: 6/7/2013
Status: offline
hi mate, liking the start of the rear end, should be good and scale looking when done, i read you built a sheet diff, this is my current effort , some where to start from, it runs a mcd diff unit
long boxed trailing arms and a multishox set up for my trophy truck build
Hide Signatures
       Post #: 9
RE: Quarterscale ProMod Rear-End - 1/6/2013 5:17 PM  1 votes
QSPSB2
Score: 104
Status: offline
Thanks.. Yeah this fabricated Rearend should make the Beretta look like its all business from the rear view.. That one you built looks pretty cool man.. The other one I built wasn't actually made from thin sheet metal. It was built from 1/8" steel,, I attached a few pics of both..
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to stiggwelder)
       Post #: 10
RE: Quarterscale ProMod Rear-End - 1/6/2013 7:34 PM
stiggwelder
Score: 100
Status: offline
hi , the steel one looks tuff, mine was made out of 2mm sheet cut and tacked on a jig, runs pretty true but weighs a ton
Hide Signatures
       Post #: 11
RE: Quarterscale ProMod Rear-End - 1/27/2013 10:44 PM
QSPSB2
Score: 104
Status: offline
I recently purchased some decent shocks for the Beretta. The shorter ones which I'll use on the rear are
Ready to be bolted on.. Once I get the Rearend done. The longer ones I'll use as struts on the front, I'm going to
Remove the lower spring and machine a sleeve that will secure the spindle and brake caliper mounting bracket.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 12
RE: Quarterscale ProMod Rear-End - 6/19/2013 11:41 PM
QSPSB2
Score: 104
Status: offline
Hey all, it's been a bit since my last post. Well I recently replaced the Z-axis thrush bearing on the mill and have yet had the time to drill/tap the timing pully mount. Will be here soon. However. I do now have the majority of the beretta components and all the electronics. Picked up a turnigy 9XR radio, 4-1/4 scale steel geared servos, fail safe, RX module, battery's & chargers. Lights. 4 wheel hydraulic disc brakes. With two master cylinders. One for the front, which will lock up the fronts for burnouts. And one for the rears. The primary brake.im currently re-designing the front upper strut mounts and struts.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 13
RE: Quarterscale ProMod Rear-End - 6/19/2013 11:42 PM
QSPSB2
Score: 104
Status: offline
Zip!
Click for fullsize
Hide Signatures
       Post #: 14
RE: Quarterscale ProMod Rear-End - 6/20/2013 12:54 AM
CEN USA
Score: 100
Status: offline
Very nice! I am becoming more and more infatuated with these large scale projects. I am particularly interested in the metal beretta body. Do you have thread on the construction of that?
US Sales Dept
1-626-537-9004
Hide Signatures
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.250RCU1
