Need some help with new to me setup    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Lanier Taylorcraft (1/4) - ARC
Seller:  p38nut
Details:   $250.00   |  6/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> Need some help with new to me setup
Page: [1]
Login
Need some help with new to me setup - 12/15/2012 9:53 PM
luckymacy
Score: 100
Last Login: 6/19/2013
Status: offline
How do I troubleshoot an electric plane when I don't have any parts to swap out? I bought a used Sebart Wind 110 I which supposedly has new Hacker A50-16L V2 (it does look shiny new and 'spotless') and the same props, ESC and battery packs that the plane supposedly flew with in copetitions. In other words, it should have been a perfectly working set already installed.
I took it out for a fist flight (for me) today. I had a amp meter installed and was doing a ground check. I do not have any experience with setups this large (8s) so was proceeding extra cautiouslessy. Anytime on the ground I got near 30 amps the motor made a screetch sound and shut down. I removed the back support plate as I was suspicious it was causing some drag/binding but it made no differenc. In my smaller electric planes that's usually been due to overspeeding or not enough load on the motor (ie, the sound doesn't happen when actually flying, it only happens on the ground). I am hoping that the motor won't make that sound and fly fine but I won't risk flying it until I know for sure. Any ideas on how to troubleshoot or verify the setup is fine?
_____________________________
lucky macy
Hide Signatures
       Post #: 1
RE: Need some help with new to me setup - 12/16/2012 10:09 PM
cubaneight
Score: 101
Last Login: 6/15/2013
Status: offline
Reckon the timing is set incorrectly. Try setting to auto or high on the ESC. Having the motor grossly over-propped will also give the problem, but as you are still using the original prop, then check that you haven't altered the timing by mistake when you set the ESC to your tranny.
http://www.hobbyking.com/hobbyking/forum/forum_posts.asp?TID=3627 This is typical of the problem.
Hide Signatures
(in reply to luckymacy)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.125RCU1
