RE: Volcano epx pro Running problem    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Volcano epx pro Running problem
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Volcano epx pro Running problem - 12/18/2012 2:15 PM
Leonardo1982
Score: 100
Last Login: 4/23/2013
Status: offline
 Thank you very much for your help. so if i find somthing on your store ill ask you.. you are really  helpfull person ty for all..
Hide Signatures
(in reply to Leonardo1982)
       Post #: 26
RE: Volcano epx pro Running problem - 12/18/2012 8:45 PM
nitrosportsandrunner
Score: 296
Last Login: 5/20/2013
Status: online
no problem.
another ESC you could look for is the team associated sc450
Ive seen them used on ebay for as little as $45
_____________________________
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
       Post #: 27
RE: Volcano epx pro Running problem - 12/18/2012 9:41 PM
Leonardo1982
Score: 100
Status: offline
I did what you said . I filled the form of warranty in RedCat .and they send me a message that say it will replace with a new ESC.. So i have to thank you for that because you informed  me..
SO THAK YOU VERY VERY MUCH!!!!!
Hide Signatures
       Post #: 28
RE: Volcano epx pro Running problem - 12/20/2012 2:03 AM
Leonardo1982
Score: 100
Status: offline
 hi again.. so i have a question, im looking for a aluminium chassis for volcano EPX  i find something can u tell me if i can use this  on volcano?
http://www.helipal.com/airy-aluminium-cnc-chassis-for-hsp-cars-hsp-111001t.html
Hide Signatures
       Post #: 29
RE: Volcano epx pro Running problem - 12/20/2012 9:59 PM
Score: 296
Status: online
quote:
ORIGINAL: Leonardo1982
no problem.
redcat has some models which other brands sell as well (just rebranded) but in my experience redcat has the better customer service and warrenty. Many other rc companies would want you to ship the bad esc to them, which means cost on your part and a longer time till you get your replacement.
The ESC in the volcano's are reliable, I have had many of them. Not just in redcat models, but in other as well. I have never seen one without that rubber cover. That was a defect and the reason yours failed.
I tried that link but it didnt work.
but to my knowledge, there is no alloy chassis that will work on the volcano.
Hide Signatures
       Post #: 30
RE: Volcano epx pro Running problem - 12/20/2012 10:12 PM
Leonardo1982
Score: 100
Status: offline
thank you very much PRO!!!
Hide Signatures
       Post #: 31
RE: Volcano epx pro Running problem - 12/22/2012 7:00 AM
scott63b
Score: 100
Last Login: 1/12/2013
Status: offline
i had this same issue. i swapped out the battery for a LiPo and it screems now. change battery. thats what i would do.. thes stock battery just isnt enough for the speed controler system.
they should just put LiPo in it from the get go.
that my point of view..
Hide Signatures
       Post #: 32
RE: Volcano epx pro Running problem - 12/22/2012 3:38 PM
Leonardo1982
Score: 100
Status: offline
 Thank you Scott ive ordered already the LIPO. Maybe that's  the reason (the battery) ty again..
Hide Signatures
       Post #: 33
RE: Volcano epx pro Running problem - 12/22/2012 8:06 PM
Leonardo1982
Score: 100
Status: offline
Hi PRO..  a friend gave me a Spektrum DX3E but  only the transmitter without a reciever!! can i uce the spectrum trasmitter with  redcat stock reciever?
Hide Signatures
       Post #: 34
RE: Volcano epx pro Running problem - 12/22/2012 10:04 PM
Score: 296
Status: online
well, it wont hurt to try and bind that radio to the stock reciever....but I highly doubt it uses the same spectrum. There are a few different types of 2.4ghz systems on the market. Some brands will work with others but most often they dont mix.
Still, he gave you a radio worth $30-$40. Good friend!
Hide Signatures
       Post #: 35
RE: Volcano epx pro Running problem - 12/22/2012 10:18 PM
Leonardo1982
Score: 100
Status: offline
ohh i like so much looks pretty good.. is much better  of redcat stock transmitter.. but i found a new DX2E for only 60$ on ebay...  which of these two is better- Spektrum DX2E or Traxxas TQi???
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 36
RE: Volcano epx pro Running problem - 12/31/2012 8:04 PM
jroptop
Score: 100
Last Login: 3/10/2013
Status: offline
I just purchased one of these and installed it but the steering horn wont fit over the brass wheel,am I missing something?
Hide Signatures
       Post #: 37
RE: Volcano epx pro Running problem - 12/31/2012 8:38 PM
Score: 296
Status: online
quote:
ORIGINAL: jroptop
not all servos have the same "thread" on the brass wheel. The servo should have come with a couple of servo horns tho. You will have to use one of them. You may have to take the ball off the stock servo horn and put it onto the new one.
Which servo did you get?
Hide Signatures
(in reply to jroptop)
       Post #: 38
RE: Volcano epx pro Running problem - 1/1/2013 1:35 PM
jroptop
Score: 100
Status: offline
Ended up getting a hexfly 15kg.I had to alter one of the star looking horns to make it work,but the horn position is different that the stock one as it hits the battery storage case when fully turning in one direction.
quote:
ORIGINAL: nitrosportsandrunner
quote:
ORIGINAL: jroptop
Hide Signatures
       Post #: 39
RE: Volcano epx pro Running problem - 1/10/2013 3:38 PM
Leonardo1982
Score: 100
Status: offline
 Hello.. i baught  a set of aluminium STEERING HUB for volcano epx pro but  something  is wrong  when i put on the weels  when weel  it lock ..  maybe the aluminium is thiken.. can somebody tell me what to do? ty
Hide Signatures
       Post #: 40
RE: Volcano epx pro Running problem - 1/11/2013 4:59 AM
Johnathond22
Score: 100
Last Login: 5/16/2013
Status: offline
 I recently upgraded to all aluminum epx pro. If you have the aluminum hubs and are using the stock plastic hex it will bind against the new aluminum hub. You will need to loosen the lock nut on the wheel to allow the hex to spin freely. I suggest you get the aluminum hex as these work perfectly with the aluminum hubs. You can tighten all the way.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 41
RE: Volcano epx pro Running problem - 1/11/2013 4:58 PM
Leonardo1982
Score: 100
Status: offline
hey Johnathond, i have problem vith a dogbones what dogbones are you use there bro? ty
Hide Signatures
(in reply to Johnathond22)
       Post #: 42
RE: Volcano epx pro Running problem - 1/11/2013 6:47 PM
Johnathond22
Score: 100
Status: offline
I had tried to use the upgraded cv axles from Redcat but it didnt work any better, they actually broke really quickly when running lipos. The best I can get is stock dogbones and adjust your camber on the wheels so that the top of the wheels stay away from the truck just a little. There was another tip from Nitro that you can put a small piece of fuel hose from a nitro rc in the c cup on the differential to keep the dog bone securley in the wheel hub, this may also help. I personally have not tried this yet. I did also notice that setting the shock height about half inch off of it's softest setting helps keep the dogbones at a prefered angle with camber setting I suggested earlier. You should also check the fluid in the shocks, they come from redcat without being completely full. I changed my fluid to 70 wt and it really has been performing well. I have not broken a Dogbone yet and I run 50c Lipos. I included two quick phontos from mine to show the camber and I also built my own aluminum skid plate and bumper combo which I made to take the hard ground lick while jumping to avoid over extending the a-arms. This was my biggest problem in breaking dogbones. You should also consider setting your steering limiter to less angle when running full power, any hard angle will put extreme pressue and this drive train and with Lipo will certainly snap that lil shaft.  Let me know if I can help with anything else.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 43
RE: Volcano epx pro Running problem - 1/11/2013 7:31 PM
Score: 296
Status: online
that rear angle shot is a perfect example Johnathond22 of how Id setup the suspension. Not only will that angle keep the dogbones from snapping to easy, it will also make the truck more stable.
Yes, it will lesson the ground clearance, but Id rather have a rock hit the chassis every now and then...then snap dogbones or be always rolling the truck over.
Hide Signatures
       Post #: 44
RE: Volcano epx pro Running problem - 1/11/2013 8:17 PM
Leonardo1982
Score: 100
Status: offline
i like your chassis good job.. So what do you think about the universal AXLE?  does it  work on volcano?
Hide Signatures
       Post #: 45
RE: Volcano epx pro Running problem - 1/11/2013 8:47 PM
Johnathond22
Score: 100
Status: offline
Yes, my truck in the photos is my Volcano EPX pro. However the universal upgrade is a bit more expensive and alot more work to replace. I really think it is better to run the dogbones and make these changes to the suspension. You should notice a great improvement in dogbones lasting much longer. If I had to guess you are twisting off the end ball of the dogbone and this is due to stress in the wheel hub. The slight angle on the camber will certainly help this. Also consider lowering the shocks so that your dogbone is almost paralell to the differential. It may not look as cool being lower, but when running full speed it will take alot more turns and beatings. The only other suggestion I can make is if you are doing a good bit of jumping you will want to set the auto brake to minimal so that it can free roll after the jump. I had mine set failrly tight when I first got it and the sudden stop was also causing the axles to bind up and bend. I posted my Volcano as it was when I first got it. I had originally only made the bumper, but as you can see in the second pic I have been having a good time with the modding fun. The weather here has been really rainy so modding is all we can do. We have been making custom parts for a while and my next post will be extreme waterproofing and I will most likley make another skid to match the hummer a little better. I also need to make one for Nitro so this weekend will be dedicated to Modding, at least thats what the weather man says...rain all weekend.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 46
RE: Volcano epx pro Running problem - 1/11/2013 9:10 PM
Johnathond22
Score: 100
Status: offline
 Nitro,
If I remember correclty the skid plate you wanted was for the Tornado version Epx. Can you post a couple of fairly colse up photos so I can get an idea of where to make the bends. I will trace my epx chassis as it is the same but, I need a couple of photos of front, rear, side and bottom view. Do you want battery vent cutouts?  I will also need you to PM me the address of where it is going. It should be ready this weekend. Also need to know if Rhino black is ok for color or you rather something else.
Hide Signatures
       Post #: 47
RE: Volcano epx pro Running problem - 1/11/2013 9:34 PM
Leonardo1982
Score: 100
Status: offline
 thank you very much for your help.. i'm  gonna do these changes and hope everything goes right..  i don't like anymore the volcano i'm gonna sell it and i like to get a HPI SAVAGE!!
Hide Signatures
       Post #: 48
RE: Volcano epx pro Running problem - 1/11/2013 9:51 PM
Johnathond22
Score: 100
Status: offline
 It's understandable, after having a large sum of back to back problems it is easy to become discouraged. You do have to consider all aspects when choosing your new RC. The volcano was an excellent way to begin the RC hobby adventure and really is inexpensive to repair and upgrade. The Savage and Traxxas products are really nice and do tend to come more heavy duty right out of the box, but the price tag is equal to the quality. I can honestly say that at this time I have about 400 dollars in my Volcano with all aluminum, body and Lipo upgrades and most likley can't get that for it if I tried to sell it, but I now learned alot about the RC by building this one, and with all upgrades it takes a real beating. My friend has both the Traxxas Stampede and T-maxx model and they are both really nice, but Brushless electric Stampede is much easier to maintain. Good luck with your mods, and if you do decide to sell it... let us know.
Hide Signatures
       Post #: 49
RE: Volcano epx pro Running problem - 1/11/2013 10:10 PM
Leonardo1982
Score: 100
Status: offline
yes i want to sell it.  i baught this volcano 20 day before. and i have same + items for that.. if you are interesing give me your email or find me on fb LEONARDO GLAN
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.844RCU1
