Joe Hunt
CA, USA Status: offline
I'm going to make a video of programming this weekend, hopefully. What I do is program the servos on the plane... remove the linkage... then plug the servo into the Programmer. I program some arbitrary center and end points and write them down (e.g., 0, -120, +120). Then I plug the servo into the RX only, turn on the radio, put back on the linkage, and check it there. I make notes on my paper of where I think I need to go from the original arbitrary numbers (maybe now it will be to try -10, -130, +110). I'll hook back up to RX only and check again. It takes me between 3 and 5 times to get this perfect. I have never got it in less than 3 tries and never taken longer than 5 tries to have it perfect. I always get flawless, absolutely perfect, linearity between elevator halves, etc.
_____________________________
VIDEO: http://www.ruddermayhem.com/aw-96inch-260.wmv VIDEO: http://www.ruddermayhem.com/aw-104inch_yak_04.wmv
