Enforcer Manta Ray advice /help    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> Enforcer Manta Ray advice /help Page: [1]
Login
Enforcer Manta Ray advice /help - 12/16/2012 10:24 AM
Euan
Score: 100
Last Login: 5/22/2013
Status: offline
Hello,
its been a long time since i last ran a boat or posted ,i picked up a ready to run Manta Ray yesterday and have a couple of questions .
Its fitted with what i think to be a spd drive ? but can anyone tell me what version ?? also anywhere in the Uk i can get a spare flexy ? .The engine is a Zen 23 but i was told by the vendor its a modded motor ? says ez 23 with a red spot on both the pull start and cylinder head ?
The boat is in great shape but came with an open un muffled exhaust that i have replaced with a Prestwich pipe and homemade header, lastly its got a water pump something i have not used before and was wondering can it be tested without putting it in the water ,
cheers Euan.
ps i will add some more photos in a bit
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: Enforcer Manta Ray advice /help - 12/16/2012 1:19 PM
Euan
Score: 100
Status: offline
Hello,
I managed to run the engine and test the water pump no real issues apart from the viton o rings need replacing ,
cheers Euan.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Euan)
       Post #: 2
RE: Enforcer Manta Ray advice /help - 12/17/2012 7:37 AM
w3bby
Score: 120
Last Login: 5/23/2013
Status: offline
You can get a flex from Dave at Prestwich, cut and make your own.
The pipe and header together look like they are going to be way too long to get best performance from the motor. You are looking for about 340mm from the flange along the centre line of the header and pipe to the widest part of the pipe.
Lots of water lines to put in place before you run it as well.
_____________________________
Ian
Hide Signatures
(in reply to Euan)
       Post #: 3
RE: Enforcer Manta Ray advice /help - 12/17/2012 9:09 AM
martno1fan
Score: 221
Last Login: 5/19/2013
Status: offline
I have 1/4 flexes in stock
waveridermouldings
Hide Signatures
(in reply to Euan)
       Post #: 4
RE: Enforcer Manta Ray advice /help - 12/17/2012 10:16 AM
Euan
Score: 100
Status: offline
Ian,
thanks for the info on the header length, performance should be fine as this is for my kids to run whilst i play with my seaplanes,
Mart good to hear from you ,
cheers Euan.
Hide Signatures
(in reply to martno1fan)
       Post #: 5
RE: Enforcer Manta Ray advice /help - 12/17/2012 1:09 PM
martno1fan
Score: 221
Status: offline
Hi Euan if its a dbl ended square setup your only option is whobbies or a custom made one.Personally id swap out the stinger for a standard type so you can use the welded flex and stub shafts you can get those with square ends more easily .
Mart
waveridermouldings
Hide Signatures
(in reply to Euan)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.172RCU1
