RE: Census of Hotspots !!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Census of Hotspots !!!
Page: <<   < prev  1 2 3 4 5 6 [7] 8 9   next >   >>
Login
RE: Census of Hotspots !!! - 1/21/2013 6:09 AM
iiievolution
Score: 100
Last Login: 6/18/2013
Status: offline
Hello
I like your color. What brand/code number/name is it.
_____________________________
Dont talk to me about props. I dont care I dont want to know!!!
Hide Signatures
(in reply to B.S.)
       Post #: 151
RE: Census of Hotspots !!! - 1/21/2013 11:09 AM
B.S.
Score: 100
Status: offline
Hi Carlos
Yes it is painted and the same problem as usually with to much weight.
With P100 and 2 litre fuel the weight is 10,4 kg.
It is 0,5 kg to much
Hi iiievolution
The colors are:
Grey metallic / Ford Moondust Metallic
Bluepurple / Honda B90P
Later this week I will add a picture of the plane taken with a real camera.
The purple color seems blue with a photo taken with my mobile phone.
Best Regards
Hide Signatures
(in reply to iiievolution)
       Post #: 152
RE: Census of Hotspots !!! - 1/21/2013 12:42 PM
iiievolution
Score: 100
Status: offline
Thanks for the info.
Paul
Hide Signatures
(in reply to B.S.)
       Post #: 153
RE: Census of Hotspots !!! - 1/22/2013 9:27 AM
mauryr
Score: 100
Last Login: 5/8/2013
Status: offline
quote:
ORIGINAL: cmjets
Hi again:
Yes, this system run perfect, I fit the bank with 2 screws and you can easily remove it from. You can put the smoke pumb down too.
I am working in another Hotspot, I need make the bulkheads for can close it. The nylon hinge is installed in the process of laminate, the door is in carbon fiber.
Regards from Spain.
Carlos Márquez.
_______________________________
http://cmjets.blogspot.com.es/
Tested balance with all components in their intended position and it seems like I can put pump, solenoids and ECU in the gear bay, so I can just send one fuel line, the throttle, the main power line and an extension for the GSU from the front to the back. I am a bit concerned that the components might get fouled up by the gears during a landing in grass or might be disturbed by strong airflow in flight. Am I thinking too much or would it be best to protect them a little?
Hide Signatures
(in reply to cmjets)
       Post #: 154
RE: Census of Hotspots !!! - 1/22/2013 10:24 AM
daorizio
Score: 100
Last Login: 1/30/2013
Status: offline
Very easy out of the situation: you have to stall .
In the video (5'10'') I make the flat spin, I change the direction of rotation, I stabilized the model, pull up and pull down the elev stick. Obviously I have rudders.
The exit is facilitated by the position of the CG back.
This model is over 12 years old, hundreds of flight.
Last summer I given the model to my friend. He made other 20 hours of flight too. And he flight every week.... forever....
http://www.youtube.com/watch?v=n1XgvMS_N3s&feature=youtu.be
damiano
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to mauryr)
       Post #: 155
RE: Census of Hotspots !!! - 1/22/2013 10:36 AM
mauryr
Score: 100
Status: offline
quote:
ORIGINAL: daorizio
damiano
Ciao Damiano,
thanks for the tip, if I end up in the same situation again I'll try cutting the power and have faith
And yes, I should cut rudders some day.
Hide Signatures
(in reply to daorizio)
       Post #: 156
RE: Census of Hotspots !!! - 1/22/2013 2:42 PM
cmjets
Score: 105
Last Login: 6/17/2013
Status: offline
Hi friends:
Really the Hot flown perfect and all components all well fixed, no problem with the LG. When you close the gears the hole is almost closed, and the wind not would be a problem, I think.
Now I not have any Hotspot in flight. I will built another and I will install in the same way.
If never give me problems, not will give me now.
I remember that I used Ni-Cd bateries.
BR.
< Message edited by cmjets -- 1/22/2013 10:18 PM >
Hide Signatures
       Post #: 157
RE: Census of Hotspots !!! - 1/23/2013 8:13 PM
wichet
Score: 100
Status: offline
Hi
here is a couple of Hotspots ive had in over the years. Looking to buy another one in a few months, can't seem to stay away from them.
Custom paint scheme was my first ever turbine jet that i cut my teeth on.
Red Bull scheme i got rid of only last year after buying a second hand airframe and re-doing it.
Wichet
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 158
RE: Census of Hotspots !!! - 1/23/2013 10:22 PM
iiievolution
Score: 100
Status: offline
quote:
ORIGINAL: wichet
Hi
Wichet
Hello
Your custom paint hotspot in the first picture is in Cyprus alive and well. A friend of mine has it.
Paul
Hide Signatures
(in reply to wichet)
       Post #: 159
RE: Census of Hotspots !!! - 1/23/2013 10:31 PM
BaldEagel
Score: 118
Status: offline
Cricky its made its way from Tyne and Wear UK to Cyprus, pretty good flying. LOL
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
       Post #: 160
RE: Census of Hotspots !!! - 1/24/2013 8:53 AM
wichet
Score: 100
Status: offline
It's nice to know it's still flying . Goes to show how good of a model they are.
Wichet
Hide Signatures
(in reply to BaldEagel)
       Post #: 161
RE: Census of Hotspots !!! - 1/24/2013 3:56 PM
flyinfool1
Score: 100
Status: offline
Keep the pics coming guys. I'm building a YA Stingray which is a very similar plan form and am getting a lot of good ideas from this thread.
Lots of real purdy planes so far.
Jeff Borowski
RAMS Club President
Hide Signatures
       Post #: 162
RE: Census of Hotspots !!! - 1/24/2013 10:57 PM
B.S.
Score: 100
Status: offline
Some pictures of my ready to fly HS
Click for fullsize
Click for fullsize
Best Regards
Hide Signatures
(in reply to flyinfool1)
       Post #: 163
RE: Census of Hotspots !!! - 1/25/2013 4:49 AM
SJN
Score: 105
Status: offline
Very nice BS :-)
Sonnich Johannesen
Hide Signatures
(in reply to B.S.)
       Post #: 164
RE: Census of Hotspots !!! - 1/25/2013 6:16 AM
VF169XO
Score: 100
Status: offline
Here's my Hotspot with a P-80 for power. Paint scheme is my last can of SuperPoxy metallic red directly over the white gelcote.
Had a lot of fun flying it but it didn't fly quite right until I put some down-thrust in the engine mount, then it grooved fine.
When I was investigating the stall characteristics, somehow I got into the flat spin more, very slow rotations. Recovery was with full power and a bit of down. very scary if you're not expecting it to happen.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to SJN)
       Post #: 165
RE: Census of Hotspots !!! - 1/26/2013 4:57 AM
I-NAV
Score: 100
Last Login: 6/9/2013
Status: offline
Here mine built back in 2005. Three engines and 3 sets of tires later it's still going..
Click for fullsize
Click for fullsize
Click for fullsize
Mike
Oahu, Hawaii
Hide Signatures
(in reply to VF169XO)
       Post #: 166
RE: Census of Hotspots !!! - 1/27/2013 12:44 PM
maxijets
Score: 100
Last Login: 3/25/2013
Status: offline
Hello to all from Argentina
RED BULL Hotspot This was put together by me for a client, in my country. This photo was taken a year ago, the plane still flying and that is fine.
It is equipped with an old Ram750 plus it works awesome (electronica Xicoy), JR & Hitec servos, Robart retracts.
Hope you like.
Regards
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Maxi Garabello - Pulqui Jet Team
AD S. Scorpion - Kingtech k170 F
Hide Signatures
(in reply to I-NAV)
       Post #: 167
RE: Census of Hotspots !!! - 1/31/2013 2:30 AM
cuevasan
Score: 100
Last Login: 5/14/2013
Status: offline
Here is my new paint job on Hotspot Carlos just waiting on you my friend for that canopy so i can fly.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to S HARRIS)
       Post #: 168
RE: Census of Hotspots !!! - 1/31/2013 1:04 PM
cmjets
Score: 105
Status: offline
Hi friends:
Finally, the next week I will have more Hotspot canopies for send. If someone need a canopy for the Hotspot I can make it.
Regards from Spain.
Carlos Márquez
________________________________________
Hide Signatures
(in reply to cuevasan)
       Post #: 169
RE: Census of Hotspots !!! - 2/1/2013 9:09 AM
John Tancock
Score: 100
Status: offline
Carlos,
You will be a very popular man worldwide!
Regards
John
Hide Signatures
       Post #: 170
RE: Census of Hotspots !!! - 2/1/2013 2:32 PM
Dr Honda
Score: 100
Status: offline
quote:
ORIGINAL: cmjets
Hi friends:
Regards from Spain.
Carlos Márquez
And shipping is reasonable. I got one from Carlos, and I think it was only $28 for shipping to the USA. (PA)
Now... I wish it would warm up, so I can get it painted !!!!! Can't wait to fly mine when spring time get's here.
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
       Post #: 171
RE: Census of Hotspots !!! - 2/1/2013 7:56 PM
cmjets
Score: 105
Status: offline
Hi Friends:
I do most things that canopy ... this is the broken fuselage of Johnny Woods and his new nose.
Regards from Spain.
Carlos Márquez
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Dr Honda)
       Post #: 172
RE: Census of Hotspots !!! - 2/4/2013 9:05 AM
mauryr
Score: 100
Status: offline
Finally maidened mine on turbine power after flying it on EDF for a year.
Everything went well, until I engaged the brakes, then a wheel flew off
Sick of these eurokit retracts, I really need to bother and get something better.
Friend of mine is selling a set of behotec C36, maybe these would be better...
What is everybody using? Any decent set out there which fits the hotspot?
Hide Signatures
(in reply to B.S.)
       Post #: 173
RE: Census of Hotspots !!! - 2/4/2013 11:23 AM
cmjets
Score: 105
Status: offline
Hello:
Where are the photos ???
I will install AirPower or Electron Retracts, maybe the last with AirPower struts and wheels.
Regards from Spain.
Carlos Márquez.
______________________________________________
Hide Signatures
       Post #: 174
RE: Census of Hotspots !!! - 2/6/2013 1:08 PM
cmjets
Score: 105
Status: offline
Hi friends:
I have more canopies of Hotspot, if someone need it, please, tell me it before spend the plastic.
Regards.
Carlos.
Click for fullsize
Hide Signatures
       Post #: 175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.629RCU1
