Cutting multiple angles on balsa stick build ups?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> Cutting multiple angles on balsa stick build ups?
Page: [1]
Login
Cutting multiple angles on balsa stick build ups? - 12/16/2012 10:32 PM
HP^Matt
Score: 100
Last Login: 1/26/2013
Status: offline
Getting back to the modeling roots and scratch building from plans again. I'm interested in the ways that others are cutting the multiple mitre/angle cuts on the diagonals of their stick framed parts. I'm marking and cutting out side the lines with a band saw or Zona saw and sanding to sneak up on a good fit. I can get perfect fits, but it is very time consuming. Is there a better way?
thanks
Matt
Hide Signatures
       Post #: 1
RE: Cutting multiple angles on balsa stick build ups? - 12/16/2012 11:28 PM
R8893
Score: 100
Last Login: 6/19/2013
Status: offline
I measure with a protractor, then cut on my tablesaw. Pretty much what you do.
Hide Signatures
(in reply to HP^Matt)
       Post #: 2
RE: Cutting multiple angles on balsa stick build ups? - 12/17/2012 2:20 AM
combatpigg
Score: 381
Status: offline
I've stick built 1/2" thick frames [and thinner] by just laying the stick to be cut over the longerons, marking for the cut with an Xacto knife, then just using a razor saw to make the cuts. If you can't trust your eyes for a vertical cut, then just use a vertical guide to set the saw blade against as you make your cut.
_____________________________
Blatantly corrupt umpiring at Yankee Stadium is an American tradition
It''s just part of the game.
Hide Signatures
(in reply to R8893)
       Post #: 3
RE: Cutting multiple angles on balsa stick build ups? - 12/17/2012 2:32 AM
HP^Matt
Score: 100
Status: offline
Thanks for the replies guys! I was really hoping for some new fangled super duper easy ....... just kidding. I just seems to take so much longer than it did 15yrs ago.
Matt
Hide Signatures
(in reply to combatpigg)
       Post #: 4
RE: Cutting multiple angles on balsa stick build ups? - 12/17/2012 4:21 AM
invertmast
Score: 193
Status: offline
quote:
ORIGINAL: HP^Matt
Matt
Laser cut sides that look like a built-up stick structure..
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
       Post #: 5
RE: Cutting multiple angles on balsa stick build ups? - 12/17/2012 7:11 AM
combatpigg
Score: 381
Status: offline
quote:
ORIGINAL: HP^Matt
Matt
If I make a cut that isn't absolutely perfect, I glue it in anyway then pack the gap with fine balsa sawdust and hit it with CA.
Once I finish the control surface or fuselage side, then I surface it with an 80 grit sanding disk that is mounted in my drill press. Set the table for a "squeeze fit" to just take a very light cut and the glued up pile of sticks comes out looking like it was machined.
Hide Signatures
       Post #: 6
RE: Cutting multiple angles on balsa stick build ups? - 12/17/2012 12:20 PM
sensei
Score: 196
Status: offline
I mark them, cut them with a scroll saw, and finish them to the line on a 6" dia. disc sanding table, after that I glue everything together with thin CA. Next I pull the work from the table and run a corner glue joint with medium CA in every corner and kick it off. I don't ever worry about the excess CA on the balsa because the way I sand flat surfaces and fuse sides is like cheating its so easy. I place 6 or 7 sheets in a row of 9" x 11" 180 - 220 grit sand paper on a flat surface like glass from an old sliding glass door with 3M 77 spray adhesive. I make sure not to allow any of the sand paper to overlap at all, then I work the control surface, stab, or fuse against the table instead of using a sanding block against these items. this type of sanding will take everything down so fast and true, you just won't believe it. I guess I have been doing this for 20 years or more and I have done it on stuff all the way up to 70 % airplane size with the same results. Here is a just glued picture and a couple more just a little while later.
Bob
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by sensei -- 12/17/2012 1:09 PM >
Fly It Like You Stole It!!!
Hide Signatures
       Post #: 7
RE: Cutting multiple angles on balsa stick build ups? - 12/17/2012 1:48 PM
ARUP
Score: 144
Status: offline
118" span of stick built glory! I do as you do- cut and sand for fit. Takes forever... but worth it!
Click for fullsize
Hide Signatures
(in reply to sensei)
       Post #: 8
RE: Cutting multiple angles on balsa stick build ups? - 12/17/2012 2:14 PM
MajorTomski
Score: 113
Status: offline
I've been contemplating one of these:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXG876&P=ML
Spitfire Brotherhood #6
Kadet LT 40 Brotherhood #98
Hide Signatures
(in reply to ARUP)
       Post #: 9
RE: Cutting multiple angles on balsa stick build ups? - 12/17/2012 4:44 PM
Walther
Score: 105
Status: offline
This is what I have been using and I think it works great. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFCE0&P=7
Hide Signatures
(in reply to MajorTomski)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.031RCU1
