CMP Beaver conversion    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Electrics to Glow Conversions >> CMP Beaver conversion
Page: [1]
Login
CMP Beaver conversion - 12/16/2012 11:41 PM
tomd-RCU
Last Login: 2/5/2013
Status: offline
The Beaver was ordered from HobbyKing. I received it in top condition. Everything was well packaged and I was surprised at the quality of the plane. It is a balsa built and covered with shrink plastic.
I am thinking of using an OS 32SX engine with a Pitt's style muffler.
The work involves removing the already built electric engine mount and replace it with a suitable mount for glow.
Of course a pushrod and an extra servo will have to be added for the engine as also a fuel tank.
Click to see fullsize image.
Click for fullsize
_____________________________
Tomd
Hide Signatures
       Post #: 1
RE: CMP Beaver conversion - 12/16/2012 11:52 PM
tomd-RCU
Status: offline
The front of the firewall needs to be flush with the front of the fuselage. Since I will be using 1/4 inch plywood to build it, I cut the original firewall 1/4 of an inch inside the front of the fuselage.
To keep the new firewall in place, I glued inside the remaining firewall four pieces of 1/8 inch plywood. Tabs were cut on these pieces to hold the firewall in place.
Triangle stock was used to reinforce the whole structure.
Click for fullsize
< Message edited by tomd-RCU -- 12/17/2012 12:08 AM >
Tomd
Hide Signatures
(in reply to tomd-RCU)
       Post #: 2
RE: CMP Beaver conversion - 12/17/2012 12:11 AM
tomd-RCU
Status: offline
This is a picture of the original electric motor mount.
You can clearly see where I made the cuts.
Click for fullsize
< Message edited by tomd-RCU -- 12/17/2012 12:12 AM >
Tomd
Hide Signatures
       Post #: 3
RE: CMP Beaver conversion - 12/17/2012 2:34 PM
Twin_Flyer
Last Login: 6/19/2013
Status: offline
Considering you only using a .32, do you really need to use 1/4" ply for the new firewall? Save some weight and use 1/8".
just a thought.
Bill S.
Carl Goldberg Ultimate Brotherhood #56
Ultra Sport Brotherhood #135
http://radiocontrolhobbies.freeservers.com
Hide Signatures
       Post #: 4
RE: CMP Beaver conversion - 12/18/2012 12:14 AM
tomd-RCU
Status: offline
Here is a picture of the firewall installed.
I made sure I gave it about 3 degrres of downthrust and close to two degrees of right thrust.
Twin Flyer, yes 1/4 inch plywood might be overkill bit it is my first conversion. Is there a rule of thumb when choosing plywood thickness vs engine displacement ?
My calculations tell me I might need some extra weight in the front because of the short nose moment of this plane. If this turns out to be the case then the extra weight of the plywood will pay off.
Click for fullsize
Tomd
Hide Signatures
(in reply to Twin_Flyer)
       Post #: 5
RE: CMP Beaver conversion - 12/18/2012 12:18 AM
tomd-RCU
Status: offline
The open space was closed off using 1/16 plywood.
I used high temperature gasket material to seal the joint betwwen the firewall and the rest of the enclosure.
Because this enclosure covers the cowling supports, I made sure I drilled holes in the enclosure to access the T-nuts installed by the manufacturer.
Click for fullsize
< Message edited by tomd-RCU -- 12/18/2012 12:23 AM >
Tomd
Hide Signatures
       Post #: 6
RE: CMP Beaver conversion - 12/19/2012 2:31 AM
ckreef
Last Login: 6/3/2013
Status: offline
Judgeing from past experience 3 degrees  of down and 2 degrees of right sounds like way too much. Every conversion I have  done to date needs some thrust taken out compared to what the electric setup had built in (and I use engines on the larger size for the plane). I would rather start either flush or with 1 and 1 and add washers as needed.
Hide Signatures
       Post #: 7
RE: CMP Beaver conversion - 12/20/2012 11:11 AM
tomd-RCU
Status: offline
ckreef,
Thank you for your input.
What you say does make sense. When the throttle is activated, an electric motor develops it's torque more rapidly than a glow motor.
I will need to try the airplane and, if need be, I will reduce the thrust incidence.
Tomd
Hide Signatures
(in reply to ckreef)
       Post #: 8
RE: CMP Beaver conversion - 12/21/2012 1:27 AM
tomd-RCU
Status: offline
This picture showas the engine support in place. The engine will be an OS 32SX and it will installed rotated 90 degrees to the right.
Click for fullsize
Tomd
Hide Signatures
       Post #: 9
RE: CMP Beaver conversion - 12/21/2012 1:29 AM
tomd-RCU
Status: offline
This picture shows the engine installed with it's Pitts style muffler.
The throttle arm had to be extended to clear the muffler.
Click for fullsize
Tomd
Hide Signatures
       Post #: 10
RE: CMP Beaver conversion - 1/30/2013 6:53 AM
Kmot
Status: offline
You're doing an awesome job!
~Tom~
Hide Signatures
       Post #: 11
RE: CMP Beaver conversion - 1/31/2013 12:17 AM
tomd-RCU
Status: offline
Thank you Kmot.
Since glow fuel is used, I need to install a support for the fuel tank at the right height.
This picture shows my work.
Click for fullsize
Tomd
Hide Signatures
(in reply to Kmot)
       Post #: 12
RE: CMP Beaver conversion - 1/31/2013 12:22 AM
tomd-RCU
Status: offline
This picture shows the servos installed.
Notice I had to add a third servo for the throttle.
Click for fullsize
Tomd
Hide Signatures
       Post #: 13
RE: CMP Beaver conversion - 2/1/2013 8:29 AM
TKO
Last Login: 3/2/2013
Status: offline
Hello Tomd,
nice conversion. I bought the Beaver from CMP(The Military version) and for a week ago i did start the conversion to glow and used your "knowledge" for the firewall.
This is almost ready and i'm thinking now about the engine. First i thought the .60 4 stroke is the egine i like for the sound, but a 4 stroke is somewhere an attack on the fuselage of the aircraft and a 2 stroke is not so nice for his sound.
What do you think?
Rgds
Theo(From the Netherlands)
Hide Signatures
       Post #: 14
RE: CMP Beaver conversion - 2/3/2013 1:39 PM
tomd-RCU
Status: offline
Hello TKO,
I naturally prefer the sound of a 4 cycle to that of a 2 cycle especially on this type of airplane.
I recently checked the balance of the airplane and with my 32 SX the airplane is a little rear heavy. This tells me that the use of a heavier engine would not need additional front weight. However, I would think that a 60 would be too heavy up front. I think a 46 size engine would be best.
As for 2 or 4 cycles, here is my thinking. Around the circunference of the cowling are three tabs whose holes have to align on T-nuts on the firewall.
If you use a 4 cycle there is a good possibility that 2 of these tabs (the holes) will be blocked by the head of the engine. You will then need to add tabs at different places on the rear circumference of the cowling to keep it in place. Believe me, adding two tabs is not an easy matter. I had to do it for the 32 SX, I imagine it would be more difficult with a bigger engine. Check my picture below and you can see the two extra tabs I had to add. Of course, forget about the fake radial when you add these extra tabs. There is no way you can align the tabs with the T-nuts with the fake radial in place.
Another consideration... a bigger engine means bigger servos. There is no problem in the fuselage. However, It is a diffrent story for the wings. I upgraded my servos to Spektrum's A5030 (these are minis)and I am having a hard time fitting them in the wings. I am almost there.
You are right a 60 size engine would be too much for the firewall. A 40 size 2 cycle would be a better choice even if the sound that we want to hear is not there.
Good luck and post pictures of your work.
Click for fullsize
< Message edited by tomd-RCU -- 2/3/2013 4:52 PM >
Tomd
Hide Signatures
(in reply to TKO)
       Post #: 15
RE: CMP Beaver conversion - 2/10/2013 10:45 AM
TKO
Status: offline
Thanks Tomd for all the information. I have to wait for the delivery of some items from Hong Kong and than i hope to finish this Beaver.
As soon as i start to build the engine on the fuselage i make some pictures.
Last year i was a couple of weeks in Canada to make a roundtrip and visit family of my wife in Edmonton. We started in Calgary and via Jasper, Edmonton to Vancouver Islands and than back to Vancouver for our flight back to the Netherlands. What a beautiful country is Canada
Rgds
Theo
< Message edited by TKO -- 2/17/2013 1:32 PM >
Hide Signatures
       Post #: 16
RE: CMP Beaver conversion - 6/3/2013 3:25 AM
Flightfreak777
Last Login: 6/6/2013
Status: offline
Anymore updates on this? I'm looking to get this plane and go glow on it. Wouldn't mind seeing some pics of the finished plane.
Matt
"Helicopters don't fly....They just beat the air into submission" <-- Go Planes!!!
Hide Signatures
(in reply to TKO)
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.141RCU1
