What timing do I use?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RC Airplane Tie Down kit for your Trailer,Truck or Van - Kit
Seller:  rcjunky2
Details:   $29.99   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Brushed/Brushless motors, speed controls, gear drives >> What timing do I use?
Page: [1]
Login
What timing do I use? - 12/16/2012 11:48 PM
rem0.061
Score: 102
Last Login: 5/21/2013
Status: offline
I have a 5692 540kv inrunner and an ESC with 3 options: auto, 7deg., and 30deg. What timing is best?
Hide Signatures
       Post #: 1
RE: What timing do I use? - 12/17/2012 10:11 PM
rem0.061
Score: 102
Status: offline
I know inrunners take low timing and outrunners use high, but I don't know the difference in degrees.
Hide Signatures
(in reply to rem0.061)
       Post #: 2
RE: What timing do I use? - 12/17/2012 10:21 PM
Dr Kiwi
Score: 120
Last Login: 5/23/2013
Status: offline
In testing 100's of motors, I've always have used "auto".. only if the test motor doesn't run well do I fiddle with changing it.
Try auto.. it might be all you need.
_____________________________
Dr Phil Millener, Chattanooga, TN
Hide Signatures
       Post #: 3
RE: What timing do I use? - 12/17/2012 10:28 PM
rem0.061
Score: 102
Status: offline
I am using auto, I was just wondering what the most efficient or powerful kind of tining is for an inrunner.
Hide Signatures
(in reply to Dr Kiwi)
       Post #: 4
RE: What timing do I use? - 12/18/2012 5:53 PM
Dr Kiwi
Score: 120
Status: offline
I finally tracked down Ken Myer's great "timing" article on its new site: http://www.theampeer.org/timing/timing.htm
Generally it seems that higher timing has few advantages... maybe more power, but a lot more heat wasted!
Over time with testing, we've found it's best to use a lower setting in order to keep motor temps in check, especially with very, very fast setups.
Higher advance makes the motor run hotter, and the higher the Kv of the motor, the hotter it will get! Too high of an advance setting will give the same results as too much advance on a brushed motor - you will actually LOSE power and speed while the motor cooks itself!"
Hide Signatures
       Post #: 5
RE: What timing do I use? - 1/1/2013 1:45 AM
carlnoki
Score: 100
Status: offline
IF that is a Leopard 5692 540KV motor, then it is also a WYE wound motor.
The WYE wind motors are normally timed in the middish to lower high timing areas.
The 7 deg. timing available from your esc should be fine.
If it were a DELTA wind motor, then lower timing is called for.
Knowing the type of windings the motor has also helps in the initial setting up of the timing of the esc.
Then through testing you can see what the results are by going both raising and lowering the timing.
In your case, you only have a very limited amount of timing selections.
I use the Fightercat (ie, Fliermodel line of esc's and they have timing adjustments in 1 deg. incriments)
I run outrunner motors in marine applications (racing mono and hydros) and they are set at around 5-10 deg. depending
on the application.
I have run the inrunners for air usage and they seem to follow the same pattern as for marine use.
But this is just my findings for my applications for the Brand of motors I use..
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.313RCU1
