Hanger 9 amp/volt meter question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Hanger 9 amp/volt meter question
Page: [1]
Login
Hanger 9 amp/volt meter question - 12/17/2012 2:31 AM
FenderBean
Score: 119
Last Login: 5/22/2013
Status: offline
I know it checks for amps but can it also check batteries with a load? My volt meter went bad and I need a new one but I would like to get something that check amps as well. This is the only one I have found. THanks
_____________________________
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
       Post #: 1
RE: Hanger 9 amp/volt meter question - 12/17/2012 4:42 PM
BarracudaHockey
Score: 280
Status: online
It checks both but there's no load
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to FenderBean)
       Post #: 2
RE: Hanger 9 amp/volt meter question - 12/17/2012 8:02 PM
pilotpete2
Score: 120
Status: offline
http://www.horizonhobby.com/browse/productgrid/electronics-10001064
If you need a new voltmeter with a load. The one on the right is what you want. It's an excellent unit, but does require some knowledge on the part of the user. It displays the voltage digitally, and it works with all chemistry batteries and a wide range of cell counts. You must actually know what voltage you're looking for. There is no go/no go indication.
The unit on the left is not a voltage meter, but is a servo current meter, handy little device too
Pete
"If the woman don''''''''t find you handsome, they should at least find you handy"
Hide Signatures
       Post #: 3
RE: Hanger 9 amp/volt meter question - 12/17/2012 9:09 PM
Rodney
Score: 169
Status: offline
You can make any volt meter a "loaded voltmeter" by simply placing a resistive load in parallel with the voltmeter terminals. For 4 or 5 cell Nixx batteries, use a 10 ohm 5 to 10 watt resistor. this will draw 400 to 700 milliamperes for a load. For a 6 cell transmitter battery, use a 22 ohm 5 to 10 watt resistor to draw about 500 milliamperes for a load. You can get a pretty good VOM (volt-ohm-meter) from Harbor Freight or many hardware stores for about $5 or less.
Hide Signatures
(in reply to pilotpete2)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.250RCU1
