What switches do you use?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> What switches do you use?
Page: [1]
Login
What switches do you use? - 12/17/2012 2:37 AM
Dig it
Score: 102
Last Login: 5/21/2013
Status: offline
New to Jets, and I have a 12X that I'm going to be using on a PST Panther. I'm setting everything up and I find myself wondering what most people ( I realize this is personal choice) are using for the brakes? I'm thinking the Aux2 3pos switch because its easy to setup, but it would be more comfortable on the Mix/Hold Switch on top or perhaps one of the sliders on the side.
I'd really appreciate the input, there's no sense in learning something already experienced.
Dale
_____________________________
Hey buddy. Thats a Kadet not an Extra 300!!!!
Hide Signatures
       Post #: 1
RE: What switches do you use? - 12/17/2012 2:42 AM
IFlyEm35
Score: 105
Last Login: 5/22/2013
Status: offline
Personally I used the slider but thats just me. I use the switches for various things on different models so I chose a method that I would be able to standardize on.
I''''m in a jet!!! What could possibly go wrong?
Hide Signatures
(in reply to Dig it)
       Post #: 2
RE: What switches do you use? - 12/17/2012 2:47 AM
number27
Score: 100
Status: offline
+1 for on a slider
Jetcat RX140 refurbished Yellow F15,
Kingtech 140F PST Reaction, Kingtech 170g CARF Eurosport
Hide Signatures
(in reply to IFlyEm35)
       Post #: 3
RE: What switches do you use? - 12/17/2012 2:48 AM
FenderBean
Score: 119
Status: offline
+2 on slider but a lot use down elevator it seems
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
(in reply to number27)
       Post #: 4
RE: What switches do you use? - 12/17/2012 2:58 AM
Flynstuff
Score: 100
Status: offline
(down elevator it seems ) Yiks
J. Tolomeo
KingTech-USA Rep & Team Pilot
Hide Signatures
(in reply to FenderBean)
       Post #: 5
RE: What switches do you use? - 12/17/2012 4:19 AM
IFlyEm35
Score: 105
Status: offline
quote:
ORIGINAL: FenderBean
I do both. I have the Jetronics Low Loss brake valve so I can land with a little positive pressure with the slider. The down elevator is nice for taxiing.
< Message edited by IFlyEm35 -- 12/17/2012 4:53 AM >
Hide Signatures
       Post #: 6
RE: What switches do you use? - 12/17/2012 4:51 AM
David Searles
Score: 115
Status: offline
If you're going to use a proportional brake valve, such as the BVM Smooth stop or Jetronics or UP, using a switch would defeat the purpose. I do not like on/off brake switches due to the tendency to lock the brakes up. I use a side slider combined with a proportional brake valve. I've used all of the ones mentioned above, & prefer either the BVM or Jetronics valves. Both work great.
David S
Hide Signatures
       Post #: 7
RE: What switches do you use? - 12/17/2012 4:58 AM
dubd
Score: 135
Status: offline
Right slider.
Hide Signatures
       Post #: 8
RE: What switches do you use? - 12/17/2012 10:48 AM
alasdair
Score: 113
Status: online
Since buying the Hitec Aurora 9 and Spektrum DX18 I have started to use the right slider  for wheelbrakes, and find it much better than mixing it on down elevator as I used to do on my old JR388.
I plan to use the left slider for progressive airbrakes
Hide Signatures
(in reply to dubd)
       Post #: 9
RE: What switches do you use? - 12/17/2012 11:29 AM
RCISFUN
Score: 105
Status: offline
Down Elevator with an electronic valve
Rich
Jet Central Rabbit, Cheetah, Super Eagle & Rhino owner
Hide Signatures
(in reply to alasdair)
       Post #: 10
RE: What switches do you use? - 12/17/2012 11:38 AM
funflyerf4
Score: 100
Status: offline
Same as Rich down elev. and jet troincs valve been doing it since day one.
Hide Signatures
(in reply to RCISFUN)
       Post #: 11
RE: What switches do you use? - 12/17/2012 12:15 PM
luv2flyrc
Score: 102
Status: offline
Used to use right slider only, now have option of down elevator and right slider, end up using the down elevator almost all the time.
Mike
Hide Signatures
(in reply to funflyerf4)
       Post #: 12
RE: What switches do you use? - 12/17/2012 12:43 PM
basimpsn
Score: 120
Status: online
Still can't shake from using down elevator.. back then we didn't have more than 6ch to play with
It''''''''''''''''''''''''''''''''s a hobby - keep it simple
Hide Signatures
(in reply to luv2flyrc)
       Post #: 13
RE: What switches do you use? - 12/17/2012 1:44 PM
MAXIAN
Score: 100
Status: offline
Right slider.....
Hide Signatures
(in reply to basimpsn)
       Post #: 14
RE: What switches do you use? - 12/17/2012 5:06 PM
Terry Holston
Score: 100
Status: offline
I use the right slider for a parking brake with mixed in down elevator for taxi , works well for me on my PST Panther, My 1/8 F-16 and my Boomerang Nano.
Terry Holston,I Fly Jets
I''''m NOT speeding, I''''m QUALIFYING
Hide Signatures
(in reply to MAXIAN)
       Post #: 15
RE: What switches do you use? - 12/17/2012 5:08 PM
Ron Stahl
Score: 125
Status: offline
Right slider
I use my real name and am not sponsored by anyone but myself
Hide Signatures
(in reply to Terry Holston)
       Post #: 16
RE: What switches do you use? - 12/17/2012 5:20 PM
VF84sluggo
Score: 345
Status: offline
Down elevator and right slider.
Like Terry, I mainly use the slider as a "parking brake." I use down elevator on taxi and landing roll. It's easier for me to stay on the stick to keep aileron into the wind on a crosswind rollout and brake with a bit of forward stick, rather than reach for a slider.
I have the brake application/forward stick mix contingent on the gear switch being down. With the gear switch up, forward stick does not apply brakes and cause bleeding of air pressure.
JetCat P100-RX
Kingtech K60G
Hide Signatures
(in reply to Ron Stahl)
       Post #: 17
RE: What switches do you use? - 12/17/2012 5:31 PM
RCFlyerDan
Score: 105
Status: offline
quote:
ORIGINAL: dubd
Right slider.
+2- 12X here and right slider/BVM smooth stops. From flying full scale jets, down elevator was not applied too soon in the landing roll, due to aerodynamics of lifting (taking possitive contact with the pavement) the mains off of the runway, reducing braking effectiveness, until below 80 knots. This is why some of you guys who are using down elevator are porpoising the jet down the runway. So, I definitely don't recommend down elevator. I think this down elevator technique started when radios didn't have enough channels, and some have just stuck with it. Again, my technique....IMHO.
There are those who have and those who will!!
Take Care! Dan
Hide Signatures
(in reply to dubd)
       Post #: 18
RE: What switches do you use? - 12/17/2012 7:06 PM
rshadroui
Score: 100
Last Login: 4/1/2013
Status: offline
I also use right slider. I think the slider winds hands down. End of story.
Hide Signatures
(in reply to RCFlyerDan)
       Post #: 19
RE: What switches do you use? - 12/17/2012 7:12 PM
Dig it
Score: 102
Status: offline
Awesome, thanks for the replies. Since most people are right sliders, and I'm using the hydraulic breaking system, thats what I'll go with.
Thanks much
Dale
Hide Signatures
(in reply to rshadroui)
       Post #: 20
RE: What switches do you use? - 12/17/2012 9:55 PM
rcand
Score: 105
Status: offline
quote:
ORIGINAL: Dig it
I have tried a few places. For me, the aux 2 is easiet to use
Dale
Hide Signatures
       Post #: 21
RE: What switches do you use? - 12/18/2012 3:00 AM
Wclays
Score: 105
Status: offline
[[/quote]
[/quote]
Agree on the slider, I feel the same that down elevator is a no no. It will cause the problems describe above.
Hide Signatures
       Post #: 22
RE: What switches do you use? - 12/18/2012 2:14 PM
CraigG
Score: 105
Status: offline
Hide Signatures
(in reply to Wclays)
       Post #: 23
RE: What switches do you use? - 12/18/2012 2:16 PM
CraigG
Score: 105
Status: offline
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
Brakes on down elevator is not a "no no", it's a personal preference. Lots of us have been using it successfully and effectively for years. I have seen lots of "porposing" on landings but none that I would attribute directly to having brakes on down elevator.
On the other hand, I've seen lots of guys have problems with directional control during the landing roll. Is it because they have taken their fingers off the stick to move brakes on a slider and/or because the short throw of the slider makes small inputs more difficult? I really don't know and I certainly wouldn't presume to tell the many slider advocates their method is a "no no".
Obviously, both methods work for different people. Let the new guy decide for himself what works best and the next time this recurring topic comes up, he can cast his vote.
Craig
Hide Signatures
       Post #: 24
RE: What switches do you use? - 12/18/2012 11:03 PM
luv2flyrc
Score: 102
Status: offline
quote:
ORIGINAL: CraigG
Craig
Yes, totally agree, porpoising down the runway has nothing to do with your brakes being on down elevator, it has everything to do with coming in too hot!  Unless of course, you are trying to apply the brakes while you're still flying, then you'll certainly drive the nose in, most of us apply the brakes tho when we're already on the ground
Mike
Hide Signatures
(in reply to CraigG)
       Post #: 25
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.857RCU1
