DLE Tachometer    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> DLE Tachometer
Page: [1]
Login
DLE Tachometer - 12/17/2012 1:40 PM
lcarron
Score: 100
Last Login: 5/13/2013
Status: offline
Hello all,
I used my brand new DLE tachometer on my new DLE-55 using the extra connection and a 12 inches extension cable.
At low RPM the tachometer show 8 and only start to pick up speed if I rev up. After few seconds it goes back to 8 and searching for speed again.
I'm using 6.6 Life battery and an ignition battery Eliminator from WIKE R/C Product..
Is yours doing that as well?
Thanks.
Hide Signatures
       Post #: 1
RE: DLE Tachometer - 12/17/2012 4:17 PM
DaleD
Score: 105
Last Login: 5/18/2013
Status: offline
 Not my experience at all. Try connecting the tachometer directly to the ignition and see if the same thing happens.
DaleD
Hide Signatures
(in reply to lcarron)
       Post #: 2
RE: DLE Tachometer - 12/17/2012 6:22 PM
av8tor1977
Score: 665
Last Login: 5/19/2013
Status: offline
Also, I believe the instructions state that if it doesn't work properly, that can be an indication of radio interference. Then again, you might just have a faulty tach.
AV8TOR
_____________________________
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to DaleD)
       Post #: 3
RE: DLE Tachometer - 12/17/2012 10:38 PM  1 votes
raydar
Score: 142
Last Login: 5/9/2013
Status: offline
 its a known issue with the rxcel tacho and rxcel igition output. Just stick the y lead in the sensor wire to ignition box wire and you will be golden.
Hide Signatures
(in reply to av8tor1977)
       Post #: 4
RE: DLE Tachometer - 12/17/2012 11:08 PM
mikes68charger
Score: 106
Status: offline
 Mine always acted odd and I never really trusted it
Hide Signatures
(in reply to raydar)
       Post #: 5
RE: DLE Tachometer - 12/18/2012 10:52 AM
Tony Hallo
Score: 141
Status: offline
I tried two, neither worked, gave up.  The first one is shown below, returned for replacement, the second one read 3 - 7's if memory serves me correctly.
Click to see fullsize image.
Click for fullsize
Tony Hallo
Hide Signatures
(in reply to mikes68charger)
       Post #: 6
RE: DLE Tachometer - 12/18/2012 5:57 PM
captinjohn
Score: 247
Status: offline
I gave up also on those type,s of tack...I do not need one anyway.  My ear and carefull tuning is good enough for me.
I never met a engine I did not like !
Hide Signatures
(in reply to Tony Hallo)
       Post #: 7
RE: DLE Tachometer - 12/24/2012 4:33 AM
lcarron
Score: 100
Status: offline
yes you were right, the module connected with the Y to the sensor work like a charm.
Hide Signatures
       Post #: 8
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> DLE Tachometer
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
