Down and Locked New Product    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Down and Locked New Product
Page: [1]
Login
Down and Locked New Product - 12/17/2012 5:47 PM
757Driver
Last Login: 5/18/2013
Status: online
Hello, I just wanted to share this great new tool for use with electric D&L Gear. Sorry for the poor video but I was stuck using my Iphone.
http://www.youtube.com/watch?v=GJfxHJj6DKU
_____________________________
Thanks, Jason
I love it when my airplane is on fire...as long as the fire stays inside the engine!
Hide Signatures
       Post #: 1
RE: Down and Locked New Product - 12/17/2012 6:16 PM
wojtek
Status: offline
Cool, i will definitely be using one of these
~V~
Nothing can ever be fast (or scale ;) ) enough !!!
www.all-scale.com
Hide Signatures
(in reply to 757Driver)
       Post #: 2
RE: Down and Locked New Product - 12/17/2012 7:18 PM
DrScoles
Status: offline
One thing I would like is the ability to cycle the gear without the tx. It would be nice during set up and take down of the plane.
Hide Signatures
(in reply to wojtek)
       Post #: 3
RE: Down and Locked New Product - 12/17/2012 8:44 PM
David Searles
Status: offline
On my D&L gear you can simply plug the battery directly to the gear plug. Reverse direction obtained by reversing the plug polarity. Simple, easy, no extra device necessary.
David S
Hide Signatures
(in reply to DrScoles)
       Post #: 4
RE: Down and Locked New Product - 12/17/2012 9:36 PM
Pepperpete
Status: online
I had my fingers crossed that this would be an announcement of new and compact electronic door rams. I tried the lado rams but they are stupid huge and just wouldn't work for anything but the largest aircraft.
Hide Signatures
(in reply to David Searles)
       Post #: 5
RE: Down and Locked New Product - 12/17/2012 10:24 PM
luv2flyrc
Status: offline
quote:
ORIGINAL: Pepperpete
Been there, done that
Mike
Hide Signatures
(in reply to Pepperpete)
       Post #: 6
RE: Down and Locked New Product - 12/18/2012 2:17 AM
Down and Locked
Last Login: 5/10/2013
Status: offline
I would like too thank (757Driver Jason) for the posting of the video and address a few comments about the new Down and Locked set up switch. We also have some interesting news for 2013.
1)This switch has ampout control which means that you can continue to hold the direction buttons after the gear has completed it's cycle and no harm will be done to the retract actuator. As David Searles stated you can use a battery but you run the risk of burning up the actuators if you do not disconnect immediately once the gear has ended its cycle,this occurrence is one of the reasons the switch was developed.
2) you do not need your radio transmitter to safely operate the gear in a static or set up situation. The switch takes the place of the transmitter and the on board gear controller.
3) you can stop/start/or reverse direction at any point in the travel of the gear without having to connect/disconnect or reverse the polarity of the wires. This is very valuable when establishing the fit of strut fairings or door closures.
4) The comment about door actuators,we have a strong desire to manufacture door actuators and do have a new product coming out in early 2013 to address this for use in some airframes. However the current size of the motors required to perform these functions and threaded rams required to develop the same operation as that of an air cylinder ram can only be made so small to get them to the size of an average 3/8th diameter air cylinder is not currently possible. The door actuator that we have developed is not the solution to all airframes due to size but it will work in some,it will also be a great option on items such as dive brakes and canopy's. But until we can further reduce the size of the required components a good mini or standard servo operated by our door sequencer will continue to be the best option for a total electric system for some time to come. We are testing some new methods to achieve door operation in a smaller package but it will be another year or so before we have this perfected.
5) Down and Locked will have a complete new website up by or before January 1st 2013 allowing for secure check out of items and announcing a whole host of electronic devices specifically engineered for the R/C aviation market to include.
Secure flight distribution modules/ twin engine synchronization systems/ regulated power switches/ Ignition Battery Elimination Filters/ on board glow chargers/Battery regulators. Etc
Thousands of customers have come to trust and rely on the "Dependable American Made" operation of the Down and Locked conversion system and our highly respected customer service. Duplicating this same relentless dedication Down and Locked will constantly add new in house developed products at a pretty rapid pace after the opening of our new web based hobby outlet in January 2013 and will be increasing the products offered by other manufactures also as we continue to build on the success of the Down and Locked electric retract conversion system.
Please be sure to visit our web site or call us for the latest technology in electronic safety devices and flight controls to make flying safer and less expensive. You will be able to purchase these devices direct from us or a multitude of distributors most of which I am sure you already enjoy doing business with. Thanks again Mitch Stott
Mitch Stott Co-owner Down And Locked
www.downandlocked.com
Hide Signatures
(in reply to luv2flyrc)
       Post #: 7
RE: Down and Locked New Product - 12/18/2012 5:00 AM
David Searles
Status: offline
quote:
ORIGINAL: Down and Locked
Thousands of customers have come to trust and rely on the ''Dependable American Made'' operation of the Down and Locked conversion system and our highly respected customer service. Duplicating this same relentless dedication Down and Locked will constantly add new in house developed products at a pretty rapid pace after the opening of our new web based hobby outlet in January 2013 and will be increasing the products offered by other manufactures also as we continue to build on the success of the Down and Locked electric retract conversion system.
Mitch,
Thanks for the heads up! You never mentioned that to me! I was doing what you told me to do. No problems though, so far, the gear works GREAT on my F-100! I'll know to be careful about the end points in the future.
David S
Hide Signatures
(in reply to Down and Locked)
       Post #: 8
RE: Down and Locked New Product - 12/18/2012 1:00 PM
Vincent
Status: offline
Hi David,
What are you using to drive the gear doors on your F-100?
Vin...
Hide Signatures
       Post #: 9
RE: Down and Locked New Product - 12/18/2012 1:48 PM
David Searles
Status: offline
quote:
ORIGINAL: Vincent
Hi David,
Vin...
Hi Vin,
I'm using the Lado Actuators. The 30 mm fit the main doors perfectly! I had to adapt the nose door fitting a bit to get the 20mm actuator to fit.
David S
Hide Signatures
(in reply to Vincent)
       Post #: 10
RE: Down and Locked New Product - 12/18/2012 9:11 PM
757Driver
Status: online
Hi David, I've started a f-100 and would love to see pics or build thread of yours of any good threads you might recommend.
Mitch is converting the gear as well.
Thanks, Jason
Hide Signatures
       Post #: 11
RE: Down and Locked New Product - 12/18/2012 10:54 PM
mario tavarez14
Status: offline
Definitely I will get one of the down and locked new products
Kingtech 140-G 2 JETCAT P-140-RX P-180-RX P-120-P-80
FEJ F-15 E/ FEJ F86/FEJ 1/3 hawk/ cessna 182 1/3 scale/comp arf e
Hide Signatures
       Post #: 12
RE: Down and Locked New Product - 12/18/2012 11:55 PM
Down and Locked
Status: offline
David if I didn't tell you to disconnect the battery when the retract reached it's travel limit you should kick me in the butt the first chance you have. LOL
Hide Signatures
       Post #: 13
RE: Down and Locked New Product - 12/19/2012 12:27 AM
David Searles
Status: offline
I'll hang on to that option as a "Get Out of Jail Free" card for the future! I'm sure I'll be able to use it at some point!
David S
Hide Signatures
       Post #: 14
RE: Down and Locked New Product - 12/19/2012 12:24 PM
DAVAL
Status: offline
I just installed a set of Down & locked in my Xtreme Jet F-86, So smooth. I couldn't be happier.
Dave
JETS
Hide Signatures
       Post #: 15
RE: Down and Locked New Product - 12/19/2012 2:54 PM
757Driver
Status: online
http://www.youtube.com/watch?v=9-MIqnQNhSE&feature=youtube_gdata_player
Thanks, Jason
Hide Signatures
(in reply to DAVAL)
       Post #: 16
RE: Down and Locked New Product - 12/19/2012 5:29 PM
corndog2
Last Login: 1/19/2013
Status: offline
Wont a servo tester for $10 do almost the same thing ?
Hide Signatures
       Post #: 17
RE: Down and Locked New Product - 12/20/2012 11:43 PM
757Driver
Status: online
NO
Thanks, Jason
Hide Signatures
(in reply to corndog2)
       Post #: 18
RE: Down and Locked New Product - 12/21/2012 12:31 AM
mario tavarez14
Status: offline
i use a servo tester and i only recycle my gear twice, them one of my gear motor burn , i will not recommend to no body to use them
Hide Signatures
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.047RCU1
