SKYMASTER Hawk 100 build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> SKYMASTER Hawk 100 build
Page: [1] 2   next >   >>
Login
SKYMASTER Hawk 100 build - 12/17/2012 9:59 PM
geh3
Score: 100
Last Login: 5/19/2013
Status: offline
OK here at  http://rcaircraft-specialties.com/ I'm starting a new build for a customer
it is a SKYMASTER HAWK 100. It will have some nice equipment in it including the new POWERBOX IGYRO!
so I will post pictures and tips here. I am also following the BVM Upgrades as listed in their upgrade manual
Starting with the flap install.. This just takes patience and skills with a Dremel ! ( how could we build awsome planes without a DREMEL????)
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
WREN TURBINES USA...GO GREEN!
ALSO SEE: http://www.rcaircraft-specialties.com/
Hide Signatures
       Post #: 1
RE: SKYMASTER Hawk 100 build - 12/17/2012 10:02 PM
geh3
Score: 100
Status: offline
The main LG units are quite robust, mounted to a strong ply/CF sandwich with SS screws
and all of the accordian doors work smoothly!
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 2
RE: SKYMASTER Hawk 100 build - 12/18/2012 2:08 PM
geh3
Score: 100
Status: offline
Flap hinges all done, now they get some scale fairings around them these look very effective!!!
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 3
RE: SKYMASTER Hawk 100 build - 12/18/2012 2:34 PM
Bob_B
Score: 100
Status: online
Nice work George!
Cincinnati Jet Club, Team Futaba, Wren Turbines USA
Hide Signatures
(in reply to geh3)
       Post #: 4
RE: SKYMASTER Hawk 100 build - 12/18/2012 3:50 PM
megafly
Score: 100
Last Login: 5/17/2013
Status: offline
Very nice!
Hide Signatures
(in reply to Bob_B)
       Post #: 5
RE: SKYMASTER Hawk 100 build - 12/19/2012 2:04 AM
hooker53
Score: 100
Status: online
Gee George. Those gear doors sure fit nice. Great work.
Scratch it till it bleeds Convert it till it chokes
Hide Signatures
(in reply to megafly)
       Post #: 6
RE: SKYMASTER Hawk 100 build - 12/19/2012 2:53 AM
FenderBean
Score: 119
Status: offline
I really like those colors
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
(in reply to hooker53)
       Post #: 7
RE: SKYMASTER Hawk 100 build - 12/19/2012 4:45 PM
geh3
Score: 100
Status: offline
WOW
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to FenderBean)
       Post #: 8
RE: SKYMASTER Hawk 100 build - 12/24/2012 12:27 AM
pilot tw
Score: 103
Status: offline
quote:
ORIGINAL: geh3
WOW
Great Job ,...wow
owner - Skymaster Jet
X-Treme Jets
Hide Signatures
(in reply to geh3)
       Post #: 9
RE: SKYMASTER Hawk 100 build - 12/24/2012 5:38 PM
geh3
Score: 100
Status: offline
OK the cockpit is all done.. it is finished per the guidance in the BVM supplementary manual, the 2 tubs
are attached to the inside of the canopy tray with small FH screws.. you have to do a bit of tricky Dremel work here
to get this right! it looks quite nice when done. I painted the interior of the canopy frame + the interior of the front fuse
around the to hide the "cream" colored FG, makes it all look better. One note here, Skymaster installed the "Tailormadedecal"
MDC system on the OUTSIDE of the canopy! They did do a good job centering it and getting it on smooth BUT with use, it would last
MUCH LONGER if it were installed as designed on the inside of the canopy. This IS a tricky install.. see attached .pdf. I have done these using the "wet" method
as well but I believe that the method shown here is better.
Click for fullsize
Click for fullsize
Click for fullsize
Click to see the file in new window.Attachment.pdf
< Message edited by geh3 -- 12/25/2012 6:31 AM >
Hide Signatures
(in reply to pilot tw)
       Post #: 10
RE: SKYMASTER Hawk 100 build - 12/24/2012 5:42 PM
geh3
Score: 100
Status: offline
Equipment trays in progress, the front tray is supplied by Skymaster, the rear one I fabricated
These are mounted low so there is room to mount equipment under the cockpit tubs!
the front one will be for the Powerbox + rx batteries. The rear one for the Turbine support stuff
These have been primed with light gray auto primer
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 11
RE: SKYMASTER Hawk 100 build - 12/25/2012 3:27 AM
smchale
Score: 115
Status: online
Looking good. You are going to add a pilot or two right?
Sean McHale
"Strive for simplicity. You never have to repair what you leave out." - Bill Lear
Hide Signatures
(in reply to geh3)
       Post #: 12
RE: SKYMASTER Hawk 100 build - 12/25/2012 6:30 AM
geh3
Score: 100
Status: offline
That will be up to the customer but probably..
Hide Signatures
(in reply to smchale)
       Post #: 13
RE: SKYMASTER Hawk 100 build - 12/25/2012 6:47 PM
geh3
Score: 100
Status: offline
I set the rear fuselage air brake up
it works fine but might need some restrictors
in the airline to make it move at a more scale speed...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 14
RE: SKYMASTER Hawk 100 build - 12/28/2012 1:44 PM
geh3
Score: 100
Status: offline
See latest pictures HERE>>>>>   http://www.rcjetaddiction.com/photo/albums/skymaster-hawk-100-build
OK they finally uploaded ( THANKS R/C U)
Almost done, just needs some more internal gear install...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by geh3 -- 12/29/2012 1:19 PM >
Hide Signatures
(in reply to geh3)
       Post #: 15
RE: SKYMASTER Hawk 100 build - 1/17/2013 5:47 PM
geh3
Score: 100
Status: offline
Servo install underway, aileron servo here.. it is a tight fit with these
JR HV servos, but doable.. 1 wing done #2 in process.
No room here to use SWB or similar arms without requiring
opening up the bottom wing surface ( no-no)
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 16
RE: SKYMASTER Hawk 100 build - 1/17/2013 5:50 PM
geh3
Score: 100
Status: offline
Elevator servo install. I put the fuse in a "0-0" position using an incidence meter
Then I positioned the stab at "0-0" using that meter. Once established I set the servos
at neutral and that enabled me to locate and drill the locator holes for the servos..
this results in a nice tight and slop free install...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 17
RE: SKYMASTER Hawk 100 build - 1/17/2013 9:47 PM
geh3
Score: 100
Status: offline
all done, VERY solid, no detectable free play
and quite smooth when powered up....
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 18
RE: SKYMASTER Hawk 100 build - 1/27/2013 5:15 PM
geh3
Score: 100
Status: offline
Radio board and air control boards all done. There are no air tubing visible when the cockpit+canopy is removed.
Also there are no servo wires visible except for the ends that plug into the PB SRS unit!!
The air board has valves for the Wheel brakes, scale air brake on the fuse rear, main LG,
Main LG doors, and Front LG doors!
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 19
RE: SKYMASTER Hawk 100 build - 1/28/2013 1:47 PM
Meesh
Score: 100
Status: offline
Nice neat work George! As usual!
Bob
If it''s worth doing, it''s worth doing it right.
AMA 779352, JPO 1965, IMAA 40337
Hide Signatures
(in reply to geh3)
       Post #: 20
RE: SKYMASTER Hawk 100 build - 1/29/2013 2:17 PM
geh3
Score: 100
Status: offline
Hiding wires and tubing under the turbine support board...
al is hidden and neat!
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Meesh)
       Post #: 21
RE: SKYMASTER Hawk 100 build - 1/29/2013 4:42 PM
afterburner
Score: 110
Status: offline
quote:
ORIGINAL: geh3
around the to hide the ''cream'' colored FG, makes it all look better. One note here, Skymaster installed the ''Tailormadedecal''
MUCH LONGER if it were installed as designed on the inside of the canopy. This IS a tricky install.. see attached .pdf. I have done these using the ''wet'' method
Nice job George. Is that Tailormade MDC install pdf. from the BVM addendum? I wish I had that when doing my CARF Hawk canopy. I'm surprised they put that on the outside. It's pretty delicate.
Marty
Hide Signatures
(in reply to geh3)
       Post #: 22
RE: SKYMASTER Hawk 100 build - 1/29/2013 4:52 PM
geh3
Score: 100
Status: offline
It does look like the Tailormade one.. and yes it is on the outside.
Hide Signatures
(in reply to afterburner)
       Post #: 23
RE: SKYMASTER Hawk 100 build - 1/29/2013 5:46 PM
kingair41
Score: 100
Status: offline
Hey George, is there going to be a fuse center tank on this one.
I was wondering if Skymaster has locating marks on the fuse where the tank gets mounted.
FB L-39, FB Hawk, FEJ Large Hawk.......
Hide Signatures
(in reply to geh3)
       Post #: 24
RE: SKYMASTER Hawk 100 build - 1/29/2013 6:12 PM
dubd
Score: 135
Status: offline
quote:
ORIGINAL: geh3
Mine is on the outside too. I would prefer it to be on the inside, but it's held up after a year.
Hide Signatures
(in reply to geh3)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.686RCU1
