hair spray a sanding sealer    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Mikado Logo XXTREME Combo - RTF
Seller:  Hegemonoius
Details:   $2,975.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> hair spray a sanding sealer
Page: [1] 2   next >   >>
Login
hair spray a sanding sealer - 12/18/2012 5:19 PM
kitman09
Score: 100
Last Login: 5/22/2013
Status: offline
hi, i am fixing to start covering a dynaflite pt-19 with 100% polyester dress lining and polycrylic. was wondering if i could use aqunet hair spray as a sealer first since it is a laquer, to seal the wood
thanks.
Hide Signatures
       Post #: 1
RE: hair spray a sanding sealer - 12/18/2012 6:48 PM
Steve Percifield
Score: 108
Last Login: 5/21/2013
Status: offline
I've never tried it, but have read where guys do it. Honestly, I can;t imagine it would work very well.
_____________________________
Sir Percy
Hoosier Dawn Patrol
Hide Signatures
(in reply to kitman09)
       Post #: 2
RE: hair spray a sanding sealer - 12/18/2012 7:01 PM  1 votes
jaka
Score: 158
Status: offline
Hi!
Sounds like a very expensive metod! Why not doing it the old way of brushing dope on?
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 3
RE: hair spray a sanding sealer - 12/18/2012 7:28 PM
HighPlains
Score: 152
Status: offline
It's actually pretty cheap way to lightly seal the wood. I use it on wing sheeting for foam cores to limit the amount of glue absorbed by the wood.
- Supplementary insipid innocuous inane vacuous proclamation
Hide Signatures
(in reply to jaka)
       Post #: 4
RE: hair spray a sanding sealer - 12/18/2012 8:20 PM
sensei
Score: 176
Status: offline
Some guys use it to seal the balsa wood before covering with Monokote or Ultra Coat.
Bob
Fly It Like You Stole It!!!
Hide Signatures
(in reply to HighPlains)
       Post #: 5
RE: hair spray a sanding sealer - 12/18/2012 8:37 PM
huck1199
Score: 115
Last Login: 5/18/2013
Status: offline
Works well and smells good too.
Hide Signatures
(in reply to sensei)
       Post #: 6
RE: hair spray a sanding sealer - 12/18/2012 9:09 PM
red head
Score: 135
Status: offline
The price is cheap if you get it at a dollar store. I've used it for years to help activate the adhesive on covering, especially if I'm recovering an old airframe . It also helps seal when there is some oil soak, that is if you got most of the oil out first. Kitty litter, electronic cleaner, baking soda or what ever you use to get the oil out . ENJOY !!! RED
Hide Signatures
(in reply to huck1199)
       Post #: 7
RE: hair spray a sanding sealer - 12/18/2012 11:58 PM
Gray Beard
Score: 314
Status: offline
quote:
ORIGINAL: sensei
Bob
As a sealer?? Probably no? I do keep a big can of the really cheap lacquer hair spray in my shop to do as sensei said before using covering. Usually a recover in case there is still a bit of oil on the wood. The hair spray melts/softens with the irons heat and gets the covering to stick really well. For sealer I use Deft Sanding lacquer sealer and it will seal the wood and if you need to you can add an extra coat or two so the wood grain is filled. I use the deft to glass with but on a plane just getting covered with plastic film there is no reason for it. It too softens with the irons heat but it adds more weight then just a mist of hair spray. I have never tried it with the dress lining. Sense the advent of Solartex I haven't used silk or dress lining.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
       Post #: 8
RE: hair spray a sanding sealer - 12/19/2012 1:57 AM
jetmech05
Score: 133
Status: offline
I have used it myself..you want the cheap hairspray....sand smooth then a light coat....helps the covering iron down better as well...works like a charm
Hide Signatures
(in reply to Gray Beard)
       Post #: 9
RE: hair spray a sanding sealer - 12/19/2012 2:45 AM
dant-RCU
Score: 100
Status: offline
+1
Dan Taylor
American Turf Flyers, Inc.
Hide Signatures
(in reply to jetmech05)
       Post #: 10
RE: hair spray a sanding sealer - 12/19/2012 5:07 AM
Andrewmc
Score: 105
Status: offline
Hi Gray Beard
What do you use to apply the sanding sealer? A brush (conventional) or an air brush spray? Do you thin it down first or apply straight out of the tin?
I have a cub which I have been building for about 10 years (no joke) and it is at the stage where I need to paint the cockpit. I tried applying primer but it has gone powdery and I am debating using a sanding sealer - after cleaning of the dud primer before adding the topcoat.
Andrew
Hide Signatures
       Post #: 11
RE: hair spray a sanding sealer - 12/19/2012 11:35 AM
sensei
Score: 176
Status: offline
quote:
ORIGINAL: Gray Beard
quote:
ORIGINAL: sensei
Bob
Yes, I stand corrected; it seals down all those little whiskers on the balsa, while providing a smooth lightweight base for the iron on covering films...
Bob
Hide Signatures
       Post #: 12
RE: hair spray a sanding sealer - 12/19/2012 4:10 PM
ma_mulcahy
Score: 100
Status: offline
And if your build is getting frustrating, just put an ignition source between Aquanet and your bird and you can start all over again. A buddy of mine tried a number of fuel sources for his PVC potato gun and found Aquanet to be the best propellant!
Mike
Waco Brotherhood #215/Ultra Sport Brotherhood #126
Hide Signatures
       Post #: 13
RE: hair spray a sanding sealer - 12/19/2012 4:35 PM
stoneenforcer
Score: 100
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: kitman09
thanks.
yes you can.
Hide Signatures
       Post #: 14
RE: hair spray a sanding sealer - 12/19/2012 6:12 PM
Gray Beard
Score: 314
Status: offline
quote:
ORIGINAL: Andrewmc
Hi Gray Beard
Andrew
I have just never tried hair spray as a sealer and don't know if it works as a sealer or not. I only have used it when doing covering repairs.
I also never seal the frame with real sanding sealer if I'm going to use covering.
I use deft Sanding lacquer Sealer to glass my planes instead of resin is all.
I do not use the water based sealer and I use it full strength right out of the can with a brush. About 80% of the chemicals in it gas off so there isn't a lot of weight left behind. I do brush on two coats onto the bare wood then sand before I start to lay on the glass. It's just to keep the glassing coats from absorbing into the wood and being wasted.
My thinking is a sealer is supposed to seal up the wood pores and make the wood smooth so I think the hair spray wouldn't make a good sealer. It does really help in holding covering onto the wood. I'm trying to remove the covering off of my old pattern plane that someone used hair spry on the wood and it is really hell trying to get it off.
The Deft will fill in the wood grain and probably hold down covering too? I'm just not sure, I have never used it on a plane getting covered? If you want to use it then paint make sure the paint you use is lacquer based!!!
Hide Signatures
(in reply to Andrewmc)
       Post #: 15
RE: hair spray a sanding sealer - 12/19/2012 10:36 PM
dbacque
Score: 137
Status: offline
quote:
ORIGINAL: ma_mulcahy
Yep, that's the stuff for a spud gun! According to the potato cannon gurus it is because it contains the highest percentage of butane. I don't know if that's true but dang, those chicks will put some weird stuff on their hair!
Dave
Hide Signatures
(in reply to ma_mulcahy)
       Post #: 16
RE: hair spray a sanding sealer - 12/20/2012 12:51 AM
larryak
Score: 105
Last Login: 3/24/2013
Status: offline
I would be afraid that someone out at the club may wink at me.
Hide Signatures
(in reply to dbacque)
       Post #: 17
RE: hair spray a sanding sealer - 12/20/2012 5:54 AM
oskartek
Score: 130
Status: offline
Don't worry larryak, only your hairdresser would know for sure
Happy flyin', Oscar
A man that hates kids and dogs cant be all bad. But then, Ive met some dogs that I liked.
Hide Signatures
(in reply to larryak)
       Post #: 18
RE: hair spray a sanding sealer - 12/20/2012 11:20 AM
TomCrump
Score: 116
Status: online
The intent of using hair spray is to aid in adhesion, not to seal the wood. Lacquer based hair sprays are sometimes used as substitutes for products such as Balsarite.
I only use hair spray if I am covering with Solartex, Monokote, etc, whic alreay have a heat activated adhesive. I would not use it with any product, such as dress lining.
Tom C
Hide Signatures
(in reply to oskartek)
       Post #: 19
RE: hair spray a sanding sealer - 12/20/2012 11:38 AM
sensei
Score: 176
Status: offline
quote:
ORIGINAL: TomCrump
Yes, but it does seal down the whiskers and leaves everything real slick.
Bob
Hide Signatures
(in reply to TomCrump)
       Post #: 20
RE: hair spray a sanding sealer - 12/20/2012 11:51 AM
TomCrump
Score: 116
Status: online
Is slick a good thing ?
When I sealed balsa, before glassing with Poly C, I ran into adhesion problems between the two components. The Poly laid on top of the sealer, instead of penetrating the wood.
The OP doesn't state how he plans to adhere his dress lining to the airframe, but to me, the idea would be to create a composite. The lining is placed over the wing, and whatever adhesive is applied over it, soaking through the lining, and into the wood. This makes a nice, strong bond. Creating a barrier, by sealing the wood, could easily weaken the process, by not allowing the adhesive to penetrate the balsa.
I may be wrong, Bob. These are just my observations.
Tom C
Hide Signatures
       Post #: 21
RE: hair spray a sanding sealer - 12/20/2012 12:10 PM
sensei
Score: 176
Status: offline
I have used Stits covering system on all the full scale airplanes I have built over the years as well as some models, if there is any areas that are not open bay areas and are sheeted instead, then I used 3/4 oz. class and Poly C in those areas and overlaped onto them about 2.00" with the Stits covering system and finally prime and topcoat. Now if I am going to Monokote an airplane then yes the slick balsa finish is better for me because I strive for a 12" stand off show quality finish on all my builds and everything under a plastic covered airplane shows.
Bob
< Message edited by sensei -- 12/20/2012 12:59 PM >
Hide Signatures
       Post #: 22
RE: hair spray a sanding sealer - 12/20/2012 2:54 PM
kitman09
Score: 100
Status: offline
thanks tom, i plan on using the poly to adhere the dress lining to the frame. so you dont use a sealer when using poly. this dont warp the wood frame.
Hide Signatures
       Post #: 23
RE: hair spray a sanding sealer - 12/20/2012 3:01 PM
TomCrump
Score: 116
Status: online
Use Poly in thin coats. This will keep any warpage to a minimum.
Tom C
Hide Signatures
       Post #: 24
RE: hair spray a sanding sealer - 12/21/2012 1:26 AM
telejojo
Score: 130
Status: offline
It's just a water based sizing or how would you wash it out of hair.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.765RCU1
