Tire changing    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car General Discussions >> Tire changing
Page: [1]
Login
Tire changing - 12/19/2012 9:16 PM
JollyPopper
Score: 163
Last Login: 6/20/2013
Status: offline
This is probably a very basic question for those of you who know the answer but I am a total newbie in cars and trucks. The question concerns replacing a set of tires on a stadium truck. I understand these things are glued on with CA. How can the existing tires be removed if they are glued with CA. That stuff is tough.
_____________________________
"In theory, there is no difference between theory and practice; In practice, there is"
Hide Signatures
       Post #: 1
RE: Tire changing - 12/19/2012 9:45 PM
proptop
Score: 130
Last Login: 6/5/2013
Status: offline
One method is to soak the wheel / tire in Acetone...
I've used a small butter tub w/ snap on lid...put a half inch or so of Acetone and wheel in and snap on the lid...let it soak for an hour or two...the soaked side will come off the rim....then flip over and do the other side. It takes a while...but the rims will be re-useable afterward. (after cleaning glue residue off )
Some guys say to boil them in water...but that method never worked for me.
After doing the above several times, it's MUCH easier to just buy new rims...(less grumbling, %^#@*!etc. etc. )
It is bad luck to be superstitious...
Steuben Red Barons, Paradise R/C Flyers, RAAM
Hide Signatures
(in reply to JollyPopper)
       Post #: 2
RE: Tire changing - 12/19/2012 9:51 PM
mattster1971
Score: 129
Last Login: 6/15/2013
Status: offline
I have boiled them with success before, its just a little dangerous, risk of burns when messing with boiling water. Boiling will usually cause any special finish to come off also like the fake chrome coloring that's on some Traxxas wheels, not sure what acetone would do to the finish. It took about 10 minutes soaking at full boil for them to come loose, the only downside is if you are trying to save the rims your good, in my case I was trying to save the tire and replace a broken rim and the tire still had all the crusty hard glue on it when this boiling procedure was done and so it was really a pain to get them glued onto new rims. I am betting the acetone removes the glue so that might have been a better option in my situation.
Traxxas Jato 3.3 Custom(2), HoBao Hyper 7(2), Associated MGT 4.6, Kyosho Javelin. Its better to be feared than loved.
Hide Signatures
(in reply to proptop)
       Post #: 3
RE: Tire changing - 12/19/2012 11:24 PM
phmaximus
Score: 632
Status: offline
Nothing works that great, ive had some success with boiling, but I burnt all my finger tips lol
That method wont work with traxxas revo wheels
Acetone is great for removing chrome of the rims, just soak over night and it basicky falls off.
Losi Micro SCT,5IVE,8IGHTe
Tamiya BajaKing,TA01R,TL01B
Hide Signatures
(in reply to mattster1971)
       Post #: 4
RE: Tire changing - 12/19/2012 11:30 PM
SyCo_VeNoM
Score: 626
Status: online
quote:
ORIGINAL: proptop
ditto
cut tire rip off dremel the left over off the rim to smooth it if I want to save the rim
I've also cut the rim off of a tire before (the rim stripped but the was still essentially new) that took a lot more finesse
boiling I had 50/50 results 2 tires came off pretty easy other 2 ripped
tried it once after nothing came off which leads me o believe the 2 that came off were glued poorly(I got them with a used truck)
Other thing I've done was run a screw driver along the rim to break the glue. this works decently on some crome RTR rims as some companies are too lazy to strip the chrome off prior to gluing and the chrome peels off nice and easy(which you have to pretty much to anyways)
With great speed comes greater repair bills.
Look at my garage for my model list.
Hide Signatures
       Post #: 5
RE: Tire changing - 12/20/2012 12:28 AM
On2_n_On4
Score: 131
Status: online
I have done it both ways (boiling/acetone) many times with no issues. only thing is, boiling is a lot cheaper
just make sure you have a good pair of gloves... it gets HOT., it will save your fingers and make the whole process a lot easier.
If you go with the acetone., test a small area first, some traxxas and tamiya wheels wont be happy
Inferno GT2 - RS4 2 - Baja 5T - Revo 3.POS - Tmaxx 3.POS
Hide Signatures
(in reply to SyCo_VeNoM)
       Post #: 6
RE: Tire changing - 12/23/2012 2:30 AM
Sigma.40
Score: 199
Last Login: 4/27/2013
Status: offline
I just changed the tires on Stampede 4x4 by boiling them. I boiled them for 10 minutes then pulled them out with tongs, put them in the sink and chiseled at them with a butter knife. It worked fairly well and I didn't lose any of the chrome.
HPI Baja 5SC, TLR 8ight 2.0, Traxxas Stampede 4x4 VXL and one very pissed off wife.
Hide Signatures
(in reply to On2_n_On4)
       Post #: 7
RE: Tire changing - 12/23/2012 4:56 AM
t-max97
Score: 173
Status: offline
Ive done it a few times just by boiling them and it worked fine, easy to burn your fingers though.
If you dont know what your doing, its best to do it quickly.
Hide Signatures
(in reply to Sigma.40)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.094RCU1
