RE: Skylark 56 – 1966 Flashback - Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> RE: Skylark 56 – 1966 Flashback - Build
Page: <<   < prev  1 2 3 4 [5] 6 7 8 9   next >   >>
Login
RE: Skylark 56 – 1966 Flashback - Build - 1/22/2013 10:41 PM
8178
Score: 131
Last Login: 5/25/2013
Status: online
The 1/4” X 1/6” rib cap strips are installed, top and bottom. It is interesting how much strength the cap strips add to the ribs. Sanding the trailing edge basswood down to a fine 1/6” edge and blending in with the sheeting. Added some triangle pieces to strengthen gear block mounting and test fitting the main gear strut.
To be continued…
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to 8178)
       Post #: 101
RE: Skylark 56 – 1966 Flashback - Build - 1/25/2013 1:36 AM
8178
Score: 131
Status: online
Working on the wingtip block. I use the round loop X-acto router blade to carve out the block.
To be continued…
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to 8178)
       Post #: 102
RE: Skylark 56 – 1966 Flashback - Build - 1/26/2013 8:36 PM
8178
Score: 131
Status: online
Working on the aileron. In these images the aileron line has been cut in the sheeting and part way into the ribs with an X-acto knife.
To be continued…
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to 8178)
       Post #: 103
RE: Skylark 56 – 1966 Flashback - Build - 1/26/2013 8:39 PM
8178
Score: 131
Status: online
Using a very thin fine tooth hobby saw I cut through the ribs.
To be continued…
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to 8178)
       Post #: 104
RE: Skylark 56 – 1966 Flashback - Build - 1/26/2013 8:41 PM
8178
Score: 131
Status: online
I/16” sheet glued to the back edge of the wing.
To be continued…
Click for fullsize
Hide Signatures
(in reply to 8178)
       Post #: 105
RE: Skylark 56 – 1966 Flashback - Build - 1/26/2013 8:45 PM
8178
Score: 131
Status: online
Aileron cut away from the center wing part and the aileron torque tube linkage. The aileron torque tube is an unused part from my Tiporare kit.
To be continued…
Click for fullsize
Hide Signatures
(in reply to 8178)
       Post #: 106
RE: Skylark 56 – 1966 Flashback - Build - 1/26/2013 9:53 PM
8178
Score: 131
Status: online
After cutting out the aileron the wing was ready for the tip block.
To be continued…
Click for fullsize
Hide Signatures
(in reply to 8178)
       Post #: 107
RE: Skylark 56 – 1966 Flashback - Build - 1/26/2013 9:57 PM
8178
Score: 131
Status: online
The back edge of the wing sanded out.
To be continued…
Click for fullsize
Hide Signatures
(in reply to 8178)
       Post #: 108
RE: Skylark 56 – 1966 Flashback - Build - 1/26/2013 10:43 PM
8178
Score: 131
Status: online
The wing tip block sanded out smooth with the wing.
To be continued…
Click for fullsize
Hide Signatures
(in reply to 8178)
       Post #: 109
RE: Skylark 56 – 1966 Flashback - Build - 1/27/2013 1:02 AM
8178
Score: 131
Status: online
Test fitting the aileron linkage. The nearest bay to the center of the wing on the trailing edge is filled with a balsa wedge. The extra balsa will be part of the nylon bolt mount for the back of the wing.
To be continued…
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to 8178)
       Post #: 110
RE: Skylark 56 – 1966 Flashback - Build - 1/27/2013 1:13 AM
8178
Score: 131
Status: online
The torque tube is countersunk into the trailing edge to get its center of rotation as near as possible to the hinge line and epoxied in place.
To be continued…
Click for fullsize
Hide Signatures
(in reply to 8178)
       Post #: 111
RE: Skylark 56 – 1966 Flashback - Build - 1/27/2013 3:17 AM
8178
Score: 131
Status: online
The front 5/16" of the aileron was cut off and a ¼” piece added and then beveled on the top and bottom.
1/16” was cut off the front of the center tailing edge and was glued back on with a combination of glue. Epoxy glue was used where the ribs support the torque tube and yellow glue at the sheeting seams.
To be continued…
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to 8178)
       Post #: 112
RE: Skylark 56 – 1966 Flashback - Build - 1/27/2013 3:18 AM
8178
Score: 131
Status: online
A brass tube gizmo was made and soldered to aileron linkage for the clevis connection.
To be continued…
Click for fullsize
Hide Signatures
(in reply to 8178)
       Post #: 113
RE: Skylark 56 – 1966 Flashback - Build - 1/27/2013 4:52 AM
KLXMASTER14
Score: 105
Status: offline
Ultra sweet!!!!!
-Robert
_____________________________
2012 NSRCA D7 Intermediate Champion
West Coast Regional Director- Classic Pattern Assn
Hide Signatures
(in reply to 8178)
       Post #: 114
RE: Skylark 56 – 1966 Flashback - Build - 1/27/2013 7:20 PM
8178
Score: 131
Status: online
The top center sheeting is on. So far so good and it is building straight and true.
To be continued…
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to KLXMASTER14)
       Post #: 115
RE: Skylark 56 – 1966 Flashback - Build - 1/27/2013 7:22 PM
8178
Score: 131
Status: online
I’m leaving the bottom sheeting off until I finish the left wing so I have access for measurements if needed.
To be continued…
Click for fullsize
Hide Signatures
(in reply to 8178)
       Post #: 116
RE: Skylark 56 – 1966 Flashback - Build - 1/27/2013 7:26 PM
8178
Score: 131
Status: online
quote:
ORIGINAL: KLXMASTER14
Ultra sweet!!!!!
-Robert
Thanks Robert. It is much fun! I haven’t used the cut out aileron process on a built up wing in decades but it seems to be going fine.
Hide Signatures
       Post #: 117
RE: Skylark 56 – 1966 Flashback - Build - 1/27/2013 10:34 PM
doxilia
Score: 136
Status: offline
quote:
ORIGINAL: 8178
... but it seems to be going fine.
Mike,
When you're at the helm, it always does.
If you were to make a mistake, we would never know unless you told us.
I think I'm going to have to get me one of them balsa colored carpets..., your pictures always look great!
Can't wait to see the fuse.
David
Hide Signatures
(in reply to 8178)
       Post #: 118
RE: Skylark 56 – 1966 Flashback - Build - 1/28/2013 10:08 PM
8178
Score: 131
Status: online
Here we go again! The left wing panel top front sheeting.
To be continued…
Click for fullsize
< Message edited by 8178 -- 1/29/2013 1:45 AM >
Hide Signatures
(in reply to doxilia)
       Post #: 119
RE: Skylark 56 – 1966 Flashback - Build - 1/28/2013 10:14 PM
8178
Score: 131
Status: online
quote:
ORIGINAL: doxilia
quote:
ORIGINAL: 8178
Mike,
David
Thanks for the comments David. I did almost glue one of the plywood gear mount doublers to the wrong rib but I caught it right away and got the epoxy off the rib! If you see me building two right wing panels let me know right away.
I’m looking forward to the fuselage too. I have the wood and I’m just thinking through if I want to use the G-21 46 or one of my more powerful engines.
Hide Signatures
       Post #: 120
RE: Skylark 56 – 1966 Flashback - Build - 1/29/2013 7:04 AM
doxilia
Score: 136
Status: offline
quote:
ORIGINAL: 8178
Mike,
Glad you told us. It makes me feel a little more human. I managed to leave a stab setting with epoxy while I went to pick up my kid from school. Naturally I was late as "it always takes longer" when you're building. Needless to say, when I came back, I wasn't too happy with what I saw... But that was a while ago.
We will..., in the extremely unlikely event!
What are the other options? Knowing how you like to set things up, I wouldn't be surprised if we wind up seeing a 55 up there.
This thread is just cookin'! You're making excellent progress.
David
Hide Signatures
(in reply to 8178)
       Post #: 121
RE: Skylark 56 – 1966 Flashback - Build - 1/29/2013 6:46 PM
8178
Score: 131
Status: online
Added the lower front and tailing edge sheeting. Epoxied in the landing gear block plywood rib dubblers and gear block.
To be continued…
Click for fullsize
< Message edited by 8178 -- 1/30/2013 10:05 PM >
Hide Signatures
       Post #: 122
RE: Skylark 56 – 1966 Flashback - Build - 1/29/2013 11:35 PM
8178
Score: 131
Status: online
Ended up using about 1/2” of dihedral under each wing tip. Just enough that it is noticeable and keep from having the straight wing look.
To be continued…
Click for fullsize
Click for fullsize
< Message edited by 8178 -- 1/30/2013 2:55 PM >
Hide Signatures
(in reply to 8178)
       Post #: 123
RE: Skylark 56 – 1966 Flashback - Build - 1/30/2013 6:15 PM
8178
Score: 131
Status: online
Installing the internal aileron parts; hinge points, end caps and linkage mount before adding the top sheeting on the left wing panel.
A small cut was made at the aileron ends so I can find the ends when the top sheeting is installed.
To be continued…
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to 8178)
       Post #: 124
RE: Skylark 56 – 1966 Flashback - Build - 2/2/2013 4:57 PM
8178
Score: 131
Status: online
Working on the left wing panel. The top trailing edge, rib cap strips and center sheeting is on along with the 1/8” X 3/16” basswood strip on the trailing edge. The lower sheeting is not installed yet so I can add some sheer webs on the main spars.
Next, the wing tip block, sand down the basswood trailing edge, cut out and complete the aileron, install shear webs on the main spars, bottom center sheeting and make a 1/4” thick plywood center wing joiner that will fit between the upper and lower wing spar.
Sanding the basswood to an edge takes some effort but I think having a sharp hard edge is worth the extra work.
To be continued…
Click for fullsize
< Message edited by 8178 -- 2/3/2013 1:35 AM >
Hide Signatures
(in reply to 8178)
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
