Hobbsy
VA, USA Status: offline
My two oldest Saitos, an .80 and a 1.50 plus an Enya .46 MKII spent the first two years of their lives running on Fox 15% fuel with 20% castor lube. Other than their exhaust valves being slightly golden in color and the mufflers being stained you'd never know. Before I knew better, so as far as I'm concerned that business about castor being bad for fourstrokes is pure unadulterated bunk. Look in the Everything Diesel forum and see where I ran the .80 on Diesel fuel just for kicks.
_____________________________
Giant Saito, 73.2 Cu. In., 70.5HP @ 5,800 rpm, 79 ft. lbs torque @ 3,500 rpm, 57 mpg, 3.50 bore, 3.81 stroke. 563 lbs.
