Paint Gun Recommendations, Rivets & Panel lines???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Paint Gun Recommendations, Rivets & Panel lines???
Page: [1]
Login
Paint Gun Recommendations, Rivets & Panel lines??? - 12/21/2012 12:33 PM
Jetfan20
Score: 107
Last Login: 5/20/2013
Status: offline
Hi All,
I'm considering a project that would require painting, panel lines and raised rivets redone. This would be my first at all three.
My question are:
What do you guys recommend for a paint gun? What should I know about the painting process?
What are some of the techniques for panel lines and rivets?
Thanks in Advance!
Hide Signatures
       Post #: 1
RE: Paint Gun Recommendations, Rivets & Panel lines??? - 12/21/2012 12:55 PM
mirce
Score: 151
Status: online
Check here, you will find all answers...
www.nsmodelers.rs
Regards
Mirce
_____________________________
Rivets, Screws, Panel lines, Detail & Finish Sets, Paint Masks and other equipment for scale warbirds - www.nsmodelers.rs
Hide Signatures
(in reply to Jetfan20)
       Post #: 2
RE: Paint Gun Recommendations, Rivets & Panel lines??? - 12/21/2012 8:24 PM
ChuckC
Score: 100
Status: offline
On spray guns - depends on your budget and the size of your project and your compressor output. Oh and the type of paint and your painting facilities.
I have several; a Binks GT2000 (I think - it's been too long).
An Astro touch-up gun; it's really, really nice for the price and very high quality.
Harbor freight HVLP gravity fed - whatever their "top of the line" is. I use this for primer and less critical paint processes.
All of the above are gravity fed, with the cup on top; uses a lot less paint and tends to spray better for me. They are also HVLP, which means a lot of air at low pressure - bigger compressor needed. If you're going all out, then you really should have a good, large air filter in-line and a smaller one at the gun.
There's just a ton more information and a few excellent painters here (myself NOT included - I paint, just not excellently). I've actually got automotive quality paint jobs out of the Harbor Freight guns, just not as easy as the Binks or Astro. Binks was over $200, I think and the Astro was upper $100's. The HF one is like sub $50 before coupons.
If you're going to invest in a tool, this is really not a place to scrimp - you'll enjoy the higher quality guns so much more. If you're trying to get by and you don't have a big compressor, then the HF touch-up gun may work for you. You'll need some practice to set it up, but it's not horribly difficult. I love to paint and buff/detail it. Something majical about pulling the tape and paper off to reveal your masterpiece - uh that is, if you don't mess it up...
Chuck Carlisle
Hide Signatures
(in reply to mirce)
       Post #: 3
RE: Paint Gun Recommendations, Rivets & Panel lines??? - 12/21/2012 9:43 PM
FalconWings
Score: 121
Status: offline
I have a small, 5 gallon Craftsman quiet compressor (could use it indoors) and I paint with this:
http://compare.ebay.com/like/200864740993?_lwgsi=y<yp=AllFixedPriceItemTypes&var=sbar
I can paint a 1/8th size F-16 model easily, and it shoots so good! makes me look so much better than I am. Really good for clear too, and holds settings very well. Its really good value for the money.
David
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
(in reply to ChuckC)
       Post #: 4
RE: Paint Gun Recommendations, Rivets & Panel lines??? - 12/22/2012 3:48 AM
ChuckC
Score: 100
Status: offline
Wow, yeah that's a really nice gun for $100. Sharpe is good stuff. Can't believe it's that cheap. You can spray some of these guns with a smaller compressor by cranking up the pressure to compensate. They just aren't "HVLP" anymore. But they usually atomize great, still.
Chuck Carlisle
Hide Signatures
(in reply to FalconWings)
       Post #: 5
RE: Paint Gun Recommendations, Rivets & Panel lines??? - 12/22/2012 7:11 AM
DelGatoGrande
Score: 105
Status: offline
SATA MiniJet HVLP for me
my 2c
Best Regards George SKYMASTER-A/D JETS-JETCAT-POWERBOX www.rcjet.gr "props are for boats"
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.187RCU1
