engine heat range    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Moki 2.10
Seller:  thunderbolt-RCU
Details:   $250.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> SuperTigre Engines Support >> engine heat range
Page: [1]
Login
engine heat range - 12/21/2012 6:04 PM
DaveFri
Score: 100
Last Login: 5/18/2013
Status: offline
Would anyone know the aprox heat range on a ST S-90K? My fuel lines are touching the engine and are either getting hot and melting a bit or just getting chaffed or both.Either way it is putting a gouge in my lines.The way the lines come out of the firewall there is not much other places for the tubing to go and it is  rubbing the engine.I wanted to put something over the tubing where it touched the engine to keep this from happening. Have some Tech Flex but the heat limitis 255 degrees.Does the engine getter that hot?
           Any ideas of what i could  use to sheath the fuel line where it hits the engine?
                                               Dave
Hide Signatures
       Post #: 1
RE: engine heat range - 1/14/2013 3:23 PM
Bax
Score: 169
Last Login: 5/20/2013
Status: offline
We've had well-running glow engines that topped 375 degrees F at the cylinder head where it joins the case. This was measured with a contact probe at the rear, where the air stagnates. A well-running engine will get hot enough to cause severe burns if touched. The muffler especially so.
Basically, though, just ignore temperature. Don't let anything touch the engine or muffler, except fuel lines attaching at the appropriate nipples. Use silicon surgical tubing for the fuel lines and muffler pressure line and you'll be OK. Other types of plastic or rubber tubing won't be as good.
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
Hide Signatures
(in reply to DaveFri)
       Post #: 2
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> SuperTigre Engines Support >> engine heat range
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.188RCU1
