RE: Waltersons 105 Full Review    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> RE: Waltersons 105 Full Review
Page: <<   < prev  1 2 [3]
Login
RE: Waltersons 105 Full Review - 1/7/2013 10:20 PM
MAUS45
Score: 100
Last Login: 5/22/2013
Status: online
This one Dan. FreakyDude posted at the beginning of this thread.
Click to see fullsize image.
Click for fullsize
_____________________________
3 Tamiya''s Tiger I, Tiger II, Panther G, 3 HL Stug III G, 1 HL Panzer III M, 1 Jagdpanzer IV L/70, 1 1/8 Tiger II
Hide Signatures
(in reply to YHR)
       Post #: 51
RE: Waltersons 105 Full Review - 1/7/2013 10:51 PM
YHR
Score: 204
Status: offline
Yes I know it functions, but from the picture you can't tell if it a floating torsion bar or not. I was just asking for some confirmation, which I have now got.
Cheers
Dan
Battle Armor R C
Hide Signatures
(in reply to MAUS45)
       Post #: 52
RE: Waltersons 105 Full Review - 1/7/2013 11:26 PM
Panther F
Score: 135
Last Login: 5/21/2013
Status: offline
You can clearly see that it doesn't act the same way the stock Mato did.
Cheers!
~ Jeff
Hide Signatures
(in reply to YHR)
       Post #: 53
RE: Waltersons 105 Full Review - 1/8/2013 3:15 AM
YHR
Score: 204
Status: offline
quote:
ORIGINAL: Panther F
Cheers!
~ Jeff
Yes, but that was not the question.
Dan
Battle Armor R C
Hide Signatures
(in reply to Panther F)
       Post #: 54
RE: Waltersons 105 Full Review - 1/9/2013 5:08 PM
wright 971
Score: 105
Last Login: 5/12/2013
Status: offline
Hi Dan Take very close look at the suspension you can see it pivots from the 2 pins(like the real one dose) ,having said that it does not work like the  original because the   sliding arms are fix.
  Can only think there is a spring (of some kind)pushing these slider arms apart so making it function similar to the real one,probably similar to HVSS suspenstion.
  All in all a good atempt at working suspension but they should have gone with the  Mato tracks and fitted a 75mm gun,after all the Panther had a 75mm gun as did the Panzer4 and Stug 3 ,so fitting a 105 so it can fire BBs dosnt hold water.
  regards pete
Hide Signatures
(in reply to YHR)
       Post #: 55
RE: Waltersons 105 Full Review - 1/9/2013 6:30 PM
YHR
Score: 204
Status: offline
OK Thanks Pete
I think what you are telling me is they are not like the Mato metal ones, as the Mato metal towers do have sliding arms that float. So this HL one functions and supplies suspension action, but not like the metal Mato sherman towers that function more like the prototype which is the answer to the question I am trying to get answered. Although Gorehounds assessment and yours are different, so I am not sure I got the answer or not
I will be getting one, and that is regardless of what the answer to the suspension question is. So in time I will find out for sure myself
Dan
Battle Armor R C
Hide Signatures
(in reply to wright 971)
       Post #: 56
RE: Waltersons 105 Full Review - 1/9/2013 7:14 PM
gorehound
Score: 100
Status: offline
Hi
Pete is correct in that the upper leg of the arms is fixed to the lower and it does not slide as the MATO one does. Inside the main part of the HL units are a couple of springs similar to those on the internal side of one of the Tiger Is that push against a spar on each leg roughly where the pins pivot which gives them the spring action unlike the MATO one which has the vertically mounted springs that push down on the two arms. I tried to take pics but I cannot get a good shot that shows this sorry - my camera skills rather than my camera.
The metal upgrade mato ones do work more like the real ones than the HL do but when viewed from the side when running the HL ones do operate a lot more like the real thing than the stock mato ones fitted to the tanks as standard. I am happy enough with them for now until something better replacement wise (perhaps like the Mato ones) as they are fine for running about.
I hope this helps.
Gorehound
Hide Signatures
       Post #: 57
RE: Waltersons 105 Full Review - 1/9/2013 7:36 PM
Panther F
Score: 135
Status: offline
I believe your question was only about if it acted the same way the ORIGINAL Mato did, not if it was perfect. It's plastic and having it work the same way the metal Mato does is impossible.
In my opinion the HL suspension works GOOD ENOUGH, it's the tracks that are not correct.
~ Jeff
Hide Signatures
(in reply to YHR)
       Post #: 58
RE: Waltersons 105 Full Review - 1/9/2013 7:40 PM
mustclime
Score: 106
Status: online
I wonder the the mato duckbill tracks will work....I think they are correct.....
That which does not destroy me just makes me more irritable
Hide Signatures
       Post #: 59
RE: Waltersons 105 Full Review - 1/9/2013 7:44 PM
Panther F
Score: 135
Status: offline
Mike said one of the two are the wrong diameter. Don't remember which one.
So, I have means to correct that if only my appliances will quit breaking down and the meds didn't cost an arm and a leg, maybe I can afford to look into it.
~ Jeff
Hide Signatures
(in reply to mustclime)
       Post #: 60
RE: Waltersons 105 Full Review - 1/9/2013 7:49 PM
gorehound
Score: 100
Status: offline
Hi
The stock Mato tracks won't fit as they are slightly wider and do not go round the HL sprocket. Also the road wheels are narrower as a result and have a lot of sideways play in the MAto (stock) tracks. I do not have a set of their metal ones to compare but if they are the same width as the stock ones they will have the same problem - which is a shame as that was my original plan before receiving the tank
cheers
Hide Signatures
       Post #: 61
RE: Waltersons 105 Full Review - 1/9/2013 8:53 PM
Panther F
Score: 135
Status: offline
If it comes down to that, then I think the Mato sprocket will have to be used.
~ Jeff
Hide Signatures
(in reply to gorehound)
       Post #: 62
RE: Waltersons 105 Full Review - 1/9/2013 10:58 PM
gorehound
Score: 100
Status: offline
I was thinking that too but the rear idler will also be needed otherwise the tracks will have far too much lateral play as the HL one is also thinner than the Mato one. The road wheels too were also in the same boat.
Now I need to find my set of Mato sprockets as I cannot find them
Might just wait until the aftermarket boys release a set spcifically for the HL Sherman as it will only be a matter of time
cheers
Hide Signatures
       Post #: 63
RE: Waltersons 105 Full Review - 1/9/2013 11:52 PM
Jaws01
Score: 100
Status: offline
Matomart sells the drive and idler set
Cheers
Click for fullsize
Hide Signatures
       Post #: 64
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.561RCU1
