covering wingtips    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> covering wingtips Page: [1]
Login
covering wingtips - 12/22/2012 2:26 AM
coralsea
Score: 100
Last Login: 12/22/2012
Status: offline
covering  wingtips for the first time.  Need some adult guideance and tips to make them look good
Hide Signatures
       Post #: 1
RE: covering wingtips - 12/22/2012 2:38 AM
speedracerntrixie
Score: 189
Last Login: 5/24/2013
Status: online
Work slowly, pull the covering tight and iron in place a small amount at a time. The heat from the iron will help you to strech the covering some so that it will conform the the shape a little easier.
Hide Signatures
(in reply to coralsea)
       Post #: 2
RE: covering wingtips - 12/22/2012 3:04 AM
coralsea
Score: 100
Status: offline
thanks for the unfo, I try to work too fast
Hide Signatures
(in reply to speedracerntrixie)
       Post #: 3
RE: covering wingtips - 12/22/2012 4:34 AM
vicman
Score: 189
Status: offline
I usually run a 1/8 or so strip of covering around the end and then follow the rules above. Also leave your covering about 3" long for something to grab it by when you are pulling it around.
The strip gives the covering something to hold on to other than just balsa and works a little better.
Crazy sharp new xacto blades or razor blades for trimming and wipe it off with a little denatured alcohol or acetone to seal the seam and hold.
_____________________________
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
Hide Signatures
       Post #: 4
RE: covering wingtips - 12/22/2012 6:06 PM
bikerbc
Score: 116
Status: offline
What type of covering are you using?
Ken , Biker BC Cub Brother #6 UltraSport BrotherHood # 100 Tiger Club # 7
Hide Signatures
(in reply to vicman)
       Post #: 5
RE: covering wingtips - 12/31/2012 5:39 PM
DustBen
Score: 113
Last Login: 2/18/2013
Status: offline
I assume the question regards "full round" tips... with every bit of them a compound curve.
Someone else said it... leave a few extra inches to grab onto.
I use a heat gun carefully pulling the material. Try not to "over-temp" the film... just get it warm enough to make it pliable.
I've covered 300 or so models.
Covering takes patience, focus, and skill.
One thing to "learn" with is using low temp film that are far more pliable. They don't render as good of results as Monokote or UltraCote, but you can learn technique easier with the low temp stuff.
Hide Signatures
(in reply to bikerbc)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.250RCU1
