Seating New Bearings in a YS 61-R    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> Seating New Bearings in a YS 61-R
Page: [1]
Login
Seating New Bearings in a YS 61-R - 12/22/2012 5:06 AM
poorbs
Score: 100
Last Login: 1/22/2013
Status: offline
I'm getting ready to reassemble a YS .61-R, and it's been a long time since I replaced the bearings in one of these engines. I think I remember how to do the rear one, with putting the bearing on the crankshaft and then into the freezer, and then heating the crankcase where the bearing goes just before assembly. Could someone refresh my memory about seating the front bearing? I know the front one has to go in first. What about using a lubricant on either one to help it seat completely?
Hide Signatures
       Post #: 1
RE: Seating New Bearings in a YS 61-R - 12/22/2012 2:41 PM
ThumbSkull
Score: 108
Last Login: 5/20/2013
Status: offline
Heat. Oil won't hurt but heat it once for the front then again for the rear. Many use an oven for 1/2 hour at 300* but I just use a heat gun while it sits on a silicone pad or wood plank. The moving air get it hot much faster.
Hide Signatures
(in reply to poorbs)
       Post #: 2
RE: Seating New Bearings in a YS 61-R - 12/22/2012 4:01 PM
poorbs
Score: 100
Status: offline
Thanks, I hadn't thought of using a heat gun - I had always used a propane torch, and feared that one day I would crack one of my crankcases.
What about seating the front bearing? I once had to remove one (and ruin it in the process) because it got stuck part way in. How do you insert the front bearing to get it seated all the way in?
Hide Signatures
(in reply to ThumbSkull)
       Post #: 3
RE: Seating New Bearings in a YS 61-R - 12/22/2012 4:09 PM
ThumbSkull
Score: 108
Status: offline
Occasionally I have one that won't just drop in with heat.
In that situation, I pull them in while its hot with washers and spacers using the prop nut.
Leather, or silicone mitts are necessary.
Hide Signatures
       Post #: 4
RE: Seating New Bearings in a YS 61-R - 12/27/2012 8:17 PM
Roary m
Score: 107
Last Login: 5/21/2013
Status: offline
Putting the bearings in the freezer for an hour helps as well.
Hide Signatures
       Post #: 5
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> Seating New Bearings in a YS 61-R
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.296RCU1
