Air Gauges    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Air Gauges
Page: [1]
Login
Air Gauges - 12/22/2012 9:27 PM
Don Reger
Score: 100
Last Login: 5/25/2013
Status: offline
Bought some air gauges from McMaster-Carr. I am looking for an adopter for the back side so I can use them in a jet? I have some but in a different jet. I do not remember where I got the adopter.
Hide Signatures
       Post #: 1
RE: Air Gauges - 12/22/2012 9:34 PM
Wclays
Score: 105
Status: offline
Which gauges did you get?
Hide Signatures
(in reply to Don Reger)
       Post #: 2
RE: Air Gauges - 12/22/2012 9:43 PM
Don Reger
Score: 100
Status: offline
Miniature, has a NPT male Connection
Hide Signatures
       Post #: 3
RE: Air Gauges - 12/22/2012 9:54 PM
k12rc
Score: 101
Status: online
try www.clippard.com/ they have small fittings
_____________________________
don''''''''''''''cry'''''''' till''''''''it hits
Hide Signatures
       Post #: 4
RE: Air Gauges - 12/22/2012 9:59 PM
Wclays
Score: 105
Status: offline
http://www.mcmaster.com/#5346K81
What about these
Hide Signatures
(in reply to k12rc)
       Post #: 5
RE: Air Gauges - 12/22/2012 11:02 PM
Flynstuff
Score: 100
Status: online
Don
Can you post the link for the gauges?
J. Tolomeo
KingTech-USA Rep & Team Pilot
Hide Signatures
(in reply to Wclays)
       Post #: 6
RE: Air Gauges - 12/23/2012 12:27 AM
Wclays
Score: 105
Status: offline
I think these are the ones.
http://www.mcmaster.com/#atmospheric-pressure-gauges/=kpjfrt
Hide Signatures
(in reply to Flynstuff)
       Post #: 7
RE: Air Gauges - 12/23/2012 12:38 AM
john4648
Score: 100
Last Login: 5/24/2013
Status: offline
Don got the McMaster #38105K51 gauge so needs an adapter from std airline to a 1/8" NPT
Thanks for the help
John
Miniature Gauges
Use with air, water, hydraulic oil, ethyl alcohol, natural gas, and nitrogen
Pipe Connection: Brass NPT male or brass BSPT male
Accuracy: ±5% full scale (Grade D)
With a dial that’s less than an inch in diameter, these gauges work well in tight spots. Case is ABS plastic and lens is impact-resistant polycarbonate. Temperature range is -40° to 150° F.
Available Pressure Ranges (psi)
Pressure
Range Grad.
Marks Numeric
Increments
0-160 10 40
To Order: Please specify pressure range from the chart.
Center Back Connection
NPT Male
Dial Size Pipe Each
29/32" 1/8 38105K51 $9.92
Hide Signatures
       Post #: 8
RE: Air Gauges - 12/23/2012 1:14 AM
k12rc
Score: 101
Status: online
quote:
38105K51
11924-1-PKG
( In Stock )
Packages (10 ea.)
Qty:
11924-1-PKG
View 3D Model
check this one out at clippard
Hide Signatures
(in reply to john4648)
       Post #: 9
RE: Air Gauges - 12/23/2012 1:26 PM
rhklenke
Score: 129
Status: offline
I tried those gauges and the problem is, after you add the adapter, they are not only big, but heavy too - and they don't really save you many $'s over the ones you can get from Dreamworks...
Bob
Hide Signatures
(in reply to k12rc)
       Post #: 10
RE: Air Gauges - 12/23/2012 1:54 PM
Dr Honda
Score: 100
Status: offline
quote:
ORIGINAL: rhklenke
Bob
Yep... What he said. Besides.... 1/8" barbed fittings are too big. You need 1/16" for air hose.
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
(in reply to rhklenke)
       Post #: 11
RE: Air Gauges - 12/23/2012 2:35 PM
k12rc
Score: 101
Status: online
They have the 1/16 if that is what he needs i agree about the weight I use the digital fron dreamworks
Hide Signatures
(in reply to Dr Honda)
       Post #: 12
RE: Air Gauges - 12/23/2012 4:13 PM
Don Reger
Score: 100
Status: offline
The weight does not bother me. I can see the larger ones better. Thanks for the help on the adopters.
Hide Signatures
(in reply to k12rc)
       Post #: 13
RE: Air Gauges - 12/23/2012 4:15 PM
dadragon
Score: 112
Last Login: 3/14/2013
Status: offline
Sierra carries a 160lb guage with the nut and air nipple built in 7/8 dia. if I read it rite they are 2 for 20.00.
Hide Signatures
(in reply to k12rc)
       Post #: 14
RE: Air Gauges - 12/24/2012 12:11 AM
Wclays
Score: 105
Status: offline
Do you have a web site for Sierra?
Hide Signatures
(in reply to dadragon)
       Post #: 15
RE: Air Gauges - 12/24/2012 1:10 AM
Harley Condra
Score: 105
Status: offline
Try this....Google makes it very easy.
http://www.sierragiant.com/prod01.html
Harley Condra
BVM REP, Skymaster REP, JetCat REP
Hide Signatures
       Post #: 16
RE: Air Gauges - 12/24/2012 1:48 AM
smchale
Score: 115
Status: online
quote:
ORIGINAL: dadragon
I read it as $20 each if you buy two, or more.
Sean McHale
"Strive for simplicity. You never have to repair what you leave out." - Bill Lear
Hide Signatures
       Post #: 17
RE: Air Gauges - 12/24/2012 3:20 AM
rick hamel
Score: 100
Status: offline
I have always soldered small brass tubing into the bore and then soldered a barb on the end of the tubingthen the airline goes right on
Hide Signatures
(in reply to smchale)
       Post #: 18
RE: Air Gauges - 12/24/2012 7:45 AM
cmjets
Score: 105
Last Login: 5/23/2013
Status: offline
Hello:
I use this FESTO, for less 20$.
BR from Spain.
Carlos Márquez
_____________________________________
http://cmjets.blogspot.com.es/
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to rick hamel)
       Post #: 19
RE: Air Gauges - 12/24/2012 1:28 PM
smchale
Score: 115
Status: online
Has anyone come across a more compact (smaller face) gauge than the 29/32" dia ones we typically use?
The smallest I've found is here: http://www.miniaturepressuregauge.com/
I inquired about getting them in a rear mount and they came back with the following notes:
For steam driven models we only manufacture these in bottom connection
½” ranges: 0-80psi, 0-100psi & 0-120psi
If you want 0-150 psi, you will need to have ¾” or 1” diameter pressure gauges
1/2" Pressure gauge for steam driven models,
Supplied with nut & tail piece.
Price: 10 off @ 20.00 each or 1-9 @ £24.00 ech
3/4" Pressure gauge for steam driven models, reading 0-150psi,
Price: 1 x 9 off @ £20.00 each
Price: (Pounds Sterling)
Delivery: 10 days
Wondering if there are other options out there in a similar size?
Sean McHale
Hide Signatures
(in reply to cmjets)
       Post #: 20
RE: Air Gauges - 12/24/2012 6:18 PM
RSO
Score: 100
Status: offline
Don: Ron, Lance, & I have the same gauges, and have had good luck with this push on style connector for years. Works great with BVM air tubing. I think this is the correct order number, but double check the sizes.
McMasters catalogue page 186, part #5779K123.
Jerry
Hide Signatures
       Post #: 21
RE: Air Gauges - 12/25/2012 12:11 AM
Don Reger
Score: 100
Status: offline
Thanks Jerry, I ordered 2 to try.
Hide Signatures
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
