Old OS61 SE pattern engine    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Moki 2.10
Seller:  thunderbolt-RCU
Details:   $250.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> O.S. Engines Support >> Old OS61 SE pattern engine
Page: [1]
Login
Old OS61 SE pattern engine - 12/23/2012 12:53 AM
Yak13
Score: 106
Last Login: 5/18/2013
Status: online
 I am using an old (very good condition) OS .61 SE long stroke pattern engine with Macs tuned pipe. Using 10% fuel and 11x11 prop. Contrary to what I expected the plane was fastest when using the 11x11. I am getting 11,450 rpm static. If I want to increase max speed should I look for a higher rpm setting of prop/pipe?
What is the highest and recommended nitro percentage? I tried YS20/20 and lost 300rpm.
Thanks a lot,
Ed
Hide Signatures
       Post #: 1
RE: Old OS61 SE pattern engine - 12/24/2012 3:06 PM
Bax
Score: 169
Last Login: 5/17/2013
Status: offline
The O.S. long-stroke engines should be propped so that they turn in the mid-to-high 11,000's when leaned to just rich of peak RPM on the ground. Your engine sounds like it's running about the right RPM. They have been propped closer to 10,000 RPM for Pattern. A typical Pattern prop of that era was an APC 12 x 12 propeller. RPM would get into the mid-9,000's with a pipe.
To slow a model with the engine, you'll need a lower-pitched propeller. That means more diameter to keep the RPM in range. The long-stroke series of O.S. engines did not like higher RPM ranges, so keep it below 12,000 RPM, and you'll be OK.
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
Hide Signatures
(in reply to Yak13)
       Post #: 2
RE: Old OS61 SE pattern engine - 12/24/2012 4:07 PM
Yak13
Score: 106
Status: online
Thanks Bill.
Would you happen to have the power curves for this engine?
Thanks again,
Ed
Hide Signatures
(in reply to Bax)
       Post #: 3
RE: Old OS61 SE pattern engine - 12/26/2012 3:38 PM
Bax
Score: 169
Status: offline
O.S. never released graphic information on their engines. We'd not have a power curve. In older magazines, the power curves you may have seen were made by the person who wrote the engine review. They did their own dyno testing.
Hide Signatures
(in reply to Yak13)
       Post #: 4
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> O.S. Engines Support >> Old OS61 SE pattern engine
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
