A7 Corsair Scratch Build Prop Jet..    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> A7 Corsair Scratch Build Prop Jet.. Page: [1] 2   next >   >>
Login
A7 Corsair Scratch Build Prop Jet.. - 12/23/2012 4:57 PM
Spiritwind
Score: 100
Last Login: 5/4/2013
Status: offline
Got some progress done with the A7 project. Building a larger version of the House of Balsa A7 Corsair.
Got the wing finished and mounted to fuse. Fuse is nearly done just need to finish the contour of the
fuse and finish the fin and rudder, rear deck and stab mounting. Also need to finish the nose, mounting
the engine and canopy detail.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Spiritwind -- 1/9/2013 10:04 PM >
Hide Signatures
       Post #: 1
RE: A7 Corsair Scratch Build Prop Jet.. - 12/23/2012 5:17 PM
DavidAgar
Score: 146
Last Login: 5/23/2013
Status: offline
Looks good, keep us posted on your progress......Thanks Dave
_____________________________
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
Hide Signatures
(in reply to Spiritwind)
       Post #: 2
RE: A7 Corsair Scratch Build Prop Jet.. - 12/23/2012 10:25 PM
Quigleywins
Score: 110
Status: offline
Thanks for the update and photos,I am watching with intrest. Yours Paul T
''''''''''''''''bugger''''''''''''''''- That went in quick... I fly that well now i''m DANGEROUS.
Hide Signatures
(in reply to DavidAgar)
       Post #: 3
RE: A7 Corsair Scratch Build Prop Jet.. - 12/24/2012 6:43 AM
skeeter_ca
Score: 121
Last Login: 3/6/2013
Status: offline
Did you blow up HOB plans or draw your own? What size is it and what kind of power is going to pull it?
skeeter
"It is easier to ask for forgiveness than permission".
Hide Signatures
(in reply to Quigleywins)
       Post #: 4
RE: A7 Corsair Scratch Build Prop Jet.. - 12/24/2012 4:52 PM
Gray Beard
Score: 314
Last Login: 5/22/2013
Status: offline
Very impressive!!! I was wondering the same thing, did you just enlarge templates and the plans of the HOB or did you draw your own?
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to skeeter_ca)
       Post #: 5
RE: A7 Corsair Scratch Build Prop Jet.. - 12/25/2012 1:36 AM
Spiritwind
Score: 100
Status: offline
Guys, I drew out my own plans 1 1/2 times bigger than HOB's, using them as a guide. The ribs were the hardest to make.
The wing span is just under 60" and the length is around 58". Putting a OS 61FX in it hoping that will be plenty.
Will have to see what the weight will end up being. Thanks for the comments. It's starting to look good.
Finished the bottom of fuse and installed the wing sheeting to blend into fuse. Also cut out the fin and rudder..
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Spiritwind -- 12/25/2012 3:23 AM >
Hide Signatures
(in reply to Gray Beard)
       Post #: 6
RE: A7 Corsair Scratch Build Prop Jet.. - 12/27/2012 4:17 AM
AERORICH73
Score: 115
Last Login: 5/10/2013
Status: offline
Very well planned enlargement. Suspect you have more training than usual. I have this same kit, but have not ventured to build it yet as other broken planes seem to need me more than building new ones. My investigation of this House of Hobbies model found some discussion on the kit landing gear was weak. I am glad to see a metal main gear system on you enlarged version. I am a retired aircraft mechanic and seem to find areas of construction somewhat on the iff side. Beefing up areas, and increasing wood strength works well for me, and believe the airworthness of the model makes it safer to fly. Your construction looks very much like you have the same idea.
Please keep us informated as this could be a model others would like to build. The engine size fits very nicely in such a model.
aerorich73@centurylink.net
Hide Signatures
       Post #: 7
RE: A7 Corsair Scratch Build Prop Jet.. - 12/28/2012 2:13 AM
Spiritwind
Score: 100
Status: offline
Thanks AeroRich, yes I beefed up the construction. The original model flew fantastic but landings were always a problem. I could grease the landing and it would bounce all the way down the runway. I'm hoping the metal gear will stop that problem. Getting ready to cover the wing. Got all the servos mounted for flaps and ailerons. Will cover with Solartex and going to do a camo paint scheme.
Hide Signatures
(in reply to AERORICH73)
       Post #: 8
RE: A7 Corsair Scratch Build Prop Jet.. - 12/28/2012 11:48 PM
Quigleywins
Score: 110
Status: offline
If you keep this up I will be forced to get that laser cut kit I have just sitting in the box in the shed and give it a go. (Flying Models 6/70 had a model . 60 powered, 64" length, 58" span.) As this was the type of aircraft flown off carriers when I first started in the hobby many, many years ago, I fell in love and have always wanted one. I have a ARF of one yet to be fitted out. I will be watching to the end of this thread. Yours Paul T
Hide Signatures
       Post #: 9
RE: A7 Corsair Scratch Build Prop Jet.. - 12/30/2012 1:38 AM
Spiritwind
Score: 100
Status: offline
Thanks Paul, I got the wing finished and covered today. Plus got the engine mounted and made the front cowling, it's still drying. Will post some pics tomorrow.
I would like to see that one you have. I didn't know anyone else had made one. Thanks, Mike.
Hide Signatures
       Post #: 10
RE: A7 Corsair Scratch Build Prop Jet.. - 12/30/2012 6:28 AM
Quigleywins
Score: 110
Status: offline
I just live for photos Mike Yours Paul T
Hide Signatures
       Post #: 11
RE: A7 Corsair Scratch Build Prop Jet.. - 12/30/2012 8:46 PM
Spiritwind
Score: 100
Status: offline
Pics... got some roughing in done on cockpit and nose.....Not trying to get super scale looking just want a
good looking everyday plane...More to follow..
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 12
RE: A7 Corsair Scratch Build Prop Jet.. - 12/30/2012 8:50 PM
mniesen89
Score: 102
Last Login: 4/6/2013
Status: offline
Wow, that looks amazing.
Mike
Hide Signatures
       Post #: 13
RE: A7 Corsair Scratch Build Prop Jet.. - 12/31/2012 2:35 AM
Spiritwind
Score: 100
Status: offline
Thanks guys. Happy New Year to all.
Hide Signatures
(in reply to mniesen89)
       Post #: 14
RE: A7 Corsair Scratch Build Prop Jet.. - 12/31/2012 10:41 PM
Quigleywins
Score: 110
Status: offline
I just thought I'd put the link to where I got my A7 Corsair cut in the states.I must get back to it Yours Paul T
http://lazer-works.com/list.html
Now there is more than one crsader on there list so you need to order the one below.
F8E Crusader, Plans from Flying Models Plans (Plans no longer available. Redrawn by Lazer Works)
$134.00
Click for fullsize
Hide Signatures
       Post #: 15
RE: A7 Corsair Scratch Build Prop Jet.. - 1/2/2013 4:19 AM
Spiritwind
Score: 100
Status: offline
Finished rear decking and glued fin and rudder detail. Did some painting in cockpit. Won't be long and I can
cover the fuse and start painting...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 16
RE: A7 Corsair Scratch Build Prop Jet.. - 1/2/2013 6:57 AM
Quigleywins
Score: 110
Status: offline
Looking real good now,have you any photos of the early stages of the wing. Keep it going. I'm in the middle of a Senior Tellemaster or I'd be with you for some of the way.
Hide Signatures
       Post #: 17
RE: A7 Corsair Scratch Build Prop Jet.. - 1/3/2013 12:47 AM
airbusdrvr
Score: 141
Status: offline
quote:
ORIGINAL: Quigleywins
$134.00
I'm not stirring the pot, but the A-7 is the Corsair and the F-8 is the Crusaider. Similar in appearance but very different aircraft. Both built by Vought later LTV (Ling/Temco/Vought).
UltraSport Brotherhood #17
Hide Signatures
       Post #: 18
RE: A7 Corsair Scratch Build Prop Jet.. - 1/3/2013 1:03 AM
Quigleywins
Score: 110
Status: offline
I just will not sleep tonight. But I will be over it in one or two days. I have the Crusader. Sorry for the mistake its Hard to be perfect. I will try harder in the future LOL. Yours Paul T
Hide Signatures
(in reply to airbusdrvr)
       Post #: 19
RE: A7 Corsair Scratch Build Prop Jet.. - 1/3/2013 5:41 AM
Redback
Score: 115
Status: offline
Yea, get it right, you're letting the bl**dy side down mate!
Hide Signatures
       Post #: 20
RE: A7 Corsair Scratch Build Prop Jet.. - 1/4/2013 2:33 AM
Spiritwind
Score: 100
Status: offline
Got the bottom of wing and fuse painted a very light grey. Hope to get the camo on this weekend. Will post more pics then.
Thanks for all the interest. Just hope this thing flies like the small one.
Paul I had started another post earlier that has some pics of the wing. But I had most of it finished before I thought to take pics. I could take a pic of the wing plans that I drew up if that would help any? Or make a search for that earlier thread, titled A7 Corsair build.
Hide Signatures
(in reply to Redback)
       Post #: 21
RE: A7 Corsair Scratch Build Prop Jet.. - 1/4/2013 4:45 AM
Quigleywins
Score: 110
Status: offline
I will look ,Keep the photos going. Yours Paul T
Hide Signatures
       Post #: 22
RE: A7 Corsair Scratch Build Prop Jet.. - 1/6/2013 2:28 AM
Spiritwind
Score: 100
Status: offline
Got the bottom of fuse and wing painted a light grey and started to put 1 of 3 colors on the wing and fuse. My first camo
paint job...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Spiritwind -- 1/6/2013 6:56 AM >
Hide Signatures
       Post #: 23
RE: A7 Corsair Scratch Build Prop Jet.. - 1/8/2013 1:15 AM
Spiritwind
Score: 100
Status: offline
Finished painting wing no onto finishing the fuse....
Click for fullsize
Hide Signatures
       Post #: 24
RE: A7 Corsair Scratch Build Prop Jet.. - 1/9/2013 10:13 PM
Spiritwind
Score: 100
Status: offline
One more color to go on fuse after finishing up with canopy detail. Will have to do some touch-up on grey
but will look good. Plan on putting a shark mouth on nose.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.375RCU1
