Wing tube length    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> Wing tube length
Page: [1]
Login
Wing tube length - 12/24/2012 4:17 PM
jp1961
Score: 100
Last Login: 5/24/2013
Status: offline
I'm scratch building a 60" wingspan profile model that will have a 25cc gas engine. The wings will be foam core. I'm using a 1.25" diameter aluminum tube to join the wings. How long would you make it? I have a 20" long tube, but I'm not sure if that's long enough.
Jeff
Hide Signatures
       Post #: 1
RE: Wing tube length - 12/24/2012 4:23 PM
sensei
Score: 176
Last Login: 5/23/2013
Status: offline
If you have upper and lower spar caps and the tube is centered between them, there is no reason that won't work great for you, just make sure to bond tie it all together.
Bob
_____________________________
Fly It Like You Stole It!!!
Hide Signatures
(in reply to jp1961)
       Post #: 2
RE: Wing tube length - 12/24/2012 5:10 PM
speedracerntrixie
Score: 189
Status: offline
I agree with Bob. I think that most manufacturers are running the tube into the wing too far. I have 2 airplanes that I scratch built with wing tubes. The first one is a 2M pattern airplane ( 11 lbs ) that uses a 7/8" CF tube that goes 8" into the wing. The second airplane is a 33% Laser that used a 1 1/2" CF tube that goes 11" into the wing. Whatever sleeve you use in the wing should be anchored  at the root rib and a peice of ply at the other end that extends vertically to tie into the sheeting. For spar caps I use some 3K CF tow that extends at least 8" past the wing tube. This helps to avoid a stress riser.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to sensei)
       Post #: 3
RE: Wing tube length - 12/24/2012 6:17 PM
jp1961
Score: 100
Status: offline
I wasn't plannning on using spar caps (not sure I know what those are), just foam, with a pine veneer covering. I did make a fiberglass tube for the sleeve.
Jeff
Hide Signatures
(in reply to speedracerntrixie)
       Post #: 4
RE: Wing tube length - 12/25/2012 1:08 AM
PatternPilot
Score: 125
Status: offline
The way we make our plug in wings is with a false rib at the end of the tube sleeve in the wing and then at the root of the foam we have a lite ply rib.... then we run a .75 inch wide by .007 thick carbon fiber tape from root to tip over the tube area.
see attached... sorry the drawing was quick.
Click for fullsize
Scott Anderson - CPA #2 - www.ClassicPatternAssociation.com - Team Airtronics SD10G - NSRCA 529 - VRCS 236
Hide Signatures
       Post #: 5
RE: Wing tube length - 12/25/2012 2:45 AM
sensei
Score: 176
Status: offline
If you are not going to run spar caps then do as pattern pilot illustrated, that works good as well.
Note: Do not just run the tube out into the foam alone and then sheet!
Bob
Hide Signatures
(in reply to PatternPilot)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.219RCU1
