SAITO .72 AAC    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> SAITO .72 AAC
Page: [1]
Login
SAITO .72 AAC - 12/25/2012 12:00 AM
TPL33
Score: 100
Last Login: 5/4/2013
Status: offline
Received my SAITO .72 AAC the other day. While looking at it, I noticed that when mounted on the airplane (it'll be mounted on its side, with the valve covers toward the left looking from the front of the plane), that the High Speed Needle Valve will be at the bottom of the engine. I read somewhere that on SAITO engines (maybe not the .72 AAC), that you can turn the carburator/needele valve assembly 180 degrees. I read through the manual and didn't see any instructions for doing this. Is turning the carb/needle valve only an option on some engines?
Hide Signatures
       Post #: 1
RE: SAITO .72 AAC - 12/25/2012 1:11 AM
fredscz
Score: 102
Last Login: 5/21/2013
Status: offline
It is very easy to do. Use the proper fitting screwdriver to remove the two screws holding on the carb body. Gently pull the intake tube from the head with the carb and turn the carb 180 and reinstall. Takes longer to talk about it than to do it.
Be careful with the o-rings and don't damage them.
Fred
< Message edited by fredscz -- 12/25/2012 4:22 AM >
_____________________________
Life''''s tough......It''''s even tougher if your stupid!! " J. Wayne
Hide Signatures
(in reply to TPL33)
       Post #: 2
RE: SAITO .72 AAC - 12/26/2012 4:36 AM
tailskid
Score: 199
Status: online
TPL33, if you need any assistance, I'm only a couple of miles away....
Jerry
# 93 in Club Saito
Carl Goldberg Ultimate Brotherhood # 12
Hide Signatures
(in reply to fredscz)
       Post #: 3
RE: SAITO .72 AAC - 12/26/2012 5:21 AM
TPL33
Score: 100
Status: offline
quote:
ORIGINAL: tailskid
Jerry
I may take you up on that! I'm back into the hobby after 23 years off, already flying a trainer well on my own. I always wanted a 4 Stroke back in the day, never got it though. Now that I can afford it, I bought one. Never messed with one though, so, I'm hesitant to turn the carb around, don't want to screw things up!
Hide Signatures
(in reply to tailskid)
       Post #: 4
RE: SAITO .72 AAC - 12/26/2012 10:01 AM
Old Fart
Score: 158
Status: offline
Well thats easy then,take freds advice
Watch out for the ground eh?
Hide Signatures
(in reply to TPL33)
       Post #: 5
RE: SAITO .72 AAC - 12/26/2012 10:26 PM
daveopam
Score: 191
Last Login: 5/18/2013
Status: offline
I never pull the tube from the head. After you pull the screws. Just swivel the carb/tube to the side, spin the carb and then swivel it back in place. The way there is zero chance of not seating the O ring back in the head.
David
"You only live once. But if you do it right,once is enough."Mae West
Hide Signatures
(in reply to Old Fart)
       Post #: 6
RE: SAITO .72 AAC - 12/26/2012 10:30 PM
tailskid
Score: 199
Status: online
quote:
ORIGINAL: TPL33
quote:
ORIGINAL: tailskid
Jerry
Where are you located? I'm near 99th Ave and Lower Buckeye Road....
Jerry
# 93 in Club Saito
Hide Signatures
(in reply to TPL33)
       Post #: 7
RE: SAITO .72 AAC - 12/27/2012 5:27 AM
TPL33
Score: 100
Status: offline
quote:
ORIGINAL: tailskid
quote:
ORIGINAL: TPL33
quote:
ORIGINAL: tailskid
Jerry
Jerry
I'm in Avondale, Dysart Rd and Encanto, across from Estrella Mountain Community College....Tim
Hide Signatures
       Post #: 8
RE: SAITO .72 AAC - 12/27/2012 6:09 AM
tailskid
Score: 199
Status: online
I'm retired, so if / when you need me, just hollar........
# 93 in Club Saito
Hide Signatures
(in reply to TPL33)
       Post #: 9
RE: SAITO .72 AAC - 12/27/2012 5:46 PM
TPL33
Score: 100
Status: offline
quote:
ORIGINAL: tailskid
Thanks. Do you have 4 Stroke experience? I may need guidance on turning the carb (so the high speed needle is at the top) and maybe initial adjustment of the engine.
Hide Signatures
       Post #: 10
RE: SAITO .72 AAC - 12/27/2012 7:47 PM
tailskid
Score: 199
Status: online
No problem..I think I have 4 or 5 currently (all Saito's).....great engines.
# 93 in Club Saito
Hide Signatures
(in reply to TPL33)
       Post #: 11
RE: SAITO .72 AAC - 1/9/2013 5:47 AM
TPL33
Score: 100
Status: offline
quote:
ORIGINAL: daveopam
David
You were correct. The person on here who said it takes less time to do it than talk about it was right. I got the carb turned tonight, piece of cake. Thanks for the inputs guys.
Hide Signatures
(in reply to daveopam)
       Post #: 12
RE: SAITO .72 AAC - 1/9/2013 6:28 AM
tailskid
Score: 199
Status: online
TPL33, where do you fly?
# 93 in Club Saito
Hide Signatures
(in reply to TPL33)
       Post #: 13
RE: SAITO .72 AAC - 1/9/2013 5:16 PM
TPL33
Score: 100
Status: offline
quote:
ORIGINAL: tailskid
I'm a member of ARCS (Arizona Radio Control Society). The field is off Greenway Rd, as far as you can go west on Greenway where it turns into a dirt road. How about you?
Hide Signatures
       Post #: 14
RE: SAITO .72 AAC - 1/9/2013 7:40 PM
tailskid
Score: 199
Status: online
I'm neat you I fly at CropDusters.....what a beautiful day it was today. GREAT bunch of guys to hang with.
# 93 in Club Saito
Hide Signatures
(in reply to TPL33)
       Post #: 15
RE: SAITO .72 AAC - 1/10/2013 4:33 AM
TPL33
Score: 100
Status: offline
quote:
ORIGINAL: tailskid
Wish I could have flown today....had to work! I usually fly 1-2 times a week, on Friday or Saturday. The weather has been great this winter, harly any wind!
Hide Signatures
       Post #: 16
RE: SAITO .72 AAC - 1/10/2013 4:35 AM
tailskid
Score: 199
Status: online
This Friday it appears it will be cold and windy, so I'm not flying and Saturday I'll be in Ontario CA for the AMA Convention. Bring your mittins if you go flying
# 93 in Club Saito
Hide Signatures
(in reply to TPL33)
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
