RE: Q-T Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: Q-T Thread
Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: Q-T Thread - 1/23/2013 6:24 AM
turbo.gst
Score: 115
Last Login: 5/18/2013
Status: offline
The Q-Tee was my first R/C airplane. I flew it with a Cox Black Widow. I used a standard 500 mah Ni-cd flight pack, but I used Cox/ Sanwa servo's which were a little smaller than standard size at the time. It flew very well. I wore the cabanes out from too many rough landings and wound up removing them completely, lowering the wing to sit on the fuse top like the S-Tee. I mounted a Tee Dee.049 - it was a hot rod for me a the time. I couldn't even guess at how many hundreds of flights I had on that airframe. Great memories for sure.
Hide Signatures
(in reply to TFF)
       Post #: 26
RE: Q-T Thread - 1/23/2013 7:22 AM
skaliwag
Score: 100
Status: offline
turbo.gst .... I think it's time you had another one...
_____________________________
Real Airplanes have Round Engines and Two Wings.
Hide Signatures
(in reply to turbo.gst)
       Post #: 27
RE: Q-T Thread - 1/24/2013 12:59 AM
turbo.gst
Score: 115
Status: offline
I agree! I would love to try one with todays small radio technology.
Hide Signatures
(in reply to skaliwag)
       Post #: 28
RE: Q-T Thread - 1/24/2013 1:54 AM
GallopingGhostler
Score: 133
Status: offline
Nice thing about today's technology, is one can surface recess mount smaller servos with short pushrods, making installation easier. That might be a little tough CG wise as the Q-Tee has a long tail moment with a longer fuselage. My Q-Tee uses smaller mid-sized servos of the day and a Black Widow for power. Nowadays a Norvel .061 Big Mig would really spice it up.
George Hostler
Clovis MADS AMA Club, Vintage R/C Society (VRCS)
Hide Signatures
       Post #: 29
RE: Q-T Thread - 1/24/2013 2:50 PM
hllywdb
Score: 118
Status: offline
I don't need one spiced up George, All my 1/2A stuff is spiced up. I have a fast GLH, 3- 1/2A pattern planes, 3- 1/2A combat planes and a ME109. What I don't have right now is a simple 2 channel lazy day flier. I'm thinking I can get it to 15oz or less and with the medallion should be just about right for some lawn chair flying
Hide Signatures
(in reply to GallopingGhostler)
       Post #: 30
RE: Q-T Thread - 1/24/2013 5:36 PM
GallopingGhostler
Score: 133
Status: offline
hllywdb, you've got a neat array of aircraft there, I'd say you really do some fancy pattern flying there.
I was referring my my Q-Tee and my spicing it up.
George Hostler
Hide Signatures
(in reply to hllywdb)
       Post #: 31
RE: Q-T Thread - 1/24/2013 6:57 PM
hllywdb
Score: 118
Status: offline
Hi George, not sure my flying would be termed "fancy", but I realy like the way the old pattern planes fly, tuned pipe, retracts, and sharp & crisp. But my larger ones are a bit thirsty. So I built the 1/2A ones and can fly all day and use less fuel than one flight with the larger ones. Plus I can toss them up in the field across the street.
Hide Signatures
       Post #: 32
RE: Q-T Thread - 1/24/2013 9:21 PM
GallopingGhostler
Score: 133
Status: offline
hllywdb, when I say fancy, I'm referring to my flying versus yours. I'm a sport bore holes in the sky pilot. I like watching them fly and that's the purdiest thing in the sky. And I know what you mean about the larger ones being thirsty. That's why I like the .20 size and under. Fuel gets kind of expensive on the larger ones. That's why I'm thinking strongly of the smaller gas engines like the Evolution 10-cc gas burner in a .46 case. Gas costs $3 per gallon, say $4 with oil mixed. Glow fuel is much higher. It doesn't take new math to figure the costs.
George Hostler
Hide Signatures
       Post #: 33
RE: Q-T Thread - 1/25/2013 12:18 AM
hllywdb
Score: 118
Status: offline
I've been testing the new NV 40 size gasser. No ignition, 13oz WITH the muffler, and spins a 10X7 1,000 rpm faster than the glow version. I'm flying 15 min "spirited" flights on 3 1/2 to 4oz of fuel per flight. It's quickly becoming my favorite sport flyer. I can get a lot of flights for $3 worth of pump gas. Probably works out to less cost per flight than a sure start!
Hide Signatures
       Post #: 34
RE: Q-T Thread - 1/25/2013 1:10 AM
cfircav8r
Score: 218
Last Login: 5/17/2013
Status: offline
I had a Q-Tee back in the late 80's with full sized servos and a full sized hard case Rx battery. It had a Cox Texaco engine running a 6-3 prop and it moved around the sky with authority. I still have the original plans and am in the process of getting the wood together to cut 6 kits for the kids and myself. With the new micro gear and electric motors it should be easy to get a reasonable weight and have 3 ch function and long run times. No more 4 min full bore flights with a glide to land. It will be ROG, touch and goes, and nice lazy flying or full throttle boring holes in the sky.
The three most useless things to a pilot, the sky above you, the runway behind you, and the fuel on the ground.
Hide Signatures
       Post #: 35
RE: Q-T Thread - 1/31/2013 8:43 PM
GallopingGhostler
Score: 133
Status: offline
Here's my Q-Tee, all broken after the last Figure-9. Now it is time to start restoring it. It has 2 Charlie R/C (Cannon) mini-servos from the 1980's. During the rebuild, a little undecided yet, I may power it with a TT GP-07 on a Norvel 1 oz tank mount or a Norvel .049 Big Mig with CL tank mount.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
George Hostler
Hide Signatures
(in reply to cfircav8r)
       Post #: 36
RE: Q-T Thread - 1/31/2013 8:54 PM
GallopingGhostler
Score: 133
Status: offline
quote:
ORIGINAL: hllywdb I've been testing the new NV 40 size gasser. No ignition, 13oz WITH the muffler, and spins a 10X7 1,000 rpm faster than the glow version. I'm flying 15 min ''spirited'' flights on 3 1/2 to 4oz of fuel per flight. It's quickly becoming my favorite sport flyer. I can get a lot of flights for $3 worth of pump gas. Probably works out to less cost per flight than a sure start!
When you say NV, do you mean Norvel? Without ignition? You've got my interest perked. Are you testing for the manufacturer?
George Hostler
Hide Signatures
       Post #: 37
RE: Q-T Thread - 1/31/2013 9:21 PM
hllywdb
Score: 118
Status: offline
Hi George,
Yes, for NV (Norvel) There is a thread over in the glow engine section.
Bill
Hide Signatures
       Post #: 38
RE: Q-T Thread - 1/31/2013 11:46 PM
MrGoodwreck
Score: 100
Last Login: 5/7/2013
Status: offline
quote:
ORIGINAL: GallopingGhostler
Outstanding!,
That looks like it should buff right out.
The real Ken of RCU. Accept no substitutes!
AMA 706166
Hide Signatures
       Post #: 39
RE: Q-T Thread - 2/1/2013 12:21 AM
GallopingGhostler
Score: 133
Status: offline
quote:
ORIGINAL: hllywdbYes, for NV (Norvel) There is a thread over in the glow engine section.
Bill, I read through parts of the thread you mentioned. This is great, a glow ignited gasser. I've been looking at the 10cc (.60) Evolution ignition gasser that has promise, but I like the idea of a .40 gasser without the heavier ignition module. In the thread, you mention it should be available this year. Do you have a rough idea of when?
George Hostler
Hide Signatures
       Post #: 40
RE: Q-T Thread - 2/1/2013 12:28 AM
GallopingGhostler
Score: 133
Status: offline
quote:
ORIGINAL: MrGoodwreck Outstanding!, That looks like it should buff right out.
It should, MrGoodwreck. I've already got the selective Q-Tee tiled pages printed out for pattern making as we speak. The wing hit the ground hard. The hardwood leading edge caused the tips of a half dozen ribs to crunch at the tips. I'm not sure exactly how I'm going to remediate yet. I'm thinking about making half new ribs and cutting the old at the spar. The fuselage sides I will splice somewhere near the middle of the receiver location, make a new plywood firewall, new 3/16" balsa cheek cowls.
This will be its second major repair job.
George Hostler
Hide Signatures
(in reply to MrGoodwreck)
       Post #: 41
RE: Q-T Thread - 2/1/2013 1:41 AM
airraptor
Score: 130
Status: offline
I use those 200 Mah LiFe Packs from tower all the time. Very light and small. I replace the included battery lead with a lighter one. I would use around 20-30 mah per 10 minute flight on a Honker with full house.
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
       Post #: 42
RE: Q-T Thread - 2/1/2013 9:44 PM
GallopingGhostler
Score: 133
Status: offline
Repair patterns from tiled full size plans have been cut out for the 1/8" ply firewall, 3/16" cheeks and bottom of the cowl, and 3/32" front portion of the fuselage sides. Also included is the wing rib template, which will be further trimmed for rib repair.
Click for fullsize
George Hostler
Hide Signatures
       Post #: 43
RE: Q-T Thread - 2/2/2013 1:28 AM
GallopingGhostler
Score: 133
Status: offline
quote:
ORIGINAL: airraptor I use those 200 Mah LiFe Packs from tower all the time. Very light and small. I replace the included battery lead with a lighter one. I would use around 20-30 mah per 10 minute flight on a Honker with full house.
Hi, airraptor. Not sure what the relationship is to the Q-Tee discussion here. Do you mean what you found to work for receiver batteries and weight savings?
George Hostler
Hide Signatures
(in reply to airraptor)
       Post #: 44
RE: Q-T Thread - 2/4/2013 8:48 PM
GallopingGhostler
Score: 133
Status: offline
I've already cut parts out except for the engine firewall and structural backing lintels and bottom plates. The basic front fuselage balsa structure less the reinforcing structural members have been cut out. Plywood firewall has been templated, to be cut out. Fuselage has been trimmed back 1 inch (25 mm). The new side fronts will be glued in place with a 3/32d inch (2.5 mm) balsa plate to reinforce behind the joint. Left cabine struts were badly cracked requiring a new left cabine strut system. Hidden damage, fix to splice 3/32 in (2.5 mm) balsa to restore side, another to restore upper lintel & reinforcement to strengthen, with cross brace to prevent sides bowing.
Click for fullsize
Click for fullsize
Click for fullsize
George Hostler
Hide Signatures
       Post #: 45
RE: Q-T Thread - 2/7/2013 8:36 PM
GallopingGhostler
Score: 133
Status: offline
I've trimmed back the broken front end of the Q-Tee, 1 inch (25 mm) from the landing gear bulkhead, then added a 3/32d in balsa backer for splicing in the new fuselage 3/32d in side fronts (1st picture). The wadded paper towel is providing a slight pressure until the CA sets up. Replacement cabine struts have been cut out of hardwood. Then I 5-min epoxy glued the right side front in place.
After that set, next I glued the left front vertical cabine strut in place. I also reinforced glued the bottom of the landinge gear bulkead to the plywood fuselage floor. As you notice, there is a slight gap now between the landing gear bulkhead and the cabine strut (2nd picture).
I then epoxied the left front fuselage side in place, using epoxy to fill the gap between the cabine strut and bulkhead. After that set, I glued and clamped the horizontal cabine strut in place and completed filling the same gap from the other side (3rd picture).
Click for fullsize
Click for fullsize
Click for fullsize
George Hostler
Hide Signatures
       Post #: 46
RE: Q-T Thread - 2/7/2013 10:35 PM
MrGoodwreck
Score: 100
Status: offline
Keep up the good work!
She'll be framed up in no time.
AMA 706166
Hide Signatures
       Post #: 47
RE: Q-T Thread - 2/7/2013 11:46 PM
hllywdb
Score: 118
Status: offline
I have the plans printed out full size and handed off the balsa and ply to my laser guy along with the cut files. Should be starting mine soon. I have all the wood, radio, and engine mounts, tanks, etc set aside as well.
Hide Signatures
       Post #: 48
RE: Q-T Thread - 2/8/2013 3:36 AM
GallopingGhostler
Score: 133
Status: offline
Thanks MrGoodwreck for the kind comment. hllywdb, just curious, but what engine do you plan to use?
George Hostler
Hide Signatures
       Post #: 49
RE: Q-T Thread - 2/8/2013 3:17 PM
hllywdb
Score: 118
Status: offline
Why of course, my trusty decades old medallion that I just found (with the aid of a realy good metal detector) after having been buried 8" deep in the turf for 9 months Yes, it needed a bit of work.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
