Beaver cowl    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Seaplanes >> Beaver cowl Page: [1]
Login
Beaver cowl - 12/25/2012 1:59 AM
Roger Gray
Score: 100
Last Login: 5/25/2013
Status: offline
OK fellas where can I find a fiberglass cowl for my 72" DH Beaver that I just started from plans purchased from the Air Age plans store.  I'm guessing this to be a 60 size plane.  The print called for a 40-50 size engine.  I hope to install a small GASOLINE engine.  The print stated the cowl could be purchased from Northwest Hobby Supply in Oregon, however, they seem to be out of business.  FRP Spec.'s has one for a 40 size and a huge one for a 22%.  Any ideas would be appreciated.
Hide Signatures
       Post #: 1
RE: Beaver cowl - 12/25/2012 2:54 AM
seaplane
Score: 100
Last Login: 5/23/2013
Status: offline
I have a Unionville Hobbies 96" Beaver and I purchased a cowl from them at a very reasonable price. They also make a 72" so I assume you could purchase one from them. Unionville does not have a web site and I cannot find their phone number, but maybe someone else with chime in with it. Fiberglass Specialties Inc. makes tons of cowls so you might try them.
Ralph
Hide Signatures
(in reply to Roger Gray)
       Post #: 2
RE: Beaver cowl - 12/25/2012 9:15 AM
kwblake
Score: 110
Status: offline
Great Hobbies, here in Canada, is a dealer for Unionville.  They may be able to help you.  http://www.greathobbies.com/
_____________________________
Kevin
Hide Signatures
(in reply to seaplane)
       Post #: 3
RE: Beaver cowl - 12/25/2012 12:47 PM
JimCasey
Score: 115
Status: offline
Maybe not what you wanted to hear, but a "Plan B" for you:
I browsed carefully thru the housewares at Walmart and found a 2 quart pitcher that made a good cowl.  Measured the depth ( including the right thrust and downthrust offset) and lopped it off.  I had to grind away where the handle had been, but this presented a minimal blemish when I positioned that area to be cut away for one of the holes in the cowl.  Polyethylene is impact and vibration resistant, so it served well.
In an AMAZING (for me) demonstration of planning and forethought,  I selected the covering to match the color of the cowl. Polyethylene does not accept paint well.  BTW: This is a Senior Telemaster that I "Beaver-ized"
Less than $5.00.
Click to see fullsize image.
Click for fullsize
Jim Casey/Seaplane Nerd
http://www.smilesandwags.com/Floats.html
Hide Signatures
(in reply to kwblake)
       Post #: 4
RE: Beaver cowl - 12/25/2012 3:39 PM
Warbird Man
Score: 105
Status: online
Also try fiberglass specialties. You might find something there.
Warbird Man
I love the smell of AV gas in the morning.
Smells like.... victory
Hide Signatures
       Post #: 5
RE: Beaver cowl - 12/29/2012 3:12 AM
Roger Gray
Score: 100
Status: offline
Thanks Kevin/Ralph,  I emailed Great Hobbies about the 6' Unionville Hobbies FRP cowl and hope to hear from them soon, I'll let you guys know what I learned.
Click for fullsize
Hide Signatures
(in reply to Warbird Man)
       Post #: 6
RE: Beaver cowl - 1/14/2013 3:28 AM
Roger Gray
Score: 100
Status: offline
I've decided to make a plug and make my own fiberglass one.  I may post  pictures of the process if any interest?  Unionville 72" available for only 15.00 or so bucks but the shipping from Canada was more than $60.  I have the materials -so- why not!
Click for fullsize
Hide Signatures
       Post #: 7
RE: Beaver cowl - 1/15/2013 5:22 AM
Bill G
Score: 112
Last Login: 5/14/2013
Status: offline
quote:
ORIGINAL: Roger Gray
I've decided to make a plug and make my own fiberglass one.  I may post  pictures of the process if any interest?  Unionville 72'' available for only 15.00 or so bucks but the shipping from Canada was more than $60.  I have the materials -so- why not!
That's probably your best bet. I've seen some Beaver cowls that aren't exactly scale, which is as unorthodox as an FW190 with an incorrectly shaped cowl. Nice build you have going there also, and if I were to build a giant scale, the Beaver would be at the top of the list. Currently I have a 24" version, with scratch built floats like yours.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: Beaver cowl - 1/15/2013 1:18 PM
kwblake
Score: 110
Status: offline
OUCH!!!  I guess it works both ways.  The shipping cost I mean.
Kevin
Hide Signatures
       Post #: 9
RE: Beaver cowl - 1/28/2013 1:39 AM
Roger Gray
Score: 100
Status: offline
Well I just built my own.  Used the lost core method and I think it looks great!
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 10
RE: Beaver cowl - 1/28/2013 3:21 AM
kwblake
Score: 110
Status: offline
110%,  with you on that.  Looks great.  I would guess, this cost a lot  less, than the buying and shipping???
Please post some pics when you are finished.  Or even some as you get there.
OK Roger this is my second edit.  Went back and had another look at your pics.  Could you please post some closeups of your float mounts.   Wow.
Kevin
Hide Signatures
       Post #: 11
RE: Beaver cowl - 1/28/2013 4:39 AM
Roger Gray
Score: 100
Status: offline
Kevin I'll probally drop this Beaver Cowl form but will continue the other one on the plane build itself.  I'll make a point to post some closeup pics of the gear setup for the floats.  They are really easy to do if you have the right materials, a few hand tools,  and a small vice.  Their fun!
Hide Signatures
       Post #: 12
RE: Beaver cowl - 1/29/2013 1:57 AM
Roger Gray
Score: 100
Status: offline
This will be my last post here.   Just wanted to show the cover I put over the engine head.  Not scale but it looks OK.  I'll primer everything tomorrow.  Se ya on the build forum!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 13
RE: Beaver cowl - 1/29/2013 8:12 AM
dadragon
Score: 112
Last Login: 3/14/2013
Status: offline
Roger;that cowl looks very nice,good job.George.
Hide Signatures
       Post #: 14
RE: Beaver cowl - 1/31/2013 12:22 AM
Roger Gray
Score: 100
Status: offline
KWBLAKE-Kevin you'll find the pictures you wanted on the beaver build forum!
Hide Signatures
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.406RCU1
