Just wondering about people's build styles..    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> Just wondering about people's build styles..
Page: [1]
[Poll]
Do you build exactly to print and cover..then deal with the workings..
  14% (9)
Or shape the plane from print and work mechanical in during....
  37% (24)
Or mock everything up, then go to covering....
  48% (31)
Total Votes : 64
(last vote on : 2/12/2013 5:34 PM)
(Poll will run till: -- )
Login
Just wondering about people's build styles.. - 12/25/2012 3:34 AM
flynte
Score: 100
Last Login: 5/3/2013
Status: offline
I'm going this time with the mock it up. It's feeling that it does take longer this way for sure. But when everything is here and fitted, assembly time should feel easier after the body work and covering is done. Or least I hope. First build this way for me.
flynte
_____________________________
MAAC 79035
Hide Signatures
       Post #: 1
RE: Just wondering about people's build styles.. - 12/25/2012 3:48 AM
GaryHarris
Score: 168
Last Login: 5/19/2013
Status: offline
I have no set regiment when building and it often depends on the kit, the engine choice and whether it's a bash or not. Most 40-60 size planes are not designed for 4-Strokes, so I always think ahead as far as throttle cable routing, tank placement etc. I do all the mechanical while building before covering.
Sig Kadet Brotherhood #1
Ultra Sport Brotherhood #105
Hide Signatures
(in reply to flynte)
       Post #: 2
RE: Just wondering about people's build styles.. - 12/25/2012 4:36 AM
Gray Beard
Score: 314
Last Login: 5/24/2013
Status: offline
Not sure how to answer that. I get the plane framed up in the bones then tape or somehow mount all the gear in different locations to get the CG, this includes the controls and control rods. Once I get close I hard mount everything. The plane is all set up and the controls are working. Then I remove everything that will get in the way and cover the plane. Some things like the aileron servos have to go in a set place but other controls have a lot of places they can go. Some planes are designed so you can only install gear in set places. Please tell me what number I should put my vote and I will do it. Covering is the very last thing I do.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to GaryHarris)
       Post #: 3
RE: Just wondering about people's build styles.. - 12/25/2012 5:09 AM
flynte
Score: 100
Status: offline
GB..it was set up as a multiple answer poll. I know situations on some projects dictates different ends, But when you roll out some prints....its takes a decision..What do ppl feel when you roll the print back....hence the poll. I get that there is no real answer, its a personal thing. But I thought it would be interesting to see.
flynte
MAAC 79035
Hide Signatures
(in reply to Gray Beard)
       Post #: 4
RE: Just wondering about people's build styles.. - 12/25/2012 5:10 AM
thailazer
Score: 110
Last Login: 5/23/2013
Status: online
quote:
ORIGINAL: Gray Beard
I do the same as Gray Beard. Plane is ready to fly and checked out fully just sans covering. Then hardware comes off for covering. Works out better for me as there is never any chance of re-work that requires changes to covered surfaces.
Tiger Flyer #49
Hide Signatures
       Post #: 5
RE: Just wondering about people's build styles.. - 12/25/2012 3:27 PM
ARUP
Score: 134
Status: offline
Build, assemble, rig, de-rig, dis-assemble, cover (and paint/ finish), re-assemble, re-rig and FLY! I checked the last box. Merry Christmas!
Hide Signatures
(in reply to thailazer)
       Post #: 6
RE: Just wondering about people's build styles.. - 12/25/2012 4:07 PM
Gray Beard
Score: 314
Status: offline
OK, I guess Thai and I are #3 type builders. Get them all finished then cover.
Hide Signatures
(in reply to ARUP)
       Post #: 7
RE: Just wondering about people's build styles.. - 12/25/2012 4:08 PM
zippome
Score: 100
Last Login: 5/22/2013
Status: offline
Since I'm still fairly new at kit building, I go as per the instruction manual says. Except where I screw up and miss a step.
Hide Signatures
(in reply to ARUP)
       Post #: 8
RE: Just wondering about people's build styles.. - 12/25/2012 4:20 PM
invertmast
Score: 193
Status: offline
Since i rarely build anything that has a set of plans that show exactly where everythig goes, the entire airplane gets built to where it could be flown, the dis-assembled, finished and reassembled for flying.
The only time this changes is if its a glassed sbd painted surface. Then i do all the glass work before initial assembly and setup.
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
(in reply to zippome)
       Post #: 9
RE: Just wondering about people's build styles.. - 12/25/2012 5:18 PM
Marinep51
Score: 100
Status: offline
Being I'm an old newbie to building from plans I have not figured out a set procedure other than to build by the plan.  Unfortunately the plans lead me to cussing the designer and drawer, recutting, wondering what to do next, and long delays in finishing.  It's fun but very frustrating.
Hide Signatures
(in reply to invertmast)
       Post #: 10
RE: Just wondering about people's build styles.. - 12/26/2012 6:02 AM
52larry52
Score: 120
Status: offline
I also do like Gray Beard and after getting the basic structures glued together I do a mock up on the balancer, taping all the other parts in place to get a rough idea if the plane is tail or nose heavy. That is the time while it's still "in the bones" to make any changes in components or locations to have the lightest finished total weight. I checked #3.
Hide Signatures
(in reply to Marinep51)
       Post #: 11
RE: Just wondering about people's build styles.. - 12/26/2012 10:59 AM
john josey
Score: 110
Status: offline
I think every build is different, even to the point of when building something for a second time i have always made changes to the original build that i never thought would be an issue the first time round. Interesting thread though.
Hide Signatures
(in reply to 52larry52)
       Post #: 12
RE: Just wondering about people's build styles.. - 12/26/2012 12:34 PM
dignlivn
Score: 136
Status: offline
But that's just me.
Bob
Hide Signatures
       Post #: 13
RE: Just wondering about people's build styles.. - 12/26/2012 1:24 PM
sensei
Score: 176
Status: offline
# 3 for the most part.
Bob
Fly It Like You Stole It!!!
Hide Signatures
(in reply to dignlivn)
       Post #: 14
RE: Just wondering about people's build styles.. - 12/26/2012 4:19 PM  1 votes
Zor
Score: 181
Status: offline
Hello,
I did not vote because _ _ _
Build exactly to print . . .
Shape the plane from print . . .
Mock up everythng . . .
To me it all means the same thing and I could put a check mark on all three lines so I did not vote.
Building style is a matter of personal choice that is as unique as the builder and his experience.
Is there a better "building style" ?
How can a "building style" be evaluated ?
The anwers to these questions can be judged in a crash landing.
The less damage the better was the building style.
Contributing factors are the design, the selection of the material, the fastening method as applicable (screwing, soldering and gluing), the methods used for rigging ( decalage, wash in and wash out, dihedral, etc...), selection of covering method for strength, weathering and long life.
Just my point of view.
If you ask for advice you will get as many varied instructions as the number of people you ask.
Do not forget to ask "why" and evaluate the reason(s) with your own intelligence.
Then you can proceed to your own satisfaction.
Zor
Hide Signatures
       Post #: 15
RE: Just wondering about people's build styles.. - 1/2/2013 3:41 AM
Leroy Gardner
Score: 116
From: Coeurd'''''''''''''''''''''''''''''''' ALENE,
Status: offline
Why vote just do your home work. There isn't anything you can build that hasn't already been built and tested in the air. By studying the builds and traits you will know what to do to address the problems found by others. If you then read your instructions and study the plans at least a couple of times, add that to what you found out from others and build the thing then go enjoy it, simple as that !
Thats style with results right out of the box.
Leroy Tiger Club # 53, TF 1/5th P-51 mustang
Eagle 2'' bashed Tiger 60
Hide Signatures
(in reply to Zor)
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
