Would you install your elevator servos in balsa?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
S&W 2-6S LCD Battery Capacity & Checker ***FREE SHIPPING US ONLY*****
Seller:  swgiantscalemodels
Details:   $19.89   |  4/2/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> Would you install your elevator servos in balsa?
Page: [1]
Login
Would you install your elevator servos in balsa? - 12/25/2012 3:42 AM
Kmot
Score: 168
Last Login: 5/24/2013
Status: offline
I'm a bit perplexed right now.
I am assembling a VQ giant scale Fly Baby. After cutting out the covering for the horizontal stab, I was able to see inside the fuselage. There are areas cut out of the wood for mounting the elevator servos. Only thing is, it looks like just plain ol' balsa wood to me.
Personally, I would not install servos in balsa sheet on even a park flyer. But maybe my thinking is flawed......
What's you guys opinions?
Click to see fullsize image.
Click for fullsize
_____________________________
~Tom~
Hide Signatures
       Post #: 1
RE: Would you install your elevator servos in balsa? - 12/25/2012 4:49 AM
foodstick
Score: 182
Status: offline
Servo screws into ply of some type is my rule... Can you cut some small rectangles of ply and glue to the balsa area? Sometimes it needs to go behind the existing mounting surface so the servo will sit down inside flush..
Hide Signatures
(in reply to Kmot)
       Post #: 2
RE: Would you install your elevator servos in balsa? - 12/25/2012 5:11 AM
Kmot
Score: 168
Status: offline
I agree with you foodstick. Needs ply at a minimum. I will be able to do something, not sure what yet. I can reach inside with a tool to place pieces of plywood. Just seems so strange to me. I am wondering if it is not balsa, but some sort of Viet Nam jungle wood that has the look of balsa. Tomorrow when it's light outside I am going to poke it from the inside with an Xacto. I suppose I should have done that already. It just really threw me for a curve.
~Tom~
Hide Signatures
(in reply to foodstick)
       Post #: 3
RE: Would you install your elevator servos in balsa? - 12/25/2012 6:09 AM  1 votes
rafeeki
Score: 101
Last Login: 5/22/2013
Status: offline
If u cannot get another layer of thin plywood under it u could pour some thin CA on the balsa wood surface, this will harden it thereby make it stronger.
Rafeek
Hide Signatures
(in reply to Kmot)
       Post #: 4
RE: Would you install your elevator servos in balsa? - 12/25/2012 6:58 AM  1 votes
Giant_Scale_Gasser
Score: 140
Status: offline
Screw them into ply or else you'll regret it, guaranteed.
Hide Signatures
(in reply to rafeeki)
       Post #: 5
RE: Would you install your elevator servos in balsa? - 12/25/2012 7:28 AM
Kmot
Score: 168
Status: offline
Yeah, I hear ya!
~Tom~
Hide Signatures
(in reply to Giant_Scale_Gasser)
       Post #: 6
RE: Would you install your elevator servos in balsa? - 12/25/2012 2:42 PM
s3nfo
Score: 120
Status: offline
Into ply or it don't fly........
Jerry Neuberger
L1324, HoF, LM, CD, Turbine sign-off CD, LMAI
Hide Signatures
(in reply to Kmot)
       Post #: 7
RE: Would you install your elevator servos in balsa? - 12/25/2012 4:18 PM
mikmerl
Score: 100
Last Login: 3/13/2013
Status: offline
You should be able to glue plywood reinforcements internally on the balsa through the hole intended for the servo.
If it is impossible to access the servo mount from behind for reinforcement and if the balsa is thick enough. What I have done with good result in the past is to enlarge the holes in the balsa to about 6mm (1/4 inch).
Then I have cut lengths of hardwood dowels and glued then in the enlarged holes, flush with the outside surface. New holes were drilled in the dowels for the servo screws, add a few drops of thin CA in the hole and all this becomes like concrete.
mike
Nothing is foolproof because fools are so ingenious.
Hide Signatures
(in reply to s3nfo)
       Post #: 8
RE: Would you install your elevator servos in balsa? - 12/25/2012 4:40 PM
Kmot
Score: 168
Status: offline
Thanks guys.
And Mike, that's a great tip!
~Tom~
Hide Signatures
(in reply to mikmerl)
       Post #: 9
RE: Would you install your elevator servos in balsa? - 12/25/2012 5:36 PM
foodstick
Score: 182
Status: offline
you need some forceps with a angled head, tape the ply piece to the forcep, apply glue to the upper face ..slide it in ,position it and gently clamp it with the forcep.. Also a small clamp will work in many cases as well.
Hide Signatures
(in reply to Kmot)
       Post #: 10
RE: Would you install your elevator servos in balsa? - 12/25/2012 6:53 PM
Kmot
Score: 168
Status: offline
Now that it is daylight again and I had all my worklights on I took another look inside, and poked it with my Xacto knife. It's definitely balsa wood that I am looking at.
However, epoxyearl (from another thread) was spot on about it possibly being "balsa plywood" because in a cutout below I can see the thin ply sandwiched between two thin sheets of balsa wood.
I will reinforce it though to be safe.
Thanks guys!
~Tom~
Hide Signatures
       Post #: 11
RE: Would you install your elevator servos in balsa? - 12/25/2012 11:43 PM
straitnickel
Score: 105
Status: offline
It's good you saw that before you put the stab on, now it will be easy to reinforce the servo area with plywood or base wood. Better safe than sorry
I don''''t always crash, but when I do!
Hide Signatures
(in reply to Kmot)
       Post #: 12
RE: Would you install your elevator servos in balsa? - 12/26/2012 12:15 AM
Airplanes400
Score: 202
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: Kmot
And that's only one structural flaw that you can see. Check the rest of the plane for other questionable design flaws like this.
We in the Federal Government have no sense of humor that we are aware of.
Hide Signatures
(in reply to Kmot)
       Post #: 13
RE: Would you install your elevator servos in balsa? - 12/26/2012 4:37 AM
vertical grimmace
Score: 154
Status: offline
Imagine how many issues like this go by the wayside by the inexperienced ARF assembler? Kinda scary really.
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
(in reply to Airplanes400)
       Post #: 14
RE: Would you install your elevator servos in balsa? - 12/26/2012 7:00 AM
nitro wing
Score: 125
Status: offline
all good advice above
Hide Signatures
(in reply to vertical grimmace)
       Post #: 15
RE: Would you install your elevator servos in balsa? - 12/26/2012 5:54 PM
Kmot
Score: 168
Status: offline
Thanks everyone!
~Tom~
Hide Signatures
(in reply to nitro wing)
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
