raron455
Score: 100 Joined: 9/11/2012 Last Login: 5/19/2013 From: robinson,
TX, USA Status: offline
I bought a 30% edge 540 made by Peak, plane is nice, put together as well as my wild hare I used to fly, it has an actual 94" wingspan I measured on it, and I am looking for some opinions, advice, experience on engine. The manufacturer says 50-60cc. However I have a great da-85 that I am almost convinced on putting on it. Here is my logic and tell me if its off and why you believe that, experience is always the best teacher,, A dle-55 weighs right at 3 lbs, the da-60 is stated as 3.1 lbs, the Da-85 listed at 4.3 so it is just a little over 1lb heavier than the da-60 which is what the manufacturer recommends, this is all engine weight manufactures generally never list total powerplant weight,,. I am reinforcing the firewall, and fuselage runners, adding a piece of ply to both sides of the firewall and pinning it, also using aluminum angle to tie it all to the fuselage, (I do this stuff no matter what,, once I get a new plane, I always reinforce the engine box),, The way I am thinking is this, running the da-85 with a carbon fiber spinner, and the ignition as far as it will go into the fuselage, and putting the batts in the tray with the reciever, (maybe a little further back) I should be able to compensate for that extra lb to get my CG where Its supposed to be,, if not I could run a little heavier tail wheel assembly to bring it where it needs to be. Now the only thing I see that is not as the manufacturer designed is that the plane will be a little heavier, but with the CG correct the plane should fly well, just perhaps a little more wing loading, but would have way more power than It needs, which is always a good thing,,,,at least to me. Laying out the da-85 it will fit fine on the firewall,, We have a club member who flys a 30% Yak with a da-85 on his and the power is insane, thats why I believe it will be fine in mine,, I know alot of you guys have seen alot and put together you have probably seen everything,, SO let me know if you think this is a good setup for great power, or a bad Idea because I am just about to jump into it with both feet,, thanks fellas
Hide Signatures
