big stik 60 recover question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> big stik 60 recover question
Page: [1]
Login
big stik 60 recover question - 12/25/2012 1:48 PM
tlojak38
Score: 113
Last Login: 5/22/2013
Status: offline
Hi. I have a question. I'm recovering a big stik 60, and I'm wondering how to go about covering the ailerons and elevator control surfaces. Normally this wouldn't be a problem, bit if you've had or seen these surfaces. They have a contoured edges on them, and that is a little confusing. Anyone know how to go about getting that done? Thanks for any help!
_____________________________
It''''s not how big the plane is, but how you fly it.
Hide Signatures
       Post #: 1
RE: big stik 60 recover question - 12/25/2012 2:33 PM
nh4clo4
Score: 105
Status: offline
The way I found the best is to cover one side, lay it down on the side you just covered, trim the scalloped to about 1/8-3/16 oversize, then make a few slits so it conforms around the edge, when you do the other side, slit the covering in so this side will overlap the slits on the first side.
Take a scrap of balsa and practice, they do add to your covering time.
Good luck and Merry Christmas
Ed
Goldberg Tiger Club #25
Hide Signatures
(in reply to tlojak38)
       Post #: 2
RE: big stik 60 recover question - 12/25/2012 2:38 PM
bbbair
Score: 100
Last Login: 5/21/2013
Status: offline
OK - I wasn't sure what you meant by 'Contours' so I looked up the plane and saw the trailing edges are 'scalloped' and YES, I can see why they would be difficult to recover.
Personally - I'd replace the elevator and Ailerons with a strait edge... but that is just me.
OK, Plan 'B' Heat, patience and time are the key ingredients here.
Cover as per normal routine and when you come to the Scallops you take your iron and heat up the covering around the individual Scallop pull the covering with a gentle pressure and keep adding the heat around the Scallop (yes you are stretching the covering). Pulling down to get the covering around the TE. Repeat for each Scallop and trim with a Xacto knife.
(Plan 'A' is much simpler )
Happy Landings!
It's Time to Kick the Tires and Light the Fires!
Hide Signatures
       Post #: 3
RE: big stik 60 recover question - 12/25/2012 5:18 PM
eddieC
Score: 249
Status: offline
Plan C, I'm lazy: cover the scallops with one thin piece, then the bottom followed by the top. I touch all my seams with clear nail polish to prevent the dreaded fuel creep.
I might not be very good, but I am fun to watch!
Hide Signatures
(in reply to bbbair)
       Post #: 4
RE: big stik 60 recover question - 12/25/2012 5:30 PM
Gray Beard
Score: 314
Status: offline
If your using Ultracote covering there is no problem. You just bring the covering over the edges a little loose and stick the covering down with the rounded shoe on a trim iron then the covering can be shrunk. Ultra is really good for this. Or you can just use the trim iron and run a strip along the inside of the scallop, then cut slits in the covering so you can run the covering back onto the flat surface of the control. Now you just cover the controls and trim evenly along the edge. The covering really sticks well to itself. Hope that made some sense to you. Easier to show someone then to try to explain it.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to eddieC)
       Post #: 5
RE: big stik 60 recover question - 12/26/2012 9:26 AM
tlojak38
Score: 113
Status: offline
I think I understand. I've been watching videos on here and I think I'm going to try the stretch method, like they use to do the end of a wing. I'll try it on a piece of scrap that ill put some scallops on. Thanks for allthe good ideas, and if all else fails, plan b will go into effect.
Hide Signatures
(in reply to Gray Beard)
       Post #: 6
RE: big stik 60 recover question - 12/26/2012 12:31 PM
dignlivn
Score: 136
Last Login: 5/19/2013
Status: offline
You could sand the Scalloped T.E. ,so it is straight. (planB)
Bob
Hide Signatures
       Post #: 7
RE: big stik 60 recover question - 12/29/2012 7:39 AM
icegs
Score: 100
Last Login: 4/27/2013
Status: offline
I did a 40 size last summer with the same trailing edge. I got a partially built kit that had two rolls of Solarfilm inside, so I used that. The covering material in general was terrible (in my opinion anyways), but covered the scallops fairly easily. I can't see me using Solarfilm again; it's easy to melt, and not very durable. The colour/adhesive has separate from the film in a number of places after about a year of infrequent flying, and can only be corrected by recovering.
I used a trim iron with fairly high heat, and just gradually worked the covering down into the scallops pushing it with the iron to stretch it. The green is Solarfilm, and the white is Monokote (my usual preference). The Monokote went into the scallops fairly well too, but took a little longer to stretch. The trailing edge of the ailerons took more time than the whole wing to cover.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to dignlivn)
       Post #: 8
RE: big stik 60 recover question - 1/6/2013 1:51 AM
tlojak38
Score: 113
Status: offline
hello. just an update on the recover. the pic is just the fuse, but i did find a relatively easy way to cover the scalloped edge on the elevator, and ailerons. i tried it on the elevator, and it worked well.
Click for fullsize
Hide Signatures
(in reply to icegs)
       Post #: 9
RE: big stik 60 recover question - 1/6/2013 5:25 AM
tailskid
Score: 199
Status: offline
And what was the method you used to cover the scalloped edges?
# 93 in Club Saito
Carl Goldberg Ultimate Brotherhood # 12
Hide Signatures
       Post #: 10
RE: big stik 60 recover question - 1/6/2013 11:20 AM
tlojak38
Score: 113
Status: offline
I took a thin strip that was longer than the elevator and de the scalloped edge first, trimmed it, and covered the rest.
Hide Signatures
(in reply to tailskid)
       Post #: 11
RE: big stik 60 recover question - 4/2/2013 10:46 AM
Inter1
Score: 100
Last Login: 4/5/2013
Status: offline
As mentioned just cut and fold for the scallops, you can have real fun recovering this plane
Ian
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.281RCU1
