Another Ziroli Hellcat build!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Another Ziroli Hellcat build!!
Page: [1] 2   next >   >>
Login
Another Ziroli Hellcat build!! - 12/25/2012 9:52 PM
Check6
Score: 105
Last Login: 5/22/2013
Status: online
After trying to sell this kit on line without any success, I decided to just go ahead and build it. First pic is of the building room all cleaned and ready to go. Trust me, it won't look this clean once I get started. LOL I inventoried all the parts and found I have a few parts miscut. I will contact National Balsa and make them aware of this. Also missing all the strip wood for the fuse former notches. I have to say the lazer cutting is superb , very clean and the parts fell right out. Here we go, stay tuned and feel free to add your comments and recommendations as I go along. There are a couple of expert Hellcat builders on this site. Sam Parfitt and Mirce to name a couple. I'm sure I missed some others and I apologize for the oversite.
Fred
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: Another Ziroli Hellcat build!! - 12/25/2012 10:01 PM
OldScaleGuy
Score: 120
Status: offline
Subscibed and looking forward to your build.
_____________________________
Steve - Spitfire Brotherhood #144
Full size airplanes are real, our models are too.
Hide Signatures
(in reply to Check6)
       Post #: 2
RE: Another Ziroli Hellcat build!! - 12/25/2012 10:11 PM
Check6
Score: 105
Status: online
Hi Steve,
Welcome to the build.
Fred
Hide Signatures
(in reply to OldScaleGuy)
       Post #: 3
RE: Another Ziroli Hellcat build!! - 12/26/2012 12:03 AM
mirce
Score: 151
Status: offline
You will enjoy and if you need some help, let me know...
Regards
Mirce
Rivets, Screws, Panel lines, Detail & Finish Sets, Paint Masks and other equipment for scale warbirds - www.nsmodelers.rs
Hide Signatures
       Post #: 4
RE: Another Ziroli Hellcat build!! - 12/26/2012 12:40 AM
Check6
Score: 105
Status: online
Hi Mirce,
Thanks for checking in. I have your build bookmarked for future reference.
Fred
Hide Signatures
(in reply to mirce)
       Post #: 5
RE: Another Ziroli Hellcat build!! - 12/26/2012 2:27 PM
OldScaleGuy
Score: 120
Status: offline
Fred, Mirce, i too have one framed up. I got well along but was unemployed at the time and stopped working on it due to the need for the retracts. Since getting back to work, there have been other projects that have taken up the spare time. Here is a thread on it if you care to have a look. http://www.rcgroups.com/forums/showthread.php?t=1165676
Hide Signatures
       Post #: 6
RE: Another Ziroli Hellcat build!! - 12/26/2012 4:43 PM
Check6
Score: 105
Status: online
Hi Steve,
Just checked out your build , it looks great!!
I just started framing the stab. I'm missing all the stringers for my fuse build so I'm working around it until I get them.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 7
RE: Another Ziroli Hellcat build!! - 12/28/2012 11:42 PM
Check6
Score: 105
Status: online
OK I have the stab framed and sheeted, Elevators next.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: Another Ziroli Hellcat build!! - 12/29/2012 4:31 AM
Check6
Score: 105
Status: online
Completed one of the elevators. I departed from the plans by adding another 1/2 in. to the inside of the leading edge. I did this to bring the hinge pivot 3/8 of in. inside the leading edge. I will be using the large Robart hinge points. This allows me to make a nice radius instead of a V hinge at the LE. Also gives a more scale look to the leading edge while adding stiffnes.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 9
RE: Another Ziroli Hellcat build!! - 12/29/2012 5:08 PM
Check6
Score: 105
Status: online
OK the elevators are rough out. The radius is a lot better on the leading edge as well as the recessed hinge joint
Will start on the fin and rudder next.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 10
RE: Another Ziroli Hellcat build!! - 12/29/2012 11:46 PM
tailskid
Score: 199
Last Login: 5/21/2013
Status: offline
subscribed....
# 93 in Club Saito
Carl Goldberg Ultimate Brotherhood # 12
Hide Signatures
       Post #: 11
RE: Another Ziroli Hellcat build!! - 12/30/2012 8:32 AM
mirce
Score: 151
Status: offline
Fred, on my first Hellcat I cover rudder and elevators with Oratex and paint it. After some time on those parts I saw some small cracks and on one - two edges oratex start to flipping out.
On next F6F (yellow) I cover those parts with 0,8 mm balsa, and made details with filler. First, construction is much stronger, no more worry about flipping out, and cracks, all in all, I think that is much better solution.
http://www.rcuniverse.com/forum/m_3711339/mpage_25/key_/tm.htm
Think about that...
Regards
Mirce
Hide Signatures
(in reply to tailskid)
       Post #: 12
RE: Another Ziroli Hellcat build!! - 12/30/2012 6:48 PM
Check6
Score: 105
Status: online
Hi Mirce,
Yes I saw your fix. I'm still going to cover the surfaces with Solartex. This fabric really covers well and stays tight and give it the scale fabric look. Although I must say your detail set you sell looks fantastic. I will be ordering a set for mine.
Just finished roughing out the fin and rudder. I guess I'll start making the fuse crutch. I have to order the stringers they were omitted from my kit
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to mirce)
       Post #: 13
RE: Another Ziroli Hellcat build!! - 1/4/2013 10:16 PM
Check6
Score: 105
Status: online
Ok I have most of the fuse formers glued to the crutch. Last 3 are still floating since I was installing the tailwheel retract. Also taped the cowl on as an incentive to finish the fuse. LOL I have to order the fuse stringers since they were omitted from the kit. I'll be starting on the wing while I wait for the parts to come in.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 14
RE: Another Ziroli Hellcat build!! - 1/4/2013 10:55 PM
Ram-bro
Score: 156
Status: offline
looking good Fred
Hide Signatures
       Post #: 15
RE: Another Ziroli Hellcat build!! - 1/5/2013 12:05 AM
tailskid
Score: 199
Status: offline
it is beginning to look like a Hellcat!!!!!!
# 93 in Club Saito
Hide Signatures
(in reply to Ram-bro)
       Post #: 16
RE: Another Ziroli Hellcat build!! - 1/5/2013 12:53 AM
Check6
Score: 105
Status: online
Hey Tony,
Now about that Grumman with the funny landing gear. When do we deal. LOL
Hey Jerry,
Yes its getting there . Thanks for checking in.
Later,
Fred
Hide Signatures
       Post #: 17
RE: Another Ziroli Hellcat build!! - 1/5/2013 1:22 AM
MarkShapiro
Score: 100
Last Login: 5/20/2013
Status: offline
Nice looking work, Fred. Following closely.
Hide Signatures
       Post #: 18
RE: Another Ziroli Hellcat build!! - 1/5/2013 1:32 AM
tailskid
Score: 199
Status: offline
What are you going to power this baby with?
# 93 in Club Saito
Hide Signatures
(in reply to MarkShapiro)
       Post #: 19
RE: Another Ziroli Hellcat build!! - 1/5/2013 3:07 AM
Check6
Score: 105
Status: online
Thanks Mark, would have loved to have done a deal with you.
Here you go Jerry.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 20
RE: Another Ziroli Hellcat build!! - 1/5/2013 6:29 AM
tailskid
Score: 199
Status: offline
My son had one of those about 4-5 years ago and LOVED it....very reliable......so Good Choice!
# 93 in Club Saito
Hide Signatures
       Post #: 21
RE: Another Ziroli Hellcat build!! - 1/5/2013 9:54 AM
mirce
Score: 151
Status: offline
Take care about weight.
If model is more than 20 kg GT 80 will not be enough. Other thing, that engine will deliver more and more power with every next gallon of gasoline...
Regards
Mirce
Hide Signatures
       Post #: 22
RE: Another Ziroli Hellcat build!! - 1/5/2013 5:49 PM
Check6
Score: 105
Status: online
Hi Mirce,
Hope I can keep it under 44 lbs. Just made up the elevator joiner wire. I don't like to use 2 servos for the elevator. Using one with a 3/16 in. joiner wire with an 8 /32 hardened bolt threaded into a 3/16 wheel collar. I grind a flat and then loctite on the bolt thread. Tighten it down and your good to go. Have used this method on over 40 large scale Warbirds without a problem
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to mirce)
       Post #: 23
RE: Another Ziroli Hellcat build!! - 1/5/2013 8:43 PM
Check6
Score: 105
Status: online
OK, I filled in the wire joiner area on the elevators with balsa, makes for a nice solid area to glue in the wire. Just placed everything on the fuse for inspiration. LOL
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 24
RE: Another Ziroli Hellcat build!! - 1/6/2013 3:53 AM
91zulu
Score: 130
Status: offline
Are you sure the hole that the wire is in will not enlarge over time and cause the elevator to develop play ? This use to happen on my 40 size planes a while back and what I started doing was the slot that the wire is in I filled with either powder or micro balloon then soak with thin CA the whole area. No more soft area and no more elevator slop.
91-Zulu
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.688RCU1
