Question abought Losi Mini Crawler    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Slash 4x4 roller with TQ 2.4GHz Traxxas Link - Kit
Seller:  Callifas38
Details:   $150.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> Question abought Losi Mini Crawler
Page: [1]
Login
Question abought Losi Mini Crawler - 12/26/2012 12:08 AM
B_Krukow
Score: 105
Last Login: 1/26/2013
Status: offline
My 5 year old son got a Losi Mini crawler from santa this morning and seeing as how its below 0(F) outside he has been bashing it in the house all day.  We already have a pile of rocks in the basment (unfinished)  we setup for him to drive my Summit on so he has been down there all day crawling around on it.  I was just down there and noticed that the left rear wheel was not spinning when he got stuck.  I grabbed ahold of it and it apears that it has a limited slip type of drive on that wheel while the rest are solid to the drive train.  I can spinn it with very minimal resistance.  I can feel it dragging a little but not much.  When I hold onto the wheel I can easaly stop it with minimal efort while the other three will stop the motor if I grab them.  I presume something is broke already but figured i would ask here to see if there was any known week points I should look for before I tear it apart.
Hide Signatures
       Post #: 1
RE: Question abought Losi Mini Crawler - 12/26/2012 2:35 AM
nitrosportsandrunner
Score: 296
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: B_Krukow
If you remove the wheel nut and take of the wheel, there is a plastic hex piece. Behind that, is a small metal drive pin. Whats most likely is that either that pin broke, or the plastic hex got rounded off (corners stripped, like if you stripped the head of a bolt)
Also, check the backside of the wheel where that plastic hex fits in. Sometimes that part can get rounded of when the hex does.
If the hex or the wheel's hex slot got stripped, then super glue the hex into the wheel. If the pin broke, you can cut a body clip with a pair of wire cutters to the length needed to replace the pin.
_____________________________
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to B_Krukow)
       Post #: 2
RE: Question abought Losi Mini Crawler - 12/26/2012 3:35 AM
B_Krukow
Score: 105
Status: offline
Got it apart and found out the center is stripped out of the ring gear.   Where the axle shaft goes into the ring gear there is no flats to engage the drive shaft.  its just round in there.  The weird part is that there is almost no shreds of pastic like you would expect to see if it had stripped out from binding up.  its almost like there was no material there to begin with.  I will have to call Losi tomarow and see if they are gona stand behind it or not.  I highly dought it but i will give them the chance to.  While looking it over durring this ordeal I also found that one of the upper front shock mounts was so loose it was ready to fall out.  There couldent have been more than 1 or 2 threads holding it in.  I love paying $240 for junk that is half ass built.
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 3
RE: Question abought Losi Mini Crawler - 12/26/2012 6:10 AM
SyCo_VeNoM
Score: 621
Status: offline
quote:
ORIGINAL: B_Krukow
should try their micros that get a whole 10 feet of range, and to get them to behave like they should you have to fork out $90 for a 2.4ghz board and additional for a losi 2.4ghz radio.
With great speed comes greater repair bills.
Look at my garage for my model list.
Hide Signatures
       Post #: 4
RE: Question abought Losi Mini Crawler - 12/26/2012 4:09 PM
Score: 296
Status: offline
its odd that that part gave before the drive pin or hex.
You mentioned your kid had been driving it alot. With crawlers, if the wheel gets pinched between rocks and cannot turn but you still give it full throttle then stuff can break. The slipper clutch is supposed to prevent this. But maybe on yours the slipper clutch is too tight.
Hide Signatures
(in reply to SyCo_VeNoM)
       Post #: 5
RE: Question abought Losi Mini Crawler - 12/26/2012 11:55 PM
B_Krukow
Score: 105
Status: offline
Ya i thought it was weird that that gave before the slipper cluch as well but like I said it apears that there wasent much material in there to begin with because I would expect to see a fair amount of plastic peices mauled up where it ripped material from the inside of the ring gear but there was not much of anything.  just a couple small slivers of material.  makes me thing that there was something wrong to begin with.  Either way Losi is sending me a new center section in the mail already so its all good.  I will just have to take 10 minutes to put it in when it gets here.  For now he is running it with 3 wheel drive.
Hide Signatures
       Post #: 6
RE: Question abought Losi Mini Crawler - 12/30/2012 5:42 AM
jmz6
Score: 100
Last Login: 4/13/2013
Status: offline
Are these the problem?
They were junk from the start, Losi and a bunch of aftermarket companies made upgraded metal ones.
We replaced both plastic front and rear sets and the plastic locker in the trans pretty much from the start in our competition trucks. You don't want to put plastic back in there or it will only do the same before long. Expect maybe $40 to replace all the lockers
Center locker in transmission
Hide Signatures
       Post #: 7
RE: Question abought Losi Mini Crawler - 1/5/2013 12:56 AM
B_Krukow
Score: 105
Status: offline
Ya those where the problem.  I put it back together and he had it up and running for all of abought 30 minutes when teh entire thing up and died.  I have no idea what the isue is this time.  The LED lights on the ESC come on but the little green light on the receiver just blinks for a split second as you are turning it on then goes out.  I have no idea what the isue is but now its been dead most of the week because of that.  Now I have to drive 120 mile round trip to the Hobby store I bought it from so they can look at it.  The top shock mounts all keep backing themselves out as well.  I guess I need to get some locktite on them.  Overall I am realy not impressed with Losi quality.
Hide Signatures
(in reply to jmz6)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.797RCU1
