EPX Slow on charged battery    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> EPX Slow on charged battery
Page: [1]
Login
EPX Slow on charged battery - 12/26/2012 4:04 PM
RaveCrusader
Score: 100
Last Login: 5/28/2013
Status: offline
 Question for everyone..I bought my son an EPX and a couple extra batteries..I charged all of the batteries and have checked the voltage on all of them. When we put the batteries in the EPX the vehcle runs like the batteries are drained..its slow forward and and reverse and will only turn the wheels when the forward and/or reverse are not engaged..Is it the ESC? seems like a strange problem considering it happens on multiple batteries.
Hide Signatures
       Post #: 1
RE: EPX Slow on charged battery - 12/26/2012 4:16 PM
nitrosportsandrunner
Score: 296
Last Login: 6/19/2013
Status: offline
so, does the model want to back up without you giving any throttle input?
If thats the case, try adjusting the throttle trim on the radio until the model no longer moves (with the throttle trigger at nuetral)
Im wondering if your throttle trim has the ESC thinking that nuetral is like 10-20% reverse. In that case, when you pull full throttle the ESC only would see 30-50% throttle.
When you apply throttle, how much do you have to give before the wheels start to move forward?
_____________________________
SC10 brushless, Thunder Tiger Phoenix XB Brushless, 1/5 custom rock crawler, Slash 4x4, Atomik Barbwire
Hide Signatures
(in reply to RaveCrusader)
       Post #: 2
RE: EPX Slow on charged battery - 12/26/2012 4:35 PM
RaveCrusader
Score: 100
Status: offline
I adjusted the throttle trim and no affect on the speed. Even with throttle tim all the way up which should have the car going forward it was at a snails pace and giving it throttle had no affect either..Its strange, have two other electric redcats which are fine. When I turn it on the ESC goes through the paces beeps at me when its ready and all seems to be working fine escept forward or reverse there is no speed.
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 3
RE: EPX Slow on charged battery - 12/26/2012 4:53 PM
Score: 296
Status: offline
quote:
ORIGINAL: RaveCrusader
Ok,
does the manual explain how to calibrate the ESC to the radio?
you could test the motor itself by plugging the motor's ends into the battery plug. Youd have to have the truck's wheels off the ground. I havent heard of a motor being bad, but its best to rule out what you can before contacting Redcat about a warrenty issue. If we can rule out everything but the ESC, then it will be easy to get redcat to ship you a replacement.
You have already ruled out the battery as you used others ones you have.
Just for fun, try plugging the ESC's plug into the servo's port on the reciever. Then turn it on and see if the steering wheel controls the speed and if the speed is any higher.
Hide Signatures
       Post #: 4
RE: EPX Slow on charged battery - 12/26/2012 10:40 PM
RaveCrusader
Score: 100
Status: offline
Well I am now guessing it was the ESC..after messing with it and using various batteries I got it going at what I thought was a decent speed..then after about 30 seconds the ESC starting smoking and the entire base melted...yay...maybe I should have bought the EPX Pro..becuase I think I should just upgrade it for my son to a brushelss lipo setup...do you think I should go through Redcat for a replacement or upgrade? I am not real upset it went south except I did not get to enjoy baching with my son..upgrade or replacement parts?
Hide Signatures
       Post #: 5
RE: EPX Slow on charged battery - 12/26/2012 10:58 PM
Score: 296
Status: offline
Id get the replacement from redcat. They are good about warrenty parts, and if you tell them the ESC smoked they will ship you a new one. Might wanna look for a used traxxas XL-5 or simillar low priced esc. Ive gotten a losi 12t and a xl-5 for aroudn $25 shipped.
The epx pro has a couple of upgrades to help it cope with the extra power. At the least, I know it has a steel spur gear and full ball bearings. Im not certain if the epx has steel diff gears of if they are plastic. If they are plastic, they will need to be upgraded for sure.
So, to do it right you will need more than just a brushless system. Thats why I think getting a better, used ESC is a good way to go.
Hide Signatures
       Post #: 6
RE: EPX Slow on charged battery - 12/29/2012 4:26 AM
RaveCrusader
Score: 100
Status: offline
Well I contacted Redcat and they are sending me a new ESC free of charge and it shipped out today. The more I deal with Redcat (I have 5 in the family) the more I love them.
Hide Signatures
       Post #: 7
RE: EPX Slow on charged battery - 12/29/2012 6:57 AM
Johnathond22
Score: 100
Last Login: 6/9/2013
Status: offline
 I can agree, we have several now and they were really good about correcting bad parts, especially right out of the box. I am currently hunting down the best upgrades possible. I have been building a few of my own also due to inability to get full aluminum chassis. I am posting a few photos in case I decide to start building to sell.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: EPX Slow on charged battery - 12/29/2012 3:57 PM
Score: 296
Status: offline
quote:
ORIGINAL: Johnathond22
is that an axial or emaxx bumper you added to the back of your chassis?
Hide Signatures
(in reply to Johnathond22)
       Post #: 9
RE: EPX Slow on charged battery - 12/29/2012 5:42 PM
Johnathond22
Score: 100
Status: offline
 I made that too. Everything you see is handmade. I'm building a few more items right now becuse the weather is too bad to run my truck so I am modding. Do you have an EPX pro also?
Hide Signatures
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.563RCU1
