Tacon motor for airboat    Gallery
Logged in as Guest
    Search This Thread
Printable Version
98 inch Caribou - ARF
Seller:  AUSTARSMODEL
Details:   $820.00   |  4/15/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> Tacon motor for airboat
Page: [1]
Login
Tacon motor for airboat - 12/26/2012 6:08 PM
X1AaronW
Last Login: 4/23/2013
Status: offline
I know this is an airplane forum but who to help me figure this out than you guys. I am curious as to weither or not you can use a tacon 3660 or 2848 540xl for an air boat. Im not worried about the power to weight ratio because im not trying to gain any lift. the 3660 is an 1800kv motor and the 2848 540xl is a 4300 kv motor. im not sure what size prop either of them require to maintain an acquitted load. so what i want to know is how would you find out? Is there some kind of formula?
Hide Signatures
       Post #: 1
RE: Tacon motor for airboat - 12/27/2012 2:27 AM
blvdbuzzard
Last Login: 5/11/2013
Status: offline
I looked up the 3660 motor. These are for cars and trucks correct? if so, the motor may not have the thrust washers needed to handle the pull of the prop on the shaft. The motors for the planes are setup to hold the shaft from the pull of the prop. These look to be setup to handle the side loads on the shaft. They may work fine, I have not put a prop on a car / truck motor.
Buzz.
Hide Signatures
(in reply to X1AaronW)
       Post #: 2
RE: Tacon motor for airboat - 12/27/2012 11:55 AM
X1AaronW
Status: offline
yes they are truck motors. i figured it would be ok because what im using it for is a pretty low weight and im only using 7.4 volts. do you think it would still be an issue?
Hide Signatures
(in reply to blvdbuzzard)
       Post #: 3
RE: Tacon motor for airboat - 12/28/2012 2:44 AM
blvdbuzzard
Status: offline
Not sure how the motor's are put together. So it may be good to go for a long time or it might go crunch after a pack or two.
Do you have a watt meter? Start with a 7X4 prop and see how many amps it pulls.
Buzz.
Hide Signatures
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.188RCU1
