Magnum xl 180 2 stroke    Gallery
Logged in as Guest
    Search This Thread
Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  4/28/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Magnum xl 180 2 stroke
Page: [1]
Login
Magnum xl 180 2 stroke - 12/26/2012 7:33 PM
edd540
Score: 100
Last Login: 1/2/2013
Status: offline
I just bought a magnum 180 2 stroke used . bearings felt a bit rough. I pulled the backplate and the rear bearing is rusty. Thought I would tear it down and put in new bearings. I have the engine apart with the sleeve out but there is not enough clearance to get the connecting rod off the end of the crankpin. Does anyone have any knowledge on how to get this thing apart. ive been in rc for 20 years so this isnt my first engine rebuild , but this on has me stumped.
Hide Signatures
       Post #: 1
RE: Magnum xl 180 2 stroke - 12/26/2012 9:44 PM
Broken Wings
Score: 141
Last Login: 5/19/2013
Status: offline
You need to clean the castor off the wrist pin up inside the piston where the rod connects to the piston. Cleaning the castor off will allow you to take an Allen wrench and gently pull the connecting rod towards the rear end of the case.
You just hook the "L" portion of the allen wrench around the back side of the rod through the rear end of the case where you removed the rear cover..
Once the rod moves you should have enough clearance to get the rod off the crank pin.
I use Dawn Power Disolver, a couple squirts, wait ten mins....
_____________________________
Club Saito member #715
Club Jett member #12
Hide Signatures
(in reply to edd540)
       Post #: 2
RE: Magnum xl 180 2 stroke - 12/26/2012 11:19 PM
Gregor32
Score: 100
Last Login: 5/7/2013
Status: offline
i dont know this motor but ive found in the past sometimes you need to be at bdc and use a transfer port to gain enough rearward movement. Greg
Hide Signatures
(in reply to Broken Wings)
       Post #: 3
RE: Magnum xl 180 2 stroke - 12/27/2012 2:04 AM
earlwb
Score: 584
Status: offline
You also need to remove the cylinder sleeve too.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to Gregor32)
       Post #: 4
RE: Magnum xl 180 2 stroke - 12/27/2012 2:22 AM
Broken Wings
Score: 141
Status: offline
He's posted that he has removed the sleeve...
Hide Signatures
(in reply to earlwb)
       Post #: 5
RE: Magnum xl 180 2 stroke - 12/27/2012 2:32 AM
earlwb
Score: 584
Status: offline
Oops sorry.
AMA # 928076
Hide Signatures
       Post #: 6
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> Magnum xl 180 2 stroke
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.176RCU1
