Question regarding Triton Junior charger to charge Tornado battery    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Question regarding Triton Junior charger to charge Tornado battery
Page: [1]
Login
Question regarding Triton Junior charger to charge Torn... - 12/27/2012 4:09 AM
rfrees
Score: 100
Last Login: 12/28/2012
Status: offline
I bought a Triton Junior charger to charge my son's Tornado EPX pro stock battery.  It is 7.2V 2000Mah, but when I charge it, the charging system usually reads that it is 7.4 all the way up to 9.6V by the time it's done charging in about an hour.  The battery feels slightly warm after it charges...just wondering if this is normal.
ryan
Hide Signatures
       Post #: 1
RE: Question regarding Triton Junior charger to charge ... - 12/27/2012 12:16 PM
nitrosportsandrunner
Score: 296
Last Login: 5/26/2013
Status: online
9.6v seems a bit high....but if the battery isnt hot to the touch then you are fine. All batteries charge above their respective voltages. The voltage spec is the "nominal" reading. Fact is, after you take it off the charger the voltage likely drops to around 7.4-8.0, and the second you punch the throttle the voltage drops (due to the load on it) to 7.2v
If you are still concerned, you can lower your charger's charging rate. You shouldnt be charging that battery at more than 2amps. You certainly can charge it higher than that....but it will shorten the life of the battery.
In the day, racers used to charge their 3000mah packs at 6amps! But they could afford to replace the battery after just a few races.
_____________________________
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to rfrees)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
