Can't learn Rc    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> JetCat Turbine Direct Support >> Can't learn Rc
Page: [1]
Login
Can't learn Rc - 12/27/2012 4:44 AM
shepp
Score: 100
Last Login: 5/21/2013
Status: offline
My New P-70 won't learn rc. It goes to release to learn rc then says move throttle to idle and green light flashes real fast. Can go no further. Any suggestions?
Shepp
Hide Signatures
       Post #: 1
RE: Can't learn Rc - 12/27/2012 11:52 AM
frema
Score: 103
Last Login: 5/22/2013
Status: offline
thats not right
it say move trottle trim first
you missed a step
try agian
Hide Signatures
(in reply to shepp)
       Post #: 2
RE: Can't learn Rc - 12/27/2012 2:35 PM
ddennison
Score: 103
Status: offline
Are both the trim and throttle stick at their lowest points?
Hide Signatures
(in reply to frema)
       Post #: 3
RE: Can't learn Rc - 12/27/2012 2:52 PM
frema
Score: 103
Status: offline
yes when you start yes
and then go step by step
first its the trim
and then its the throtle stick
i hope you can do something with my info
Regards,
Martin.
Hide Signatures
(in reply to ddennison)
       Post #: 4
RE: Can't learn Rc - 12/27/2012 3:31 PM
Greg Wright
Score: 102
Status: offline
Use the instruction manual it will take you thru the set-up procedure step by step.
_____________________________
Greg Wright
Not a Horizon team member/ But would love to be one!!!!!!!!!!!! BVM Jets/Jetcat
Hide Signatures
(in reply to frema)
       Post #: 5
RE: Can't learn Rc - 12/27/2012 3:38 PM
shepp
Score: 100
Status: offline
according to book, first screen says set throttle to minimum, so I don't think I have missed a step. The trottle and trim are at their lowest setting travels set to 75%. The ecu does not recognize the throttle position and I get a rapidily flashing green light and can go no further. This is not my first Jet Cat I have several others and have never had a problem.
Shepp
Hide Signatures
       Post #: 6
RE: Can't learn Rc - 12/27/2012 3:40 PM
Greg Wright
Score: 102
Status: offline
What brand of radio are you using.
Greg Wright
Hide Signatures
(in reply to shepp)
       Post #: 7
RE: Can't learn Rc - 12/27/2012 5:26 PM
mr_matt
Score: 116
Status: online
I would increase the ATV a bit at a time to see if it takes, maybe on this radio 75% is not enough travel on the low end. You can worry about failsafe after you get it to learn RC.
Matt
Hide Signatures
(in reply to Greg Wright)
       Post #: 8
RE: Can't learn Rc - 12/27/2012 5:31 PM
Greg Wright
Score: 102
Status: offline
I'm thinking that if it is 2.4 Ghz then you might reduce the ATV to 50% on both sides as that is where you have to set JR or Spektrum radios to do the learn RC settings.
Greg Wright
Hide Signatures
(in reply to mr_matt)
       Post #: 9
RE: Can't learn Rc - 12/27/2012 8:34 PM
shepp
Score: 100
Status: offline
Thanks guys for your help. I tried everything you suggested, then called Bob lol. The problem is, I am not getting any signal from the reciever. He suggested I try a servo to make sure the reciever/transmitter is working correctly, checked all my connections and now He is pretty sure I have a defective ECU and I am returning it to him. What great guy. On the few issues I have had, Jet Cat has always given great customer service.
thanks again for your help.
Shepp
Hide Signatures
       Post #: 10
RE: Can't learn Rc - 12/28/2012 12:09 AM
rocketman-RCU
Score: 100
Last Login: 5/14/2013
Status: offline
Did you bind the Rx at 150% throttle travel volume?
Hide Signatures
(in reply to shepp)
       Post #: 11
RE: Can't learn Rc - 4/24/2013 2:08 PM
chopper52
Score: 100
Last Login: 5/18/2013
Status: offline
150% is just plain not right!!!!!
Hide Signatures
(in reply to rocketman-RCU)
       Post #: 12
RE: Can't learn Rc - 4/24/2013 2:48 PM
KC36330
Score: 328
Status: offline
quote:
ORIGINAL: chopper52
yes it is, you bind for failsafe with 150%, reduce to 75% and learn RC works perfect.
JetCat USA Rep / KingTech Turbines Rep
Hide Signatures
(in reply to chopper52)
       Post #: 13
RE: Can't learn Rc - 4/26/2013 6:10 AM
Gixxy
Score: 105
Status: offline
Got a Titan that's recently back from JC doing the same exact thing. Also have a p-160sx and 0 problems doing learn rc on it. But the Titan won't scroll past set throttle to min. Ecu is vs 6.0
Hide Signatures
(in reply to KC36330)
       Post #: 14
RE: Can't learn Rc - 4/26/2013 8:44 AM
KC36330
Score: 328
Status: offline
Does the value on the GSU change if you move the throttle stick?
Hide Signatures
(in reply to Gixxy)
       Post #: 15
RE: Can't learn Rc - 4/26/2013 2:14 PM
Gixxy
Score: 105
Status: offline
quote:
ORIGINAL: KC36330
Yes it does.
Hide Signatures
       Post #: 16
RE: Can't learn Rc - 4/26/2013 2:22 PM
KC36330
Score: 328
Status: offline
See if you can do the Learn RC with the button on the IO board.
Hide Signatures
(in reply to Gixxy)
       Post #: 17
RE: Can't learn Rc - 4/26/2013 3:51 PM
essyou35
Score: 100
Status: offline
Stupid thing I did when I switched to futaba, is taht the throttle channel needs to be reversed. Long shot but thought I would throw it out there.
Hide Signatures
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
